May have solved 100% E85 on LNF puzzle
Old Mar 16, 2011 | 03:22 PM
  #301
Iam Broke's Avatar
Originally Posted by RyRidesMotox
I can't wait til this is ready for the 2010s. You guy's haven't had to do anything with the pumps or fittings yet?
Not yet, I haven't had the opportunity to flog it yet though.
Old Mar 16, 2011 | 03:24 PM
  #302
Iam Broke's Avatar
Originally Posted by 2010SS
Wow I'm not sure how you guys are maintaining those kinds of mpg.. With the new tune for e35 my mpg have been constantly dropping I'm almost down to 19 mpg... With my tf tune I was about 23.5 on 93... Obviously I know that mpg will decrease but it seems like my foot is heavier than everyone elses haha
My commute is 95% highway and I used to get 30+ MPG on 93.
Old Mar 16, 2011 | 03:33 PM
  #303
RyRidesMotox's Avatar
Hmm that is my only hesitation. I do like to feel the boost quite often since my right foot is made out of a size 12 chunk of lead. Keep us updated
Old Mar 16, 2011 | 03:57 PM
  #304
VinceTrifecta's Avatar
My car was averaging around 23MPG during my testing, which is actually a little above what I usually see, but there was more highway driving than usual
Old Mar 16, 2011 | 04:15 PM
  #305
MS3 2 SSTC's Avatar
same here!!! LOL
Old Mar 16, 2011 | 06:03 PM
  #306
I don't give a rat's ass about fuel economy... Show me the powa!
Old Mar 16, 2011 | 06:34 PM
  #307
Iam Broke's Avatar
GOt one pull in tonight, had to back off in third as I saw over 28 lbs boost, gotta cut the DAL's back! Got on it again at 4k & wound it out to redline. No misfires or low fuel rail pressure but I think it was close at 2200 psi. Sent some info to Vince but got a reply his internet connectivity was bad so IDK if we'll see any more tonight from him or not.
Still looks promising, never got this far on >80% ethanol before. MPG Avg still reporting >30, but by my fuel PID remaining calcs in HPT & miles it's closer to 25 which is what I expected.
Old Mar 16, 2011 | 06:50 PM
  #308
FF_ace's Avatar
great news cant wait to load this in my car
Old Mar 16, 2011 | 06:56 PM
  #309
IAB... Thats good it sounds like. So there is still an issue in the midrange it sounds like or when you were getting 28PSI? You are running all bolt ons correct?
Old Mar 16, 2011 | 07:03 PM
  #310
Yes, sounds promising for sure.
Sorry for the tech issues, I'm actually out of town right now and it looks like something happened to my machine back at the office (power failure, internet problems). I'll be back online tomorrow afternoon.
Old Mar 16, 2011 | 07:10 PM
  #311
cubaniche's Avatar
Sweet! Good progress
Old Mar 16, 2011 | 07:21 PM
  #312
BYT*SS*TURBO's Avatar
Try dropping it back to like 20psi even and see if it pulls clean. See what the limit of the 2200psi is
Old Mar 16, 2011 | 07:31 PM
  #313
Iam Broke's Avatar
I loaded my tables instead of BYT's DAL & MALT, should be more reasonable tomorrow.
Ry - I let off when the boost gauge caught my eye, it was at 28 lbs! I'll post a screencap, BRB...
Yes, fully bolted now, stock turbo. Also pulled a few % fuel in the areas it wanted less.
Oh yeah, no KR false or otherwise in the entire log.
Old Mar 16, 2011 | 08:20 PM
  #314
My ***** just got hard. Is your boost set to go that high or did the E85 make it go that high.
Old Mar 16, 2011 | 08:31 PM
  #315
paintballerr78's Avatar
Cant wait till this is done.
Old Mar 16, 2011 | 09:08 PM
  #316
Iam Broke's Avatar
LOL.
Well, it ~WAS~ a 24 psi tune before. I guess all the extra fuel added a bit o' boostage in the midrange. I loaded some tamer DAL & MALT tables tonight, we'll see.
Old Mar 16, 2011 | 11:05 PM
  #317
LOL.
Well I can kinda see why as far as the mechanics of the combustion go. We are putting in a ton of fuel with E85... Some of the extra fuel is still going through thermal expansion when it is leaving the cylinder because it isn't fully combusted. Sounds like it would be magic for a big turbo setup well minute the higher EGTs. Or maybe I'm way off I dunno lol I'm jsut excited for the E85 right now haha. Let me know about the "tamer" tables. Maybe we don't need as much fuel as initially anticipated.
Old Mar 17, 2011 | 05:45 AM
  #318
Iam Broke's Avatar
The extra fuel has to be there for proper lambda, adding more ethanol adds more oxygen molecules.
Old Mar 17, 2011 | 11:35 AM
  #319
Iam Broke's Avatar
Got one pull in this morning at 23 psi, just about hit the fueling wall at 2200 psi fuel pressure, popped twice in the midrange during the pull.
Inj % above 50%, no low fuel pressure CEL logged. 4.6 sec 60 - 100, slightly slower than my 47% E average at these temps (~4.5 sec) but I'm having intake cam actuator issues also right now.
AVG MPG displayed is still over 31, calculated from fuel remaining is around 23-24. Perhaps the fuel mass shift is fooling the BCM into better displayed mileage? IDK.
Old Mar 17, 2011 | 11:38 AM
  #320
Omnigear's Avatar
2many lines goin every where >_<
Old Mar 17, 2011 | 12:26 PM
  #321
LOL
Have you tried any more Spark advance? I notice you are running 24*... I can't recall exactly but don't LSJs run a few more degrees?
Old Mar 17, 2011 | 12:56 PM
  #322
Iam Broke's Avatar
I was running up to 27* from 4k up and a lot more in the midrange than I am now until I vaporized #2 spark plug one day never showing any KR. All at once I logged misfires galore and most of #2 spark plug was gone. Detonation must've got me when I got cocky on the 60% E blend. :-/
Old Mar 17, 2011 | 01:13 PM
  #323
Iam Broke's Avatar
Not if you know what you are looking at. :p
Old Mar 17, 2011 | 02:44 PM
  #324
OK so you are running it fairly conservative at the 24 then... good news. Whats going on with the intake valves,a s you stated above, that is causing the issues? Is it something the rest of us need to keep an eye out for when switching to E85?
Old Mar 17, 2011 | 02:47 PM
  #325
Iam Broke's Avatar
No, it's a separate issue I've had for about a week. My intake cam actuator is popping an intermittent P0010 and stops responding after a while, sometimes the intake cam sits at 0.0*, sometimes it wanders around. The new cam actuator arrived today, hopefully it'll be resolved tonight.
Not whatsoever related to any ethanol . It just decided to die at 57k mi.
