Tranny problems!!!! (2008 w/39,000 miles)
Old Jun 21, 2011 | 11:15 AM
zdoc's Avatar
Just so you know to wheel bearings are covered under powertrain warranty, even though thats not what it is.
Old Jun 30, 2011 | 07:26 PM
NDCOBALTSS's Avatar
There Replacing EVERY bearing in the Transmission!!!!! they have had it for like 2 1/2weeks now!!! there taking forever but there putting in my clutch for like 50 bucks so its ok!
Old Jun 30, 2011 | 07:41 PM
JacBlackSS/TC's Avatar
idk where the noise in my car is coming from
i am going to replace my flywheel with a new stock one to see if that helps
but i get a whirling noise when the clutch pedal is out when i press it in it goes away
then every now and then i get a whining noise as well
Old Jun 30, 2011 | 10:04 PM
ronn's Avatar
Prolly the tranny.
Old Jun 30, 2011 | 10:08 PM
god well i am gonna have to wait to get it looked at i am gonna change the fluid to see if that helps for now and switch back to the stock tob i have been told if the noise goes away with the pedal pressed in then its the tob i doubt my trans went up in like a few weeks i literary got the clutch installed and it started making the noise a week later and then the car sat at the dealership for two months
Old Jul 1, 2011 | 02:21 AM
SSlobalt's Avatar
Originally Posted by ronn
Prolly the tranny.
Say it with me, ronn.
Old Jul 1, 2011 | 12:25 PM
IsItFast?'s Avatar
If it was ONLY when ROLLING it's not the tranny or clutch. Those will make noise at a standstill as well as rolling.
They would make noise if it was the input shaft or related bearings/gears. If its on the output shaft it will not make noise when stopped because it only spins when the wheels turn.
Originally Posted by FasterIsBetter
Probably the bearings on the output shaft or the diff.
This is what it is. My first transmission started making this same noise at around 40k miles, it was the output shaft bearings. However they couldnt get the parts to fix it, so they put a reman transmission in. Which had 3rd gear shatter and punch a hole in the case less than 30 days and less than 1000k miles later and GM voided my warranty at this time.
Can't beat that. I had the dealer install my excedy hyper single when they had the first transmission out, they charged me $100 - I was glad to pay that, even though it took almost no time to install because it saved me a BUNCH of time to install.
Old Jul 4, 2011 | 04:55 AM
KrustyKrab's Avatar
So I was expecting a tranny story... As in a man dressed as a woman.
Old Jul 4, 2011 | 04:40 PM
Shanedude's Avatar
2 1/2 weeks!? The 50$ clutch deal does not make up for the wait period.
Old Apr 1, 2012 | 05:09 PM
SC_redline_SS's Avatar
im having problems with the output shaft bearing on the drivers side. gm has replaced the original transmission already and the second one is grinding again from the driver side. Has anyone had this problem?
Old Apr 1, 2012 | 05:21 PM
  #36
Powell Race Parts's Avatar
many clutches, exedy for one, and I have no idea about KY, make rattling noises, its a total pita. Not saying thats your problem.
Old Apr 1, 2012 | 06:24 PM
  #37
FF_ace's Avatar
My spec rattles
Old Apr 1, 2012 | 07:21 PM
  #38
1SLOLT1's Avatar
I'm having this same issue now! 29k miles
Old Apr 1, 2012 | 07:34 PM
  #39
Switt23's Avatar
$20 says it's the carrier bearing. I busted mine like a year and a half ago. 30k miles on it being bad and all it does is make noise.
I plan on pulling the tranny this summer, but it has never affected driveability.
Old Apr 2, 2012 | 11:11 AM
  #40
Bluekid99's Avatar
my car now whines here and there but its very noticable when driving and starting to drive however dont hear it at idle so im guessing the wheel bearing? bc if its the tranny ill flip ive only had the car 2 months
Old Apr 5, 2012 | 12:25 AM
  #41
Shanedude's Avatar
That sucks they won't install a LSD for you. Keep buggin them it's worth it.
Old Apr 5, 2012 | 11:31 AM
  #42
1SLOLT1's Avatar
They said that there was no way they have had this question come up in the past and they werent able to do it.....
bigdeertz
Nov 17, 2016 09:41 AM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
