Sputtering under boost
Old May 19, 2015 | 11:17 AM
Jordan93's Avatar
About a month ago my 09 LNF randomly started sputtering and bogging down under boost. I'm hearing a sputtering crackling noise from my exhaust and losing a lot of power. If I stay on it for a couple seconds, it'll keep sputtering without being under boost for a few seconds while the CEL blinks. I don't have a scan tool so I replaced the spark plugs but it didn't help. Any idea what else it could be?
Old May 19, 2015 | 11:44 AM
What codes set?
Old May 19, 2015 | 12:18 PM
Sl0wbaltSS's Avatar
My brother's lnf started doing this, he took his opel injectors out and one was broken lol.
Old May 20, 2015 | 02:42 PM
Jordan93's Avatar
Originally Posted by ECaulk
What codes set?
Had it checked at autozone, no codes showed. Guy there suggested boost leak or hose collapse.
Old May 20, 2015 | 02:51 PM
Its weird that there are no codes.
If the cel is blinking that means that the ecu is disabling at least one injector to save the cat from getting too much fuel. Which essentially means you have a major misfire. Could be single cylinder or coule be multiple.
Old May 20, 2015 | 03:05 PM
Agreed that its weird, if the CEL blinks something set, even if the light doesnt stay on
Old May 20, 2015 | 03:08 PM
brycerice13's Avatar
Yeah ignore my post, I don't know what I was thinking here. I was looking at another persons boost leak issue, and started to read this and think it was the same issue.
Old May 20, 2015 | 03:14 PM
Jordan93's Avatar
Tuned
Old May 20, 2015 | 03:20 PM
Have someone run a data log to see more in detail what is going on with your car. I think that would be a good start.
Old May 21, 2015 | 09:42 PM
09CobaltSS1's Avatar
Originally Posted by brycerice13
Might be the wastegate sticking open that is why you are hearing the sputtering. Then maybe not pushing the correct amount of metered air into the engine.
I'm sorry, but this is straight up incorrect. IF the wg was somehow stuck open and limiting boost completely, this would not cause some massive amount of misfire like the OP is experiencing. Further more, it's silly to somehow assume that IF the wg was in fact stuck open, that this would also somehow equate to unmetered air passing into the engine. These are 2 completely different scenarios, neither of which are likely happening.
It's absolutely a misfire issue. I can almost guarantee there is at least a pending P0300 stored in there.
Old May 22, 2015 | 10:39 AM
Jordan93's Avatar
Got my own OBDii adaptor yesterday and used the Torque app with it. No codes showed. (No code showed for my aigbag light either)
Old May 22, 2015 | 10:49 AM
Did the autozone guy reset the codes?
Old May 22, 2015 | 10:56 AM
Also whats your plug gap set to? and I know its painful, but you'll have to make the CEL blink again then pull the code shortly after it goes off. Also if you can log with the torque app look at timing, knock, and misfires
Old May 22, 2015 | 11:01 AM
Some scanners don't show pending codes. Some will only show mature (active) dtc's.
Old May 22, 2015 | 04:58 PM
Jordan93's Avatar
Got it figured out. The new plugs I put in were NGK which I didn't gap. They turned out to be at around .038-.039ish. I checked the gap on some new AC Delcos, made sure they were .032, and those fixed the problem.
Old May 22, 2015 | 05:53 PM
Yeah thats a little big (the 0.038/9) glad you've got the issue fixed.
Old May 22, 2015 | 06:45 PM
Thank goodness you didn't start futsing with the stupid waste gate. Lol
Old May 22, 2015 | 06:56 PM
Old May 22, 2015 | 07:10 PM
So he was getting spark blow out pretty much
Old May 22, 2015 | 08:04 PM
That's more of less what it boils down to.
Old May 22, 2015 | 08:10 PM
Jordan93's Avatar
Really glad it was that and not something more complex. I'm always afraid I'll screw something up when digging deep into mechanical work. One less thing to worry about.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
