top speed with trifecta tune?
Old Apr 27, 2009 | 02:46 PM
  #51
cardelino18's Avatar
Originally Posted by red06SC
You did not go 162mph stock, if you did your speedo is 7mph fast
the thing with the speedometer being off by a couple of miles is because the speedometer reads the speed that your tires are going... but oviously the wind will slow you down wich the speedometer wont read it... its just like pressing the gas on 2nd gear and you see your speedoter hiting 60mph in less than 2 secs... wats not reading is that the tires are sliping and you are actually not going that fast.... same thing with the wind.... but like someone said that the f1 hit 240 and someone read the car was going 220... its because of the wind... if im doing 162 im not going to loose 7 miles... ill loose about 3 or 4 miles...
Old Apr 27, 2009 | 02:54 PM
  #52
Ferretts's Avatar
Originally Posted by WickedSS2005
Funny, GM has the computer set to 155mph in the TC tune's I've seen. The SS/SC was set to 158mph. Either way, no need to get to that speed. unless you are on a private track. If the spedometer stops at 160mph, how can you tell if it really was 162 legitamitly w/o a gps triangulation. It wasn't.
You can go by the rpm and do alot of math
  #53
Terminator2's Avatar
Huh. The speedometer on this car seems to be slow on the acceleration or deceleration. Wind will slow you down or make you a little faster but the speedometer will read those changes unless you happen to be spinning the tires.
Old Apr 27, 2009 | 02:58 PM
  #54
Ferretts's Avatar
Originally Posted by G Speed
176mph with a trifecta tune, and a rev limiter at 6300pm
/thread
He is right.. if you can hit 6300 rpm in fifth gear you are going 176 mph... do not try and gimmie all this bullshit with the wind and blah blah, its ******* math. Stop judging your car by your inaccurate speedos...
BTW if anyone was curious, if you want to reaach 200 mph in a ss/tc, you need to be going 7200 rpm in fifth, on stock tires. with a 235/40/18 you only need to hit 7115
Old Apr 27, 2009 | 03:03 PM
  #55
Your math is correct However.
My point is has anyone actually recorded that speed because I believe we need almost 400 whp to rev 5th gear all the way to 6300 which is indeed 176 mph. The drag on our cars at that speed is enormous. Mine feels like it slows down quite a bit once I shift to 4th at 111 mph or so. Wind resistance is a bitch up high. I was not doubting that math. i just doubt that a 280-300 whp TC can acheive those speeds.
Old Apr 27, 2009 | 03:08 PM
  #56
Ferretts's Avatar
Notice how i said if your car can reach those speeds... Im not saying it can because i have not had the abilty to test it out myself, but that will all change soon once i get my trifecta tune and other goodies... i am hoping to see at least 170, and to be able to beat a 360 challenge stradale from a 40 roll
Old Apr 27, 2009 | 03:13 PM
  #57
170 might be attainable if you take the wing off the back. The problem is that most tuned TC s loose a lot of power after 5800 or so. That will limit you some. If you make it to 6K that is 167 in 5th. IDK. My cars goes pretty damn fast but I dont have the ***** to push it to those speeds on public roads.
Old Apr 27, 2009 | 04:23 PM
  #58
i do:P
Old Apr 27, 2009 | 04:39 PM
  #59
Otown07's Avatar
Damn, if you're experiencing wheelspin at the top of 5th, don't get the Trifecta tune 'cause you already have close to 1900 hp.
Factory speedos are not perfect. They are good enough to get it down to +/- 2 or 3 mph, and error gets greater as speeds rise.
Old Apr 27, 2009 | 04:53 PM
  #60
madlion's Avatar
your speedo on your dash is inaccurate.. put a gps unit inside and take a picture of 162mph you will get better responses
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
