Walbro 400lph Fuel Pump?
Old Apr 14, 2012 | 08:31 PM
gone_in_10_sec's Avatar
Walbro 400lph Fuel Pump - does anyone have one installed or currently using one now?
Old Apr 14, 2012 | 08:40 PM
tomj77's Avatar
What would u need one for
Old Apr 14, 2012 | 09:09 PM
SSlobalt's Avatar
For 700 hp.
Old Apr 14, 2012 | 10:35 PM
tomj77's Avatar
ahh lol
Old Apr 16, 2012 | 11:32 PM
I'm going to order it on friday.. I'm hoping to install it before LNF mod day..
Old Apr 17, 2012 | 02:04 AM
FasterIsBetter's Avatar
Didn't burn up the aeromotive pump did you?
Old Apr 17, 2012 | 02:05 AM
nope just wondering if the walbro 400 pump would provide more fuel on demand when using e85/90 mix..
Old Apr 17, 2012 | 02:13 AM
And I believe you need a pump with the center inlet. I don't think the walbro is offered in that so you'll have to modify your sending unit/fuel pump assembly.
Old Apr 17, 2012 | 02:14 AM
I was wondering cause I'll buy the aeromotive off of you otherwise, lol!
Old Apr 17, 2012 | 02:16 AM
i think the corvette pump assembly is similar, i wouldn't know until i get to work tomorrow.. lol..
most likely im keeping the aeromotive pump for now.. until then i'll try the walbro pump and see if it works with or without modifying the pump assem..
Old Apr 17, 2012 | 09:37 AM
The corvette fuel tank module isn't going to work, b/c the white module "cap" [fuel tank door] is too small, but I found the next best thing to work..
The closes one to fit the Walbro 400 FP is a 09-11 Equinox/Torrent Primary Fuel Tank Module.. the module will fit right inside the Cobalt tank.. there is only one problem - on the Equinox/Torrent there is a right side fuel pickup line for the right side tank.. [it's a single tank but the drive shaft hump turns the tank into a dual tank setup]
The fix: Is to either swap out the Equinox/Torrent white module cap with the Cobalt white module cap or
seal the second pickup line with sealant and cap off the outside second pickup line as well..
Also the really neat thing to this setup is the fuel tank module can be also used as a dual fuel pump setup as well.. it has a second pump "seat" for the second fuel pump inside the module "white can"..
Old Apr 17, 2012 | 09:42 AM
Gremlin85's Avatar
I love information like this!
Thank you!
Old Apr 18, 2012 | 10:55 AM
Thank you!
no problem, just thought it would be neat to share..
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
