NLS and mods
Old Apr 17, 2010 | 01:22 PM
northvibe's Avatar
I'm going to it as well on my way home to my parents, I'll update as well and try to nls at 6200rpm instead of 6k.
Old Apr 17, 2010 | 02:48 PM
swazzees's Avatar
your GMS1, am I right Northvibe...are you catless too?
If so lets help me and or us figure it out right.
5 pops was a scary time
Old Apr 17, 2010 | 04:44 PM
northvibe's Avatar
I am Gm stage 1 with only injen charge piping and a k&n drop in filter. I ordered a hahn catted downpipe but it is not at my door yet. Hmm I did a nls 2nd to 3rd and 3rd to 4th on the way down and did it up just after 6100rpm and it went fine. No pop though. I think I'll pop again when the down pipe is put in, I bet I blew my cats out a while ago ahah
Old Apr 17, 2010 | 04:47 PM
Mike_peperni's Avatar
I also rarely hear the pop sound, once in a while... sometimes it sound more liek pshhh
But i know it work, the car just keep pulling no hesitations..
Old Apr 17, 2010 | 10:37 PM
G Speed's Avatar
the pshhh/screech sound
If you shift fast enough, it will not make a pop's at least on the stock exhaust since there will be less fuel being wasted needing to be burned... if you do it slow... more fuel more pops
Old Apr 18, 2010 | 12:11 PM
swazzees's Avatar
I went out and did one finally,
did a 2 to 3
shifted faster.....but my RPM's were lower maybe 5800
it grabbed hard into 3rd, and popped once....
mus thave been my slow shifting in my OP
thanks for the opinions and stuff guys
Old Apr 19, 2010 | 01:59 PM
wantedSS/TC's Avatar
Originally Posted by steddy2112
Car has been out for 3 years now and people still are confused about no lift shift.
Done right it should be one pop.
Not 5
Not 3
Not 198432732846873264
1.
Now go ahead and NLS with full bolt ons and tune.
Old Apr 19, 2010 | 02:08 PM
swazzees's Avatar
Tell us how it goes man......
Old Apr 19, 2010 | 02:09 PM
I've seen the damage (not my car personally). It's not pretty.
Old Apr 19, 2010 | 02:12 PM
swazzees's Avatar
Im not fully bolted or tuned for that matter, but im still not making a habit out of it.
I dont think the car likes it very much
just going to do it @ the track
Old Apr 19, 2010 | 02:14 PM
  #36
cmiller8006's Avatar
Shifting way to slow. Didnt read it all to see if someone else said this already.
Old Apr 19, 2010 | 02:16 PM
  #37
Permafried-'s Avatar
Darryl, when you NLS on the 401 did you go right to 6500RPMish....or were you closer to 6000? I never ever let mine hit redline because if you miss it by that split second you're into rev limiter and NOT NLS and the tach lags a bit. At 5800 it sounds like it did what it was supposed to. Stock I would do it about 5800/6000RPM and it worked every time, with the GMS1 I'm pushing closer to 6200 or so. Mind you, when you did it beside my window on the 401 it didn't sound like a misire, that was fine. The 5 or so pops was definitely rev limiter and not NLS however.
He did one clean beside my window on the highway at 11pm, the only other noise besides us two making racket with our cars was the occasional truck, I guarantee his shift the first time (not his 5 pops one) was not too low .
Last edited by Permafried-; Apr 19, 2010 at 02:20 PM. Reason: Automerged Doublepost
Old Apr 19, 2010 | 04:00 PM
  #38
swazzees's Avatar
lol
soooo good one beside you, then I did a bad one....last one was right.
The whole point of this thread was to see if anything was supposed to change when I changed the DP.
From everything that I have learned is nothing changes, its good,
And Perma, the change I did beside you was where the old rev limit was.
I used to hit redline.....when I was going to NLS......it pissed me off, but I keep forgetting I have an extra 300rpm now, it works out perfect....when I see the needle hit 6,000 I switch it up.
Old Apr 19, 2010 | 04:29 PM
  #39
ninja44's Avatar
Sounds like you're bumping the rev limiter, put the keys down now and walk away
Old Apr 19, 2010 | 04:40 PM
  #40
owned. He bought everything but a driver mod over the winter .
Old Apr 19, 2010 | 04:42 PM
  #41
^^ lol.
Old Apr 19, 2010 | 04:45 PM
  #42
Cobalt_Daddy's Avatar
same here...
Old Apr 19, 2010 | 04:51 PM
  #43
crypticscifer's Avatar
Kinda like what a mouth looks like after chewing on glass right....
Old Apr 19, 2010 | 04:54 PM
  #44
Old Apr 19, 2010 | 05:31 PM
  #45
swazzees's Avatar
good one.lol
I already tried to tell how bad of a driver I was.
Anyways, yes I just said I used to hit the limiter on stock tune, now that its 6500 Im good.
It easier to drive now, cept that pesky 2nd gear lets loose all the time damn conti's
bigdeertz
Nov 17, 2016 09:41 AM
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
The Rookie24
Sep 20, 2015 04:33 PM
