Tune Maybe? Knock!
Old Aug 22, 2013 | 02:52 PM
Kbbalt's Avatar
Thumbs down Tune Maybe? Knock!
So lately i have my interceptor setup to watch knock, And im seeing a good amount of it... It freaking me out, Im pretty sure when i first got it tuned I didnt have any..
So Wot I'll get 2.9 and it will stay up there until i get off. the other day i did a WOT pull in 4th around 4.5k and i got 4.0 Degrees of Knock.. Should i be worried? I have been riding around with the GMS1 tune for safety reason because that gets no knock.
Old Aug 23, 2013 | 11:54 AM
RYRO14's Avatar
Yes you should be worried, you need to get the tune looked at. Any knock is bad.
Old Aug 23, 2013 | 12:07 PM
Hockeyman's Avatar
Blends of fuel vary depending on the time of the year, could be why you're seeing knock. When were you tuned? Mods?
Old Aug 23, 2013 | 12:22 PM
does the nterceptor gauge need to be adjusted/dialed in to monitor knock correctly? some of the functions it shows do. just a thought before you jump to conclusions. but yes any real knock is bad
Old Aug 23, 2013 | 12:46 PM
umrdyldo's Avatar
switched to a higher grade fuel and see if it goes away.
If you can't go higher grade maybe drop in a gallon of E85.
You shouldn't see knock under WOT. maybe at part throttle.
If it doesn't go away with higher octane then you need tune adjustment.
Old Aug 23, 2013 | 01:56 PM
shroogis's Avatar
Were you getting it before, or all of a sudden? It could be the fuel. I'm getting some inconsistent KR at WOT on my LNF Trifecta tune...Usually 2.9* as well! I can do a pull from 60-120, not 1* of KR. Slow down let the IAT2's cool off, do a 4th gear pull @ 4000 rpm and get KR at 4500-5000. The tune is only commanding 13.5* up top so it's not very aggressive and I'm hoping it's just poor fuel.
Old Aug 24, 2013 | 12:18 PM
Kbbalt's Avatar
Sorry guys i dk, imma try new plugs and everything.. Here is a vid... May just need a retune.. and baby it until then
Old Aug 29, 2013 | 09:40 AM
Kbbalt's Avatar
Alright so I brought some Torco and added to my tank... No Knock... I hope its just bad gas. I used Shell like always too!
Old Aug 29, 2013 | 09:50 AM
user 72239's Avatar
I seem to get knock at WOT when its really hot outside. when its colder I get no knock. plus it jumps around. It could be false knock.
Old Aug 29, 2013 | 10:13 AM
shroogis's Avatar
Try different gas and if it still knocks you'll have to send a log to Vince and he will pull out some timing. The tip in is somewhat normal, but I saw where the KR came in part way through the pull and that's real KR.
Old Aug 31, 2013 | 09:59 AM
Damn, I only get some knock/false knock at low rpms but goes away as soon as i get into the throttle more.
Old Sep 1, 2013 | 05:59 AM
08baltSS's Avatar
About Knock Retard (KR) | ZZP News
Read this^ It's most likely false knock because, from what I read, real knock would have made kr go up as rpm goes up. Never hurts to look into it though.
Old Sep 1, 2013 | 09:00 PM
user 72239's Avatar
Yeah, its knocks bad at WOT when its 90+ out. its false knock though, but I'm still cautious
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
