View Poll Results: uhhh
i want some of what ever this guy is smoking
47
49.47%
he is uber smart...thats right uber
5.26%
/end thread
43
45.26%
Voters: 95. You may not vote on this poll
pulled fuse = 10hp??? lol
Old Aug 19, 2009 | 03:57 PM
fshizl's Avatar
after you pull some fuses i heard that if you suck on the exhaust while the car is running you get better flow through it...
i havent tried it but i figured its worth a good 10-15 hp
Old Aug 19, 2009 | 03:58 PM
09CobaltSS1's Avatar
Originally Posted by 09WhiteSS
wow...im ******* stunned at some of these insanely idiotic responses about pulling fuses....
i pulled the fuse for the muffler bearings and seriously picked up like 50whp
Old Aug 19, 2009 | 04:07 PM
DarkCobalt13's Avatar
The EXH fuse is for either bank 1 or 2 O2 sensors or both, im not sure. Pull it and the car goes into open loop. As to what it would do to the PCM while it still reads the other inputs, I dont know..... My guess is a longer pulsewidth than normal, which may result in a little more throttle response depending on other conditions but it doesnt give more power and is not a smart thing to do.
Old Aug 19, 2009 | 04:10 PM
Nal's Avatar
Nal
it makes the car run lean you need to retune for this
Old Aug 19, 2009 | 04:35 PM
dunit121's Avatar
Originally Posted by Shez
It might have been the exhaust fuse. Me and a friend were checking out the fuses one night since I just got the car and I was just checking **** out. We found a fuse that said EXH or something like that. I took it out and noticed a little more popping in the exhaust but that's about it. I had a check engine light at the time from putting hot side intercooler piping on wrong. After I fixed the piping I had a friend scan it with his computer he gave me the codes the piping put out and it also gave him o2 codes which I'm guessing is from the exhaust.
it was the exause fuse. it was giving me a code from emissions.
Old Aug 20, 2009 | 09:40 AM
Shez's Avatar
That's what I just said.
Old Aug 20, 2009 | 12:19 PM
WaRRioR-StaTuS's Avatar
D I thought you were better then that lol
Old Aug 20, 2009 | 03:11 PM
dunit121's Avatar
no i can always use a good laugh at people that tell you rediclious things
Old Aug 20, 2009 | 09:40 PM
Cobaltss/TC's Avatar
Originally Posted by Terminator2
You brought up an interesting point actually. I dont believe the AC compressor cuts at WOT on this car. It does on most cars but I have not noticed it on this car.
Yes on the cobalts the A/C compressor shuts off at WOT
Once engaged, the compressor clutch will be disengaged for the following conditions:
• Throttle position is 100 percent for 10 seconds.
• A/C high side pressure is more than 2951 kPa (428 psi) and will reengage once the pressure drops below 2068 kPa (300 psi).
• A/C high side pressure is less than 310 kPa (44 psi).
• Engine coolant temperature (ECT) is more than 125°C (257°F).
• Engine speed is less than 475 RPM.
• Engine speed is 6,100 or more RPM.
• ECM or PCM detects excessive torque load.
• ECM or PCM detects insufficient idle quality.
Old Aug 20, 2009 | 09:46 PM
Dayta's Avatar
take a your fuses out, youll gain SO MUCH hp!
Old Aug 25, 2009 | 12:53 PM
  #36
jmiller15's Avatar
a buddy told me once that if I use melted salted butter instead of oil, my engine will last for ever and I will gain 5 Crank HP!
Old Aug 25, 2009 | 12:57 PM
  #37
CudaJoe's Avatar
R O F L. I can just imagine how smoothly those pistons move with all that SOLID butter in your car during a start up.
Old Aug 25, 2009 | 01:02 PM
  #38
Stamina's Avatar
What do you think the engine block heater's for?
Random kinda-related fun fact of the day:
The Russians have a nuclear submarine (the Akula class if I remember right) that uses lead as coolant. Every time they shut down the reactor, the lead solidifies in the system and they have to heat the lead up in the coolant lines to liquify it again before they kick on the reactor again.
Old Aug 25, 2009 | 01:06 PM
  #39
CudaJoe's Avatar
I dont think an engine block heater would work lol. not to mention the butter would be grittier than 5w-30.
Old Aug 25, 2009 | 01:25 PM
  #40
06G85's Avatar
To the guy who said you gain 10 hp...
Old Aug 25, 2009 | 01:26 PM
  #41
Brian MP5T's Avatar
Ban!
Old Aug 25, 2009 | 07:01 PM
  #42
Baron7700's Avatar
did you know that every sticker is 5hp!?
Old Aug 25, 2009 | 07:13 PM
  #43
dunit121's Avatar
oreli?
Old Aug 25, 2009 | 07:15 PM
  #44
Dayta's Avatar
this is my new favorite thread
Old Aug 25, 2009 | 07:19 PM
  #45
mrsilent13's Avatar
talking about muffler bearings...apparently they are real in the toyota world...or was it volkswagen.....one of the 2 if not both actually have a part called a part called muffler or exhaust bearings.
Old Aug 25, 2009 | 07:30 PM
  #46
ItalianJoe1's Avatar
Usually it's a rubber hanger or something, but it gets lost in translation to english and just becomes a "bearing". Seen that before.
Old Aug 25, 2009 | 07:46 PM
  #47
Shibito's Avatar
I took my Direct Injection Pump fuse out and solved all my fueling problems.
Old Aug 25, 2009 | 07:49 PM
  #48
fredds-turbaltSS's Avatar
D why did you even try this?>? Did you think it would work? Anyway this is going to be a great thread!
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
jmelton327
Sep 26, 2015 10:04 PM
