And So It Begins - Another ZZP Engine Swap
So my built engine will be here next week, I decided to take a few pics of the progress and start slowly pulling the car apart. A lot of you know the stock engine pretty well blew on me and spewed coolant and oil everywhere out of the valve cover which I had VTA at the time since my MPx catch can would not work with my ZZP turbo kit at the time(I figured out a different way to run it and just filter the output on the catch can). I ordered new fuel pipes and a lot of gaskets. I am sure I will need more gaskets that I am forgetting but I will just order them as I go. I never had any issues with my VVT or the solenoids but we will find out if the coolant in the oil affected them. If so, I will order the solenoids as well as the actuators. I ordered the ZZP Engine with the forged bottom end, neutral balance shafts, ati underdrive balancer, ported head/cams combo with the upgraded fuel lobe....pretty well the works. Only thing I did not do is have ZZP assemble my top end which I assumed would take a bit longer so I just told them to send it to me with the bottom end assembled and I would put the engine in time it as I already had a new timing chain and etc. from where I had planned on ordering their ported head/cams in the past.
NEW GASKETS, INJECTOR SEALS, FUEL LINES, THERMOSTAT, AND ETC.
FRONT END DISASSEMBLED FOR THE MOST PART AND INTAKE MANIFOLD/FUELING SYSTEM REMOVED
PARTS WITH EXTERIORS CLEANED WITH BRAKE CLEANER AND ROUGHLY ORGANIZED IN A PLASTIC PAN
TREADSTONE MBC (So I can adjust the boost a lot easier)
i guess id need all new gaskets and those 2 fuel lines if i change it eh
It's not bad. You can probably get the head off in a couple hours. If you support the motor and take the passenger side motor mount off it makes it easier. It's probably a lifter your hearing. Take the valve cover off and investigate. Take the cam bolts out to take the chain off. Then just pull off the gears. It's the easiest way because you have to have the gears off to put the chain back on.
Yeah, I was gonna order the big pack of filters from CED but I ended up ordering from GMPartsEast. I can never get the factory filter at the local parts stores and have used the Mobil1 in the past with no issues, but I'll try to grab one. I'm guessing you are saying that due to the filter density for better oil flow.
Anybody got any pics of the tensioner on the car? I want to see where it is when installed. I've seen the broken pics of them when they're out of the car.
If I were you, I'd inspect your rockers, replace all your lash adjusters, and maybe replace/inspect your timing chain tensioner as well. You wouldn't need any new gaskets and I bet one of those is your ticking issue.
what would be awesome if someout did a whole taking off the head, and even replacing pistons and rods writeup with picks and post it. that would be awesome. but ya thanks guys for the info will help tons
If I need any extra gaskets I'll order some filters. Odd that I never heard of this issue. If I don't need anything else I'll just get a K&N, Fram, or try looking again for the AC Delco factory filter
i think i have pics from my build as well i had a machine shop assemble my bottom end though
and its easier to just match the links to the color and markings on the actuators
i followed the diagram i found on the site and went from there
FasterIsBetter - I'm stoked!! Just like what 40rty stated - 2012 looks like a good year for you, me and everybody else!!
I had a customer 3 weeks ago, who had the Mobile1 oil filter and the "nipple" broke off, he was lucky too, I found the nipple in oil filter "cup".. We stopped ordering them, we now use either AC/Delco or K&N..
