Performance With intake...
After installing my HAHN intake my car seems to be sitting around 900-950(normally right at or a little ovee 1k) rpms and bogs out pretty low when i first start it up. is there anything i can do to stop this besides a tune? gap my plugs a little more?
I know this is probably the first thing you checked, but did you make sure you did not install the MAF backwards? That would cause boging and idle issues. I have a Dejon SRI with an AEM filter and I have no boging or idle issues in fact I think it pulls a little harder now.
I know this is probably the fist thing you checked, but did you make sure you did not install the MAF backwards? That would cause boging and idle issues. I have a Dejon SRI with an AEM filter and I have no boging or idle issues in fact I think it pulls a little harder now.
^that may have something to do with the larger amount of cold air combined with the cold engine. I know the SC'd cars have problems compensating for the change in cold air density. that might be your issue, but, i am not an expert.
[QUOTE=ls1fbody;3407295]Haha, Edwards and Slater, over by Hope View Elementry. My home station is at Fort Bragg, so i'll be part of the NC crew when i get re-deployed to the States.QUOTE]
Right on, yeah i miss ol' southern cal. sure wish i was chompin down on a double double right about now.... or maybe some tacos from jack in the box.......
im going to re install my intake this weekend i think. i need to fit my elbo back onto my turbo caus ei guess it worked itself a little loose and i can see metal. and ill also check my maf. it sucks though hahn didnt send me new maf hex screws in my order so i had to re use my old ones and make new threads, and a day later they arived fedex with a sorry for forgetting note lol.
I don't have any boggin issues and my idle is normal and i haven't tuned it yet.
If it can be installed upside down, than someone please show me a pic of how it is supposed to be installed. Either way, mine idles rough at start up, but I believe the computer is compensating for the extra air flow and reworking itself. Either way, I let my car run for about 10 minutes before I drive it and havent had a single issue yet.
yeah i was occ about installing that backwards and triple checked, but maybe i somehow ended up installing it backwards.... but wouldnt that have thrown a cel? im already 500 miles into this mod? now it only bogs down when i first start it in the morning and when its wamed up it idles fine....
I noticed with my Hahn intake the throttle hangs a lil n thakes a bit longer to drop to idle rpm rather then drop fairly quick like it did when stock
I dont got and booging issues or anything of that kind
if you think its in backwards take it out im pretty sure it has a arrow on it telling you the direction the air flows across it not supper sure but i cant take mine ot to tell you sorry, i would just it had a leaking seal on my custom intake so i sealed it in with sensor safe rtv haha ghetto i know
