Try this again.
Old Feb 4, 2012 | 07:43 PM
cmiller8006's Avatar
Try this again.
Got the ZZP fifth injector hooked up and wired in. Also a couple other things I did. Next will be the fuel pump and some retro headlights, and finish the lowering springs as well. Will post everything in here as it comes.
Injector done
Boost controller in cab, and you can see the fuel controller at the top of the pic.
Old Feb 4, 2012 | 07:44 PM
ssyellow's Avatar
Very nice sir.
Old Feb 4, 2012 | 08:10 PM
Maven's Avatar
This bitch sprays fuel? **** I thought it was meth for some reason
Old Feb 4, 2012 | 08:15 PM
LOL. yes it sprays fuel
Old Feb 4, 2012 | 08:17 PM
Maven's Avatar
I saw the line taped into the pressure port and I was like wait a minute........
Old Feb 4, 2012 | 08:40 PM
BlkWdoSS's Avatar
Interesting location for the boost controller, is it a push/pull type knob so that it locks into place? Could wreak havoc if you mistakenly turn the boost up with your leg.
l8r,
PD
Old Feb 4, 2012 | 08:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
clean work as always
Old Feb 4, 2012 | 09:20 PM
l8r,
PD
Yes it pushes in and out.
Old Feb 4, 2012 | 09:22 PM
Thanks, got a couple little things to clean up still.
Old Feb 4, 2012 | 09:40 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Those are good boost/pressure controllers. We use them at work on all the machines. Very reliable. Some of them don't stay locked as well as they used to... but most of those are like 10 years old and have been adjusted 10-20 times a day, every day since installation. So like 36,000-75,000 times.
Look forward to seeing what you can do with the car this year.
Old Feb 4, 2012 | 10:40 PM
Matt M's Avatar
We typically use them on E85 cars, so meth wouldn't really do much. It could be set up in a meth kit pretty easy for gas cars cars, though.
Old Feb 4, 2012 | 11:03 PM
jonathan923's Avatar
nice work! goal numbers?
Old Feb 4, 2012 | 11:29 PM
Really if as long as it remains the same power. I would like to be around 550 but the big thing is not having to switch fuels all the time. Would like to run 10's which at 550 that would be easy as long as it stays together.
Old Feb 4, 2012 | 11:39 PM
Matt M's Avatar
Should be pretty easy. I got there on a poorly prepped track. With my cars best 60' and hitting the high boost switch a little sooner, I would have been looking at 10.60s. The trick is not getting kicked out of the track before you put down a good run.
Old Feb 4, 2012 | 11:55 PM
Frogstofall's Avatar
That's what she said...
Sorry I had to.
Please post more pics as you continue.
Old Feb 5, 2012 | 02:36 AM
nhanson's Avatar
This means you wont have to worry about carbon build up
Old Feb 5, 2012 | 10:48 AM
mongorat427's Avatar
Anyone try one of these yet ? 77mm 6 pin off a V6
Old Feb 5, 2012 | 11:21 AM
Luckily on our TNT and amateur nights they are very cool about things. There's hardly any tech.
Old Feb 5, 2012 | 11:23 AM
[QUOTE=mongorat427;6319230]
I seen that in another thread but I don't think anyone uses one. I have the 2.4 TB on mine.
Old Feb 5, 2012 | 12:52 PM
[QUOTE=cmiller8006;6319261]
Ha Ha Right you got it off me
Old Feb 5, 2012 | 01:24 PM
[QUOTE=mongorat427;6319446]
Yep lol
Old Feb 7, 2012 | 10:53 AM
Got the Aeromotive stealth pump done. Only took one pic so here it is.
Old Feb 7, 2012 | 02:45 PM
Ryan@zzp's Avatar
Looks good cmiller! Enjoy!
Old Feb 7, 2012 | 03:12 PM
RooTBeeR's Avatar
in for slips
Old Feb 7, 2012 | 03:29 PM
RoadconeTuning's Avatar
10.6@140+???
