New Bolt-on EFR Video
Old Nov 18, 2011 | 06:59 PM
  #151
sponge14's Avatar
Originally Posted by ULWiz Cobalt SS/SC
A decent tune on a 6758 should easily put you over 400ish. And as far as i know the EFR is not a bolt on solution on your stock k04.
ZZP has said their EFR will be bolt on.
Old Nov 18, 2011 | 07:29 PM
  #152
ULWizSS's Avatar
yep evetually next spring
Old Nov 18, 2011 | 08:19 PM
  #153
donkeyballs's Avatar
I call dibs on it!!!!!!!
Old Nov 18, 2011 | 09:42 PM
  #154
soundjunky's Avatar
umm...
... And as far as i know the EFR is not a bolt on solution on your stock k04.
thank you...
lemme help you with this;
https://www.cobaltss.net/forums/5629704-post1.html
Old Nov 19, 2011 | 12:30 AM
  #155
ULWizSS's Avatar
umm...
thank you...
Yes its becomming a solution but its still not available yet so what are you helping me with exactly besides showing people its still not available yet.
Only one unit besides this car is available until spring.
Old Nov 19, 2011 | 12:39 AM
  #156
Knightwolf's Avatar
You already have one!!
Old Nov 19, 2011 | 01:10 AM
  #157
soundjunky's Avatar
As you just pointed out, the other day Matt said that one would be available (I think it was a black friday thing);
This thread, and any subsequent/recent ZZP-EFR turbo threads have been totally about the 100% bolt on EFR turbo ~ not about any other turbo.
Matt has been making these threads to keep the subject of their pending 100% bolt on EFR turbo relevant while we've all patiently (some more than others) waited for it to become available...
... and for those who haven't had the patience, I would guess that the secondary purpose (intended or otherwise) behind these EFR turbo threads has been to help ZZP sell packages for their other turbos.
I am the patient type, which is why I'm subscribed to this thread, and his other (pending) bolt on EFR turbo threads...
Old Nov 19, 2011 | 01:27 AM
  #158
ATLsilverSS's Avatar
he was asking what it would make with just the efr swap and no other mods besides an intercooler. im not sure that the efr without a downpipe and an intake to let it breathe would get too far past 375is on pump gas. i could be totally wrong here but it that turbo would be seriously choked up without those mods. besides who does a turbo swap with no other supporting mods anyway
Old Nov 19, 2011 | 01:31 AM
  #159
ULWizSS's Avatar
Its cool. An EFR 6758 owner myself. Or at least will be here in two weeks when i finally get my car back from BYT. Putting it on the dyno myself so i will post of some LSJ results with this turbo on.
Old Nov 19, 2011 | 01:48 AM
  #160
soundjunky's Avatar
you know I didn't stop to think about that... good point.
I would expect that supporting exhaust mods (at least a downpipe) would be presumed...
the whole thing is that all of Matt's threads so far are a EFR Cobalt with, cams, an extra injector(?), running on E85... which on the last point alone is kinda moot since not everyone has access to E85.
back to the supporting mods bit - I had understood that many parts are not needed - but chosen to be changed at the same time as a turbo upgrade... almost just because.
I have understood that the sole reason for an intercooler upgrade has been to lower restriction in the charged airflow - which is sound logic if you plan on increasing air volume in any way shape or form... (plus I like that this can be hidden)
I have understood that upgrading the charge piping is done almost more for 'bling' than anything else - the only real reason to do this would be that if you up the boost pressure, and/or air volume, that the OE plastic piping becomes a liability.
the latter point is kind of a bummer - because I personally like the subtlety of using all OE (exposed or visible at least) parts as possible - which is the key reason why I personally have no plans for an intake....
awesome!
Old Nov 19, 2011 | 11:58 AM
  #161
awesome!
there are a couple reasons for an intercooler upgrade. the stock intercooler has plastic endtanks and is not as efficient at cooling the air after multiple pulls. the main reason most upgrade the ic is for reliability reasons...hence the plastic endtanks that are prone to breaking.
the same goes for the charge piping. the plastic charge piping is prone to breaking....ask me how i kow lol.....and the bends flatten out in a couple places and restrict airflow.
Old Nov 19, 2011 | 12:33 PM
  #162
MajorCB's Avatar
awesome!
this is kind of what I was getting at... my ultimate plan was to make an upgrade that was essentially stealth... this EFR seems to bring that possibility to the surface. My thought was to put on a Intercooler mainly to reduce heat soak issues.. not really to increase peformance..as for the DP, I know its a source of restriction on the car, but I guess I wondered what the BASE requirements of the ERF were... in terms of keeping all other elements of the car stock ( intake, DP )... Ive seen some folks suggesting that the normal mods are expected.. but what someone wants to keep wraps on the power in the car?
now the story on the charge piping is another issue I guess.. some people say its a better idea to go along with a intercooler, but I'm not so sure its necessary... however with this EFR, it would be nice to know whats "reccomended" in terms of bottom line to allow the turbo to run "efficiently".... so here are my personal goals... and maybe the field can decide if they are achievable with the EFR...
-HP tuned with intercooler ( already in the works and have the HP tune on top of the GMS1 upgraded sensors)
-look & sound stock ( i.e. no intake , no DP)..
-sustainability , meaning I want the car to last with no daily performance issues
-keep the MPG's at or around 25mpg
-WHP AOA 350-375 with lower boost....
I guess my thinking here is that with a much more efficient turbo... I could get more horse power without having to raise boost, hell maybe even lowering it... which to me means keeping the car less prone to problems, being efficient and fun without breaking it...but still making gains, and not having to put on a bunch of peripheral parts... I guess the question is, what can the stock DP handle.. does it require an intake and upgraded DP? what are the expected outputs without them? .... there is alot here I know.. my brain doesnt wrap around all of this... but Im looking for a balance between more power while keeping the engine running at a happy place and not blowing it up... I think you all get that lol...
Old Nov 19, 2011 | 12:58 PM
  #163
If you want to keep your engine happy you need to upgrade with basic bolt ons.
Old Nov 19, 2011 | 02:28 PM
  #164
pistol_junior23's Avatar
I'm curious too! What the car would make by just doing a turbo swap on a GMS1 car. If i did just the turbo of course i would get a aftermarket tune but makes you wonder!
Old Nov 19, 2011 | 03:47 PM
  #165
soundjunky's Avatar
the DP isn't visible;
for even a GMS1 car the DP is a legitimate upgrade ~ with the exhaust restriction associated with it noticeable via the basic butt-dyno...even vondors has proven that w/o a tune change the downpipe does add power...
think of it this way; if the exhaust is restrictive - the turbo cannot spool up quickly...
iirc a more restricitve exhaust will also cause higher exhaust temps which have negative effects on the turbo...
iirc on a stock turbo, with even a downpipe, the stock exhaust isn't a restriction;
I would think that upgrading to a better exhaust would also be a good idea.
I would strongly encourage you to upgrade your downpipe.
tomj77
Oct 2, 2020 05:36 PM
Jan 12, 2016 12:01 AM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
