Tuned maintenance
Old Jan 26, 2010 | 10:54 PM
  #51
LE5_AJ's Avatar
bump and sub'd for a good thread so in a nutshell plugs will help substatially about every 3 or so oil changes
Old Jan 26, 2010 | 11:05 PM
  #52
Kildore's Avatar
Bump for further news
Old Jan 27, 2010 | 12:24 AM
  #53
austinss's Avatar
Anyone got the part number for the stock plugs, I can't seem to find it.
Old Jan 27, 2010 | 08:48 AM
  #54
wantedSS/TC's Avatar
They're posted 58 times on the forum mang. Search lol
Old Jan 27, 2010 | 05:49 PM
  #55
austinss's Avatar
I have, maybe I'm looking in the wrong spot.
Old Jan 27, 2010 | 06:02 PM
  #56
Black08SSTC's Avatar
Originally Posted by BYT*SS*TURBO
After the WB02 died at 22K and now the 2nd change of plugs as well....
Looking like running a strong tune will require you to change WB02's at 20K and plugs at 10K intervals. Ive found the O2 sensor on GM Parts Direct for $60 (PN: 12589380 for 09's, prolly the same for 08) And the Plugs are about $5/each on GM Parts. I don't have that PN tho, sorry.
When the WB02 went out, the car had a rough idle with a FAINT sound of a boxer rumble to it. Replacing it made that go away but it still stumbled a tiny bit at idle. I replaced the plugs again (had been ~10K) and gapped them to .030. The car idles perfect now, incredibly smooth and very quiet as well!!! Try a tighter gap tuned guys
I drive about 100 miles a day a minimum, in 6 months Ive put 22K on the car. 20K of it was tuned lol! Anyone else putting this many miles on their tuned car? And finally, is anyone else finding anything similar to what I am???
careful!! you might get banned for supporting GMpartsDirect.com Let alone you and I support another forum in our sig!!!
Old Jan 27, 2010 | 07:48 PM
  #57
rukkee's Avatar
My car is dry as a bone on the outside...oil wise. I didn't think i had anything leaking till i pulled on the sound deadening material on teh HP fuel pump..... It was saturated with oil . I would have never guessed I had an oil leak .... that foam was sucking it all in .
Old Jan 27, 2010 | 11:17 PM
  #58
tomj77's Avatar
iv looked at the foam, it has some on it but that i splashed on it when i filled the oil, but im gonna take a closer look just in case.
****, on closer inspection i do have a little bit of oil soaked dirt under there. not much though, i cleaned it and ill keep my eye on it. does gm have a proper fix for it yet? or someone link me to the thread with instructions on how to do it right so i can give it to my dealer
Old Jan 28, 2010 | 12:09 AM
  #59
SSlobalt's Avatar
Look in where the oil filter is, then just above it. I had some oily residue there and eventually a puddle by the oil filter.
Mine had it. That's where I first noticed it. My dealer kept trying to blame it on my oil changes. They finally put dye in my oil and found out that I was telling them the truth and that they were ignorant. Why won't these damn dealers listen to us?
Old Jan 28, 2010 | 12:24 AM
  #60
tomj77's Avatar
i just found the best delailed insructions with pics on how to fix that leak and the fuel pump oil leak, check it out
www . localcobalt . net / forum / do-yourself-how-guides / 4028-how-repair-lnf-cylinder-head-oil-leaks.html
remove the spaces, it didnt let me post it
Old Jan 28, 2010 | 01:41 AM
  #61
SSlobalt's Avatar
I read that post a long time ago. That's how I found my oil leak to begin with. I even showed the post to my service adviser. He still thought I spilled the oil myself. Idiots.
Thanks for posting the link though.
btw: lol that you can't even point to a url of this site.
Old Jan 28, 2010 | 01:45 AM
  #62
1badBlueberrySC's Avatar
11k miles 10k miles were tuned....
o2's have been fine, plugs are fine.... but I am going to replace them with a stage colder her shortly...
fuel trims well.... need constant attention now... LOL
Old Jan 28, 2010 | 07:19 PM
  #63
tomj77's Avatar
i called my dealer today see if they can fix it, they said all they can do is replace the sensor, they can only do what gm allows. so its usless taking it to them to do under warrenty, cause they wont fix it. id do it myself but i dont want to have to buy new stupid fuel lines on the high pressure fuel pump.
Old Jan 28, 2010 | 08:14 PM
  #64
Iam Broke's Avatar
NGK 6509's are 1 step colder Iridiums. 6510's 2 steps colder boosty boy. I've been running the 6510's for a loooong time now at 25 psi with no issues. Still look great after about 10k miles.
Old Jan 28, 2010 | 08:37 PM
  #65
tomj77's Avatar
i wonder how those would do on stock tune? id like the one step colder for my tune, but im usually on stock tune, would they work?
Old Jan 28, 2010 | 10:11 PM
  #66
NME's Avatar
NME
I hope you never get married
Old Jan 28, 2010 | 11:53 PM
  #67
tomj77's Avatar
whats that supposed to mean
Old Feb 24, 2010 | 01:02 PM
  #68
pookie025's Avatar
on gmpartsdirect i tried to order the plugs and it comes up as a quanity of 8 and the price is 62 dollars...wtf why not like thirty. can we just buy them from like autozone
Old Feb 24, 2010 | 01:27 PM
  #69
cmiller8006's Avatar
The dealer maybe I think I asked Autozone and they didnt have them. Go on Amazon and look I got 8 NGK 6509's for 32.00 shipped and there brand new.
Old Feb 24, 2010 | 01:33 PM
  #70
Rissa's Avatar
Got 2 new O2 sensors woo!
Old Feb 24, 2010 | 01:37 PM
  #71
06black's Avatar
from what i've checked into hun, replace the 2nd unit first. if you can, leave the primary in place.
if the 2nd unit cleans things up, the primary should become error free. unless it is jacked up.
i know youve gotta move the old ones out, but if you can, this would be a way to easily check things out.
people, adding in the upper EGT lamda adder will have a huge effect on 02 life. not all of it, just some.
Old Feb 24, 2010 | 01:38 PM
  #72
badbaltguy's Avatar
great thread! BYT,, i got my new MAF sensor finally...
Old Feb 24, 2010 | 01:41 PM
  #73
Rissa's Avatar
Thanks.
Old Feb 24, 2010 | 01:50 PM
  #74
fredds-turbaltSS's Avatar
06BLACK are you saying the problem is the 02 sensor in the down pipe? Not the WB02? everyones replacing the WB02 are saying thats fixing there problems?
Old Feb 24, 2010 | 01:55 PM
  #75
06black's Avatar
i never said that.
there are various DTC checks in the system, the range of error is greater on the secondary unit. thus it could cause an issue thats reported from the primary sensor.
this is what i'm being told here, i dont do controls work.
