Transmission question
Old May 20, 2011 | 11:18 AM
MajorCB's Avatar
so I wanted to canvas the group on what you've experienced with your stock tranny's and clutch... to me, and maybe this is just me... but when I shift, under fairly normal driving conditions, especially 1st thru 3rd, it seems like when the clutch grabs, there is sometimes some of that clanking between the tranny and the motor.. are any of you getting the same thing? just not sure if this is normal to the car... or if maybe this needs to be looked at... I just dont think there should be so much noise during shifts..
I have no upgrades on this other than the GMS1 and a Forge Coming..
thanks!
Old May 20, 2011 | 11:29 AM
504redcobaltss's Avatar
doesnt sound normal. get the dealer to look at it
Old May 20, 2011 | 12:07 PM
vahdyx's Avatar
my clutch grabs a little early in second as well and from what I understand we have a loud engaging transmission and the clank you hear is normal
but I'm just repeating what I read because when I first got this car I had all sorts of noises I wasn't used to and asked. all were apparently normal
Old May 20, 2011 | 01:21 PM
cmcphi1195's Avatar
I just started getting the noise a few weeks ago. Or at least noticing it. Its only when you press down on the clutch though or if I let off the gas while in 1st gear. And it only lasts a second. Almsot sounds like a rattling or kinda grinding slightly? Im not sure its anything serious. But wouldn't hurt for us to get it checked out
Old May 20, 2011 | 01:47 PM
MajorCB's Avatar
yeah.. its not overly bad I dont think... but it just seems loose... and perhaps there is a built in flexibility?? the clutch itself doesnt really make any noise... its definately directly located metal to metal tranny to engine.. but it occurs during the process of when the clutch plate pressure increases when you let out the clutch... usually at slower speeds.. less than 25mph.... acceleration.. deceleration.. reverse.... but when I get on it... it goes away..
Old May 20, 2011 | 01:55 PM
northvibe's Avatar
the linkage is cables...so its loud and can be clanky... Unless this is the inner workings of the clutch. could be the throw out bearing...
Old May 20, 2011 | 03:03 PM
MajorCB's Avatar
anyway to make those cables quieter?? hahaha
Old May 20, 2011 | 03:40 PM
RomeDiggy's Avatar
Mine does that too, it's a single clunk sound when the clutch engages. It's done it ever since I've had it, I now have 8100 miles on the car.
Old May 20, 2011 | 04:35 PM
northvibe's Avatar
no its cable linkage, my MS3 did it, the SS and the Cruze.... ah the fun
Old May 20, 2011 | 04:59 PM
brainchasm's Avatar
Good to hear this is fairly normal, because I notice it sometimes, and it makes me cringe a little.
Especially since I did the front and rear tranny mounts, and it makes me think I did something wrong, or they're getting loose, or something.
Old May 20, 2011 | 07:10 PM
tomj77's Avatar
thanks!
clunking or nauchy (spelling?)
Old May 20, 2011 | 11:38 PM
Mike_peperni's Avatar
Mine do it since day one, or two... and im at 38000km still do the same, a bit louder than new though...
Old May 21, 2011 | 10:00 AM
MajorCB's Avatar
Rome,
Since I am not fully sure if you tuned for the Hahn catted DP, have you noticed any issues with your car? .. have you Dyno'd it at all? the impression I get is that without a specific tune for that addon, you won't be getting 100% of the performance gains... but what I wondered is, if you had the GMS1 first, then the catted DP, did you notice a performance difference once you put it on? if so how much..... any CEL issues after you did put it on? just curious...
thanks!
Old May 21, 2011 | 10:02 AM
MajorCB's Avatar
Thanks to everyone for the replies... I think its a good enough consensus that this seems to be a fairly normal issue... I kinda wonder if a shift kit would be something to look at to tighten this thing up... but I don't know of anyone that makes one that's quality and smooth for the Cobalts...
anyone?
Old May 21, 2011 | 11:04 AM
SSlobalt's Avatar
Shift kit? Those are for automatics.
Old May 22, 2011 | 02:33 PM
MajorCB's Avatar
As I have both a Manual and a Auto.. sometimes the brain just doesnt wanna seperate the two haha..
Old May 22, 2011 | 02:53 PM
mongorat427's Avatar
Mine was making a little noise like that going into 5th gear. The syncro finally blew into little pieces Warranty covered it. 1500 miles on the car
Old May 22, 2011 | 03:03 PM
MajorCB's Avatar
syncro huh?.. interesting... what happened when it blew? could you drive it still ? or was it a tow job...
Old May 22, 2011 | 03:44 PM
gotboost?17's Avatar
Nothin Stock
how often should we do a tranny flush?
Old May 22, 2011 | 06:39 PM
reefone's Avatar
my trans make a little clanking noise upon letting out the clutch into 2nd and 3rd. only if im going slow like mentioned. when im wot its fine.
Old May 23, 2011 | 06:39 AM
It was still drivable because 5th gear is in a little area by itself on the end on the trans. Sounded like a popcorn maker though
Old May 23, 2011 | 09:51 AM
RomeDiggy's Avatar
Rome,
thanks!
I have not had any issues or CEL. I put it on after GMS1, there is an increase in mid to top end but will have more power if it were tuned for. Sorry but no dyno, I guessing I have 275-280 Whp.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
