need a clutch?
Old Apr 15, 2011 | 11:03 AM
  #51
09CobaltSS1's Avatar
Originally Posted by Mark Aubele
My car is stock save a K+N drop in and the stock clutch started slipping at 17K miles. Stock clutch is garbage. Car has been to the dragstrip once, road course three times. Unacceptable IMO.
The stock clutch is a solid piece. Sorry you had an issue with yours, but burning out or glazing due to impropper use isn't the clutches fault.. that would fall under user error
Old Apr 15, 2011 | 11:28 AM
  #52
emiller's Avatar
How did you wreck your clutch in 17k miles? There are at least a few tuned people still on stock clutches.
Old Apr 15, 2011 | 11:36 AM
  #53
Baron7700's Avatar
MOST tuned people are on stock clutches hah. Mine holds 360wtrq pretty well.
Old Apr 15, 2011 | 12:00 PM
  #54
emiller's Avatar
I'm still on the stocker too. Don't have as much power as you but it does just fine. If you don't abuse it or put make huge power it turns out to hold just fine.
Old Apr 16, 2011 | 05:15 AM
  #55
RyRidesMotox's Avatar
As some of the other guys said... alot relates to how you drive it. I know a guy in Tucson (Drewbroo) who makes more power than me and was running around on a stock clutch.. If you hammer it at too low of an RPM it will slip... the more you do it the worse it gets. I was gentle on mine for the most part and it didn't slip under WOT as long as it was in the correct gear. Especially with an untuned car... I would say that it was either a defective clutch or maybe you were lugging it and then going WOT to often. It's easy to do but it should be done as little as possible.
I am putting down a ton of torque and the clutch looks almost perfect still after a few thousand miles of driving it and beating on it a little. I'll take a picture and post it in the morning.
Old Apr 16, 2011 | 05:34 AM
  #56
Zander916's Avatar
Yep. I agree. I'm tuned and my stock clutch didn't really start slipping until I reached over 60K miles or possibly more. It's hard to say. But even now it doesn't slip THAT bad but it's getting worse. It used to only slip if I was in the wrong gear but now it noticeably slips sometimes at 65-70mph in 3rd which is the proper gear to be in. I'm at 73K miles though right now so it's got some wear on it I'm sure. 17K miles is just.... outstanding.
Old Apr 16, 2011 | 08:43 AM
  #57
SSBalt's Avatar
Around 4k total miles, added a Trifecta tune =slippage for me. And i drive like a sissy compared to a lot of you guys. Sometimes i feel like they threw in an aveo's clutch just for snitz and giggles.
Old Apr 16, 2011 | 03:30 PM
  #58
ronn's Avatar
Wow...I bet you're running over 370Ft Lbs. What boost are you running? Have you ever drag raced it? Stock clutch should hold up to 350 Ft Lbs. I have tune and around 360 Ft lbs..ZERO slip. The stock clutch is pretty damn robust.
Old Apr 16, 2011 | 03:34 PM
  #59
ronn's Avatar
Originally Posted by 09cobaltss1
the stock clutch is a solid piece. Sorry you had an issue with yours, but burning out or glazing due to impropper use isn't the clutches fault.. That would fall under user error
this!
Old Apr 27, 2011 | 06:33 PM
  #60
xray_racer's Avatar
I've also had good luck with the stock clutch + being tuned. But I've always tried to rev match, pop it into neutral when stopped, etc, just as a general way to prolong clutch life and she's still holding strong. I can make it slip if I go full boost at too low an RPM (a big no no) like some others have said, but if I drive it right there's no slipping.
I also dynoed 378 ft lbs, but who knows how accurate that really is.
Old May 5, 2011 | 08:07 PM
  #61
SSBalt's Avatar
Sry for the late reply, Highly doubt im making that much TQ. I wish! (Early Trifecta tune 22psi)
Anyway I got my new clutch put in and the mechanic said the stocker looked unused. Even the flywheel was showroom new. Just confirmed what I already suspected, that It wasn't my driving. Probably just a underachieving Gm part.
Old May 5, 2011 | 09:15 PM
  #62
Omnigear's Avatar
spec 2+ clutched here , its slippy slippy from time to time. depends on how many pulls i have done in sequence ^_^ .
Old May 6, 2011 | 12:02 PM
  #63
09BlueBaltSS's Avatar
They just got some more pressure plates on Monday. I ordered mine on Tuesday and received it today. It's a very sexy looking disk.
pics
Old May 6, 2011 | 12:15 PM
  #64
Dart_SI's Avatar
i was on a trifecta 24psi tune, no slip. now im on a hp 20psi tune and still no slip. the hp tune feels just as fast as the 24psi tune.
anyway when i get a new clutch eventually its going to be a zzp stage 4.
Old May 8, 2011 | 03:38 AM
  #65
A.J.'s Avatar
Originally Posted by Supercharged Guy
Just get the spec 3+
Decent price and good
i agree i bought there stage 3+ and new light weight flywheel and let me tell u it grabs hard
Old May 8, 2011 | 10:43 AM
  #66
kxrida2000's Avatar
spec 3+ sucks ass..me and 2 other members have recently had them slip horribly and eventually i ripped the rivets holding the clutch together apart.
Old May 8, 2011 | 12:01 PM
  #67
Chevycobaltss3's Avatar
When i had it on my lsj i blew the rivets and blee one of the holding carriers for the springs....
Old May 8, 2011 | 12:39 PM
  #68
mmcgee123's Avatar
I've had stage 3 spec for 40k makes a little noise but it looked fine when we took the motor out
Old May 8, 2011 | 12:45 PM
  #69
Gremlin85's Avatar
37k miles, 20k have been tuned, been down the strip quite a few times. Still on the stock clutch and it's holding ok. Power at the wheels is in my sig.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
