Meth is up and running!
Old Apr 30, 2011 | 06:59 PM
Iam Broke's Avatar
Over the last week I installed an AIS Stage 1 kit using my WWF tank and a Devil's Own tank tap. 5 GPM nozzle installed in the ZZP lower CP at the MAF relocate block off plate.
New 3 gal trunk mount tank is for sale in the Classifieds if any one is interested.
From what I have read locating the nozzle too far back causes evap too early and doesn't leave as much cyl cooling, the main reason that I installed it.
Boost is currently set to activate at 10 psi mani pressure. 'ON' LED is installed in the cowl. Pump, tap, & pressure sw are located down in the bumper behind the drivers side foglight.
Here's a few pics I took before the pressure switch arrived today. (Pressure sw not shown but it is mounted down by the pump)
Using 30% meth WWF for now. Fuel trims adjusted about -7% in a quick run. More dialing it in Monday. 25 psi boost.
Old Apr 30, 2011 | 07:06 PM
SunburstSS's Avatar
Whats that pump resting on ? or what is bolted to ? I like the led btw
Old Apr 30, 2011 | 07:11 PM
slowstang's Avatar
Good ****. I'm interested in your results because my AIS kit comes in on Monday
Old Apr 30, 2011 | 07:14 PM
Iam Broke's Avatar
Bolted to the fender liner with rubber bushings & resting on a piece of closed cell foam underneath it for padding. Intake line to the pump runs around under the WWF tank to a straight fitting you can't see. Vertical tubing after the 90* fitting is the outlet. Power tapped out of the underhood FB and all wiring runs in automotive style looming.
Old Apr 30, 2011 | 07:23 PM
Iam Broke's Avatar
Here's the line route if you look carefully from the intake mani & to the nozzle...
Old Apr 30, 2011 | 07:30 PM
Iam Broke's Avatar
Check all the fittings, including the check valve. Some were not tight and leaked at first.
Parts all are very nice quality in the kit. When I called Rodney about the missing boost switch in the kit, he sent one out the same day Priority Mail. Excellent service!
SunburstSS's Avatar
yeap i see it looks good job nicely done sir..
Old Apr 30, 2011 | 09:33 PM
Iam Broke's Avatar
Thanks!
Old Apr 30, 2011 | 09:55 PM
Gremlin85's Avatar
Very nice!
Thank you for posting this up. I really like how you installed the LED. Well done, sir.
Old Apr 30, 2011 | 10:04 PM
09BlueBaltSS's Avatar
Arent you already seeing lower egt's with the e85? Why meth?
Old Apr 30, 2011 | 10:07 PM
Iam Broke's Avatar
Cleaner intake & valves, cooler temps & more fuel.
Getting ready for the ZZP turbo bolt on when it comes out. lol.
Old Apr 30, 2011 | 10:10 PM
Got you. Im about to hop on the E47 train myself
Old May 1, 2011 | 11:19 AM
Sweetsandman's Avatar
It's a fantastic train
Old May 1, 2011 | 01:02 PM
Gremlin85's Avatar
Just curious, why did you choose it to come on at 10 psi? I was leaning towards 15 for myself, but I wasn't sure. I peak 25-25.5 psi.
Old May 1, 2011 | 03:33 PM
Iam Broke's Avatar
Just a starting point, AIS recommends 65% of total boost so 16 # would be right I guess. It's rare I get into 10# of boost unless I nail it anyway. Usually 5# or so is enough to roll around someone in traffic. If I seem to be using too much, I'll raise it up some.
Old May 2, 2011 | 11:28 AM
Iam Broke's Avatar
Got into it a bit this morning, 10# feels about right for the activation point, couldn't get a good log though. Maybe tonight.
I'm still waiting for a brass tee for the vacuum line, I don't trust the old nylon one I had laying around too much long term.
Old May 2, 2011 | 11:53 AM
AcesNEights's Avatar
Thats exactly how mine is, besides the pressure switch.
Old May 2, 2011 | 12:43 PM
cranemaster's Avatar
Very nice install, dyno!
Old May 2, 2011 | 02:35 PM
Iam Broke's Avatar
Meh..., dyno's just give semi-random numbers. Wanna race? lol.
Old May 2, 2011 | 02:40 PM
Gremlin85's Avatar
ooh! ooh! I do, I do! lol
Old May 2, 2011 | 06:21 PM
Iam Broke's Avatar
What's halfway between Mass & Ind? BYT's place? I'll race you there. lol.
Old May 2, 2011 | 06:30 PM
beast10007's Avatar
any good 60-100 times
Old May 2, 2011 | 06:48 PM
Iam Broke's Avatar
Not yet.
Old May 2, 2011 | 06:54 PM
beast10007's Avatar
Not yet.
I want them now!!!
lol
Old May 2, 2011 | 07:01 PM
I got a 4.9 60-100 the other day when I blew my fuse for the pump. Didnt spray at all, and had about 4* KR up top....But 20*+ timing is nice tho lol
