P0010+p0013 and boost issues
Old Dec 18, 2013 | 10:04 PM
hucks1987's Avatar
P0010 and p0013 even with new Sensors
While data logging my Exhaust cam noid went out, easy fix right? No, I have replaced it with 3 brand new sensors and still pulling the code, iam so lost. Also both wires have power, not to sure if they should. But the wires are fine
Old Dec 19, 2013 | 08:58 PM
hucks1987's Avatar
Bump, no help?
Old Dec 20, 2013 | 08:09 AM
hucks1987's Avatar
So P0010-P0013 plus limp mode with new solenoids
Old Dec 20, 2013 | 09:55 AM
umrdyldo's Avatar
You replaced both?
If so check the wiring between selenoids and ECU. Not sure about the resistance between them.
Old Dec 20, 2013 | 10:02 AM
LS6Rally's Avatar
im willing to bet its a different issue if you're getting both intake and exhaust simultaneously. have you done any other work to the car recently?
Old Dec 20, 2013 | 11:38 AM
umrdyldo's Avatar
Also most people say to try changing your oil if it hasn't been done in awhile.
Not sure it will help, but it is suggested.
• The engine oil level and the oil pressure are critical to the correct operation of the camshaft position actuator system. Verify that the engine has the correct oil level and the correct oil pressure before continuing with this diagnostic. Refer to Oil Pressure Diagnosis and Testing.
• The engine oil condition has a major impact on the camshaft actuator system. Debris in the oil can interfere with the camshaft position actuator solenoid and the mechanical camshaft actuator operation. Inspect for dirty or degraded crankcase oil. The engine may require an oil change. Inquire with the customer when the last oil change was performed. You may also monitor the scan tool Engine Oil Life Remaining parameter. Advise the customer an oil change may be required.
You could also do these tests with a OHM meter to check the solenoid valves youeself!
Ignition OFF, disconnect the harness connector at the Camshaft Position Actuator Solenoid Valve.
Test for 8-12 Ω between the control terminal A and the low reference circuit terminal B of the Camshaft Position Actuator Solenoid Valve.
⇒ If not within the specified range, replace the Camshaft Position Actuator Solenoid Valve.
Test for infinite resistance between each terminal and the Camshaft Position Actuator Solenoid Valve housing.
⇒ If not the specified value, replace the Camshaft Position Actuator Solenoid Valve.
Old Dec 20, 2013 | 02:40 PM
hucks1987's Avatar
The only work I have done was put the turbo back on, and the oil is brand new. Like yesterday new, and those sensors are new, and it has 9.5-9.8 ohms
Old Dec 20, 2013 | 02:56 PM
hucks1987's Avatar
Old Dec 21, 2013 | 10:46 AM
hucks1987's Avatar
Just so you know, there is a 10amp fuse for those. And that's what blew
Old Dec 23, 2013 | 05:29 AM
LS6Rally's Avatar
awesome, glad it was simple. at least you upgraded your sensors in the process...
Old Dec 23, 2013 | 08:31 AM
hucks1987's Avatar
I didnt upgrade anything, they are the stock ones......
Old Dec 23, 2013 | 11:12 AM
LS6Rally's Avatar
I believe that GM Revisioned them to now have a nice metal housing Vs. the shitty plastic one most of the cobalts came with
Old Aug 21, 2019 | 07:02 PM
Atokad Smottob's Avatar
Where is the 10 amp fuse located???
I literally have no clue where it’s located
Old Aug 22, 2019 | 04:01 PM
umrdyldo's Avatar
Under hood fuse box. It's labeled EXH. Enjoy
Old Nov 25, 2020 | 12:09 PM
Silverbullets's Avatar
Thank you sir.
thank you sir
maccos
Aug 3, 2014 01:23 PM
Louee29
Jul 15, 2014 11:02 AM
MajorCB
Apr 12, 2012 12:59 AM
dunc
Sep 16, 2011 10:41 AM
ripped
Aug 27, 2010 05:34 PM
