Quick! Need a replacement coupler! What size do i need?
Old May 29, 2012 | 08:31 AM
ford's Avatar
Exclamation Quick! Need a replacement coupler! What size do i need?
Damn coupler blew the side out as soon as i went to pass a car. I want to order one ASAP instead of waiting to get home as it will ship a day sooner if i do. Can anyone tell me what size the opening on the ZZP intercooler is(same as stock opening i know)? 2.5"?
I think the coupler blew out the side because the body shop mounted my new intercooler a little off center after the wheel in the road claimed the last one, and the coupler was pulled a bit to the side because of it. Guess ill have to get un-lazy and move the intercooler to center now.
Thanks!
Old May 29, 2012 | 08:26 PM
Fastgti69's Avatar
Most likely is a 2.5 but if you can find 2.75 or 3" it would be better cause you technically can tighten the **** out of it... the L silicone right?
Old May 29, 2012 | 08:37 PM
ford's Avatar
Nah a straight piece off the intercooler end. I ordered 2.5 as it was the best information i could find doing a search today. Everyone was referring to clamp size in most posts.
Old May 29, 2012 | 09:01 PM
FasterIsBetter's Avatar
2.5", you may have to switch clamps. I know I was blowing off the lower charge pipe and upper charge pipe. I switched to stock clamps and had no more issues.
Old May 29, 2012 | 09:02 PM
Oh never mind. It rubbed a hole in the side of it, but yeah, 2.5"
Old May 29, 2012 | 10:02 PM
silverbullet08's Avatar
Get the exact size which is a 2.5 I believe. If you get a larger one and try squeezing it down you will end up with a boost leak. Send me a text BTW so we can get everythign set up!
Old May 29, 2012 | 11:10 PM
ford's Avatar
Will do tomorrow, I got distracted after work today. Sorry.
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Oct 1, 2015 08:17 PM
