P0089 (fuel pressure regulator 1 performance)HELP!
ok i got this code and my car is iddling like ****... it turns off and everything... what could this possibly be
please help me!!!
thanks!
please help me!!!
thanks!
i got this code a few times at the track but never caused me a problem i think i took my air filter off one of the times maybe u have an intake leak
This code is caused by your actual fuel pressure being above or below your commanded fuel pressure for a certain amount of time.
Basically your car didn't get the fuel pressure it was expecting, when it expected it. Off hand, I'd imagine this could be due to the fuel pump going out or a clogged fuel filter.
I had this pop up on a long 5 hour trip, where I did a few WOT runs every once in a while to mix things up. After a while the code went away on its own in my case. If your car is not idling properly, I'd take it in for warranty work on possibly the fuel pump going out.
where would the fuel filter could be at?
If you've got a clog/restriction upstream, then the high pressure fuel pump may not be able to flow enough fuel.
I don't think it's got a second one, but if it does somehow, then that could be another place to check.
The code should be for the high pressure one. The low pressure one feeds the high pressure one and has the fuel filter. I'm saying that if the fuel filter in the low pressure one has a bunch of junk in it or something, then it may not be able to flow enough fuel to the high pressure fuel pump.
I have the same problem Cardelino but it happened after i cleared the codes. I unplugged the mass air flow sensor and it started running. Now i have more problems. It was running fine before i cleared the codes.
