Tranny problems!!!! (2008 w/39,000 miles)
There Replacing EVERY bearing in the Transmission!!!!! they have had it for like 2 1/2weeks now!!! there taking forever but there putting in my clutch for like 50 bucks so its ok!
idk where the noise in my car is coming from
i am going to replace my flywheel with a new stock one to see if that helps
but i get a whirling noise when the clutch pedal is out when i press it in it goes away
then every now and then i get a whining noise as well
Prolly the tranny.
god well i am gonna have to wait to get it looked at i am gonna change the fluid to see if that helps for now and switch back to the stock tob i have been told if the noise goes away with the pedal pressed in then its the tob i doubt my trans went up in like a few weeks i literary got the clutch installed and it started making the noise a week later and then the car sat at the dealership for two months
This is what it is. My first transmission started making this same noise at around 40k miles, it was the output shaft bearings. However they couldnt get the parts to fix it, so they put a reman transmission in. Which had 3rd gear shatter and punch a hole in the case less than 30 days and less than 1000k miles later and GM voided my warranty at this time.
Can't beat that. I had the dealer install my excedy hyper single when they had the first transmission out, they charged me $100 - I was glad to pay that, even though it took almost no time to install because it saved me a BUNCH of time to install.
im having problems with the output shaft bearing on the drivers side. gm has replaced the original transmission already and the second one is grinding again from the driver side. Has anyone had this problem?
$20 says it's the carrier bearing. I busted mine like a year and a half ago. 30k miles on it being bad and all it does is make noise.
I plan on pulling the tranny this summer, but it has never affected driveability.
my car now whines here and there but its very noticable when driving and starting to drive however dont hear it at idle so im guessing the wheel bearing? bc if its the tranny ill flip ive only had the car 2 months
Iceberg
Sep 29, 2015 12:33 PM
