Rumbling during NLS?
Old May 27, 2011 | 09:49 AM
DerekDTP!'s Avatar
When stock.. NLS is awesome.. I nailed it perfect almost everytime.. Only on the track lol, too much is bad, now tuned.. Its another story.. I only do it 3-4 and sometimes 2-3, but only when needed.. Times that involve faces to be raped
Old May 27, 2011 | 09:57 AM
SuperchargedSS's Avatar
This is why I would never buy a used TC or SC...
Old May 27, 2011 | 10:22 AM
vahdyx's Avatar
but a used beat up girl is okay for some reason. most have been driven pretty hard by now.
Anyway I think there's a risk in everything you buy new or used, but yes I agree with you. I wouldn't want a used Evo ever.
Old May 27, 2011 | 11:10 AM
RiceCop's Avatar
I have this problem also, something to do with the higher boost levels I think. I can NLS fine 1-2 and 2-3 and 3-4 off my tune (in stock mode). Tune active, I can NLS perfect 1-2 every time, 2-3 misfires every time. I've tried shifting sooner, later, faster, idk what it is but it won't work. I just don't do it anymore, the turbo spools up quick anyway if you shift fast.
I say higher boost levels because first gear is still stock or close to stock on trifecta tunes, and i can still NLS 1-2 fine on the tune. Only the higher boost gears are a problem.
Old May 27, 2011 | 01:26 PM
CrystalRedSS's Avatar
Originally Posted by sundevil07
Nls at 6k on the tach, on and off the clutch as fast as possible. Don't miss the gear, it ain't hard
Exactly what he said. I NLS right at 6k and blip the clutch. Its pretty easy to do. Just don't do it going from 1st to 2nd.
Old May 27, 2011 | 01:46 PM
MastaShaKe_88's Avatar
so tune or no tune, stock plugs are bout the best?
and do you have to be smooth wih the clutch or jus pop it in an out?
Old May 27, 2011 | 01:48 PM
Gremlin85's Avatar
You want stock AC Delco plugs or the NGK equivalent. Some have had success of going a step colder and gapped tighter when tuned.
And you want to be really fast with the shift. No need to be smooth. IN and OUT as fast as possible.... that's what she said.
Old May 27, 2011 | 03:16 PM
AndrewSS/TC's Avatar
NLS'ing seems to be smoother than lifting when shifting in my car at least.
007Buff
Jun 11, 2017 03:04 PM
Hugger1975
Oct 15, 2015 03:28 PM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
The Rookie24
Aug 27, 2015 09:18 PM
