Stock boost solenoid
Old May 16, 2012 | 02:15 PM
paintballerr78's Avatar
Im wondering with an after market turbo kit how do you hook up lines to the stock boost solenoid. Im just trying to run my wastegate spring only and want to make sure i have it setup right..Thanks
Old May 16, 2012 | 02:21 PM
BLAZIN07SS's Avatar
I'm too JDM for you
if you are just trying to run wastegate spring only. run a vacuum line from your turbo to the side port on the wastegate and leave the top port vented to atmosphere
Old May 16, 2012 | 02:34 PM
I know I have an lnf and they have the electrical boost solenoid stock and im tryin to find out if i need to hook any lines up to that
Old May 16, 2012 | 03:28 PM
Frogstofall's Avatar
You talking about the wastegate solenoid? You can run the lines like Blazin suggested and then just plug in the solenoid but don't hook any vac lines to it. It does need to be plugged in so the ECU can see it even tho you're not using it.
Old May 16, 2012 | 03:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
just like frogstofall said. no lines need to be run into it. just connected electrically
Old May 16, 2012 | 04:21 PM
Dart_SI's Avatar
Theres 3 ports. 2 on the sides one on top of the port that is shiney goes to your boost source. The port on top goes to your wga. The 3rd port can be left vta, its the plastic black one. Make better sense?
Old May 16, 2012 | 04:28 PM
So basically how it does is one from the turbo goes as the boost source then the other goes to the wga?
Old May 16, 2012 | 04:34 PM
Dart_SI's Avatar
Yes. Run a line from the turbo to the front port and a line to the wga from the top port. The 3rd port just bleeds off air since its a boost confroller basically.
Old May 16, 2012 | 04:58 PM
FasterIsBetter's Avatar
The only time you need the boost control solenoid is when you want to control your boost via the ecm. If you connect the boost control solenoid to the wastegate you WILL need to be retuned as you were tuned before for a manual boost controller.
Old May 16, 2012 | 05:02 PM
What in the world are you talking about? Top port, side port, bottom port, inside port.
OP, if you have an aftermarket wastegate, you don't need to run the stock wastegate solenoid. It just needs to be plugged in.
Old May 16, 2012 | 05:52 PM
Alright ill try it without it plugged into an vacuum see how it runs...Now if i want to run a manual controller would i hook it up still as if the electronic one wasnt there
Old May 16, 2012 | 06:39 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Yes. You would still hook it up exactly like me and frogs said. The boost controller goes in that line in between the turbo and wastegate side port.
Old May 16, 2012 | 07:07 PM
Dart_SI's Avatar
I guess i misunderstood the question.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
