No intercooler upgrade needed when using E85
Old Mar 9, 2011 | 10:36 AM
2000Firehawk's Avatar
Ok, I'm thinking that there's no reason to swap out the stock intercooler, if your'e going to make the switch, & run E85.
Because E85 removes latent heat, & resistance to pre-ignition is much higher than gasoline, so its much safer, & besides, the stock intercooler can't be that bad.
Maybe I'm wrong, but has anyone done any, before/after testing running E85, with a stock, and then an aftermarket intercooler, to see if it makes any difference.
One less thing to worry about, when switching to E85, if it's really not needed.
I did a google search for ' E85 intercooler' & discovered that some guys don't even use an intercooler when using E85...
Old Mar 9, 2011 | 10:38 AM
BYT*SS*TURBO's Avatar
Doesn't keep the plastic tanks from exploding
Old Mar 9, 2011 | 10:43 AM
Sweetsandman's Avatar
Troof.
This is my biggest fear now that I'm back on the modding trail. I just don't want to go through taking my front bumper off. Did a heat exchanger on a buddies SS...Getting it off wasn't bad...but damn those little clips make it a pain to get back on I'll just wait for catastrophic failure to do that mod.
Old Mar 9, 2011 | 02:17 PM
SSlobalt's Avatar
I'm going to time my ZZP IC install. I can get me bumper off in about 15 minutes and back on in about 20. I've had plenty of practice lately. It's easiest to do it without taking out the headlights.
Old Mar 9, 2011 | 03:56 PM
silverbullet08's Avatar
[QUOTE=2000Firehawk;5620246]Ok, I'm thinking that there's no reason to swap out the stock intercooler, if your'e going to make the switch, & run E85.
I did a google search for ' E85 intercooler' & discovered that some guys don't even use an intercooler when using E85...[/QUOTE
the people running no intercooler are either rear mount or running a really low boost setting. E85 does help cool the charge and produces lower EGTs, but its not enough for the stock turbo on these cars being pushed to the limit. I notice with my afterarket intercooler that i get about 7degrees rise out of a third gear pull on my iats compared to 30 degree rise on a third gear pull on the stock intercooler. Thats at 23-24 psi. You will still see the same iats on e85 of coarse, But with a aftermarket intercooler your charge temp will be that much cooler. The cooler the air the safer it is for your motor... to a extent.
Old Mar 9, 2011 | 04:19 PM
Grishbok's Avatar
wouldnt an ideal set up be along the lines of a short track small air to water intercooler? just sayin...
Builttss
Oct 4, 2015 10:21 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
