Tuned maintenance
Old Jun 4, 2010 | 08:09 AM
  #151
TurboTechRacing's Avatar
Originally Posted by BYT*SS*TURBO
ewwwwwwwwwwwwwwwwwwwwwwww
Seafoam purchase on my way home...YUP!
X2 me too
Old Jun 4, 2010 | 08:39 AM
  #152
glhs379's Avatar
Already got my seafoam can ready to go!
Old Jun 4, 2010 | 09:42 AM
  #153
tom.g's Avatar
Originally Posted by rukkee
I've noticed that my car afterfires alot more now that the weather has gotten humid and sticky . When i shift out of 1st to 2nd it sounds like an SRT-4 lol snap crackle pop! . Every once in awhile i will get a loud pop after letting of the throttle ..... like a full blown backfire ...... the motor is almost at an idle like if your just coasting to a stop after giving 1st a run up to 4K rpm .... or if your shifting really slow to 2nd...... then POP! . My LTFT's get worse with the humidity .... its at -7.1 today. I've only seen positive fuel trims one time since ive owned my car...... right after i Seafoamed it .
I'm wondering if I should throw a set of plugs in her .... I'm at 10K miles and 8K have been on a Superchips tune . I've seafoamed her twice and I can't believe how bad it smoked .... the carbon build up on these Direct injected cars must be nasty . I often wonder if the intake valves stick a little sometimes cause the exhaust note with change out of no where and sound boggy . Some of the braver members should pop the intake manifold off and take a look at the valves .... then we might know how they are holding up to gunk build up 8)
Here is a pic i found of a DI motor with 22K miles on it
Mine does the snap crackle and pop just like yours in slow 1-2 shifts and easing of the throttle at around 4k. Mine only started doing it once I put my catless downpipe on so i figure it's normal.
Old Jun 4, 2010 | 10:02 AM
  #154
cubaniche's Avatar
I may be in the engine this weekend, Ill try to remember to take some pics. So, one can of seafoam will clean ALL of that gunk off or what?
Old Jun 4, 2010 | 11:08 AM
  #155
rukkee's Avatar
Originally Posted by Stamina
I'll do it one better. 2009 SS/TC, 15,000 miles, Shell gas only, and oil changes every 3,000 miles. These pics are from a local member on here...
Kinda makes you think about getting a catch can, huh?....
Yep lol..... I was looking at Catch Can's last night and wondering where i should put it . I'm going to take the trap off the bottom of the intercooler today and see if there is anything in there.
If the intake valves are that bad i wonder what the throttle body looks like ??
Yep i'm sure it's because of the cattless DP but mine has been getting progressively worse as time goes by ..... must be the stock Resonator and muffler are wearing in and unable to keep it quiet anymore.
I don't know if one can will do it or not .... I've seafoamed my car twice in 10K miles and it smoked just as bad the 2nd time as it did the first . I wonder how often is too often with seafoam? Cause i just did it two weeks ago and would really like to do it again but dont want to over do it.
Its funny .... my car smoked like a bitch in the driveway for a good 5 minutes ..... and then kept smoking for about 5 miles down the road . I honestly thought i hurt the car and it was burning oil cause it wouldn't stop smoking lol.
Old Jun 4, 2010 | 11:29 AM
  #156
BYT*SS*TURBO's Avatar
I wonder the same on using it over and over! Anyone?
Old Jun 4, 2010 | 11:32 AM
  #157
What does the can say, how often to use?
Old Jun 4, 2010 | 11:33 AM
  #158
FF_ace's Avatar
ive used it twice on my car and i have 28k on it everything is running great for me
Old Jun 4, 2010 | 11:44 AM
  #159
cubaniche's Avatar
Okay, so I guess one can cleans ALL of that heavy gunk out or gets enough of it out that the car runs better.
Old Jun 4, 2010 | 12:11 PM
  #160
Stamina's Avatar
I'm still trying to figure out how this stuff is going to clean those valves off. It's not like you're rubbing them with this stuff.
Old Jun 4, 2010 | 12:21 PM
  #161
cubaniche's Avatar
Thats the same question I have.
Old Jun 4, 2010 | 12:27 PM
  #162
It steam cleans from the inside if Im not mistaken
Old Jun 4, 2010 | 12:31 PM
  #163
glhs379's Avatar
Uses the heat from the warm motor to clean the crap off that's why it says to do it when up to op temp and let it set for awhile to dissolve
Old Jun 4, 2010 | 12:32 PM
  #164
cubaniche's Avatar
Cool! So I can give Stanley Steamer a call too then lol
Thanks for the info. Okay, I can kinda see how that would clean the valves.
Old Jun 4, 2010 | 12:36 PM
  #165
1badBlueberrySC's Avatar
I have never used the seafoam stuffs... but am going to give it a whirl.... excuse my newbstyle question but where the hell do you pour the **** in for the vacuum line...
I know some goes in the oil, some goes in the gas, but what vacuum line do you use???
Old Jun 4, 2010 | 12:42 PM
  #166
Any that's direct to the IM I believe. I will prolly be pulling the line going to the BPV Solenoid and use that!
Old Jun 4, 2010 | 12:50 PM
  #167
Rissa's Avatar
I don't know why I'd be afraid to sea foam this car. I sea foamed my camaro and it was fine, but for some reason I'm scared to do this one lol. I probalby need spark plugs too...28k miles and they've not been changed.
Old Jun 4, 2010 | 12:54 PM
  #168
^Im with you! I know it will be for the better but Im def nervous to try it lol!
Old Jun 4, 2010 | 12:55 PM
  #169
Yeah.... Nick you still rockin stock plugs in your car? Or did you change them up to the 3787s?
Old Jun 4, 2010 | 12:58 PM
  #170
Im running the XP5263's right now. I just ordered another set of stockers to have around. So far I see no difference running the Autolites!
Old Jun 4, 2010 | 01:00 PM
  #171
stock gap? or closed in im at 14,500 miles and still on the stockers!!
Old Jun 4, 2010 | 01:05 PM
  #172
cubaniche's Avatar
Yeah Im running the same ones. Dont see any difference. Gapped at .34. Just a wee bit less than stock.
Old Jun 4, 2010 | 01:06 PM
  #173
I run them at .030. Ive been sticking with stock each plug change this time I wanted to swap them before going to the track and no dealers had them. I figured this was a good time to try a diff plug lol
Old Jun 4, 2010 | 01:08 PM
  #174
i was thinking in the .30 to .32 range... im thinking its time to take them out
Old Jun 4, 2010 | 02:15 PM
  #175
Terminator2's Avatar
It has solvents in it that are supposed to break up deposits. My CPs are clean and dry inside and my TB was pretty clean at 20K miles. I cleaned the TB with carb cleaner and it was cleaner than my GTO's TB was at 6K miles LOL. It is a PITA to clean the TB on this car.
