what vin digit shows lsd?
the VIN doesnt show if it has LSD or not. IF you do not have the window sticker..You need to open the trunk, and look ath the parts indentification sticker in the back. It will have codes like 34U (rally yellow) for example. Once there, locate G85 for the LSD code.
* 1st character - Identifies the country in which the vehicle was manufactured.
For example: U.S.A.(1or4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
* 2nd character - Identifies the manufacturer.
For example; Audi(A), BMW(B), Chrysler(C), Dodge(B), Ford(F), GM Canada(7), General Motors(G), Honda(H), Jaquar(A), Lincoln(L), Mercedes Benz(D), Mercury(M), Nissan(N), Plymouth(P), Toyota(T), VW(V), Volvo(V).
* 3rd character - Identifies vehicle type or manufacturing division.
Chevrolet(1), Pontiac(2), Oldsmobile(3), Buick(4), GM Overseas(5), Cadillac(6), GM Canada(7), Saturn(8), GM Overseas(9), Chevy Truck (C), GMC Truck(T)
* 4th character - Identifies the restrain system.
Non-passive(A), Automatic belts(B), Inflatable restraint(C)
* 5th character - Identifies the series.
Chevette CS trim(B), 2WD Truck(C), Cavalier base trim(C), Cavalier CS trim(D), Cavalier type 10(E), Van(G), Citation(H), 4WD Truck(K), Chevette base trim(J), Impala(L), Camaro Sport Coupe(P), Step Van(P), Caprice Classic(N), Camaro Berlinetta(S), Small Pickup(S), Malibu(T), Malibu Classic(W), El Camino(W), Celebrity(W), Citation(X), Monte Carlo(Z)
* 6th and 7th character - Identifies the body style.
Landau Coupe(03), 2 dr Coupe(08), 1/2 ton(10), 2 dr notchback Coupe(11), 4dr Sedan(19), 3/4 ton(20), 1 ton(30), Sport Coupe or Convertible(27), Station Wagon(35), Sport Coupe(37), Sport Coupe(47), 2-1/2 ton(50), 3 ton(60), 4-1/2 ton(65), Convertible(67), 4dr Hatchback Sedan(68), 4dr Sedan(69), 2 dr Hatchback(77), Sedan-pickup(El Camino)(80), Sport Coupe(87)
* 8th characters - Identifies the engine.
* 9th character - is a check digit to verify VIN accuracy.
* 10th character - Identifies the model year.
For example: 1981(B), 1982(C), 1983(D), 1984(E), 1985(F), 1986(G), 1987(H), 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T), 1997(V), 1998(W), 1999(X), 2000(Y), 2001(1), 2002(2), 2003(3)
* 11th character - Identifies the assembly plant for the vehicle.
Lakewood(A), Baltimore(B), Lansing B(C), Doraville(D), Linden(E), Flint (Chevy)(F), Framingham(G), Flint (Buick)(H), Janesville(J), Kosai(K), Leeds(K), Lansing(M), Norwood(N), Pontiac (Pontiac)(P), Detriot(Q), Arlington(R), St. Louis(S), Ramos Arizpe(S), Tarrytown(T), Hamtramck(U), Pontiac (GMC)(V), Fairfax(X), Wilmington(V), Fremont(Z), Wentzville(1), Oshawa #2(1), Moraine (T&B)(2), St. Therese(2), Detroit (T&B)(3), St. Eustache(3), Orion(4), Bowling Green(5), London(5), Oklahoma City(6), Lordstown(7), Shreveport(8), Fujisawa (Japan) Luv(8), Detroit (Cadillac)(9), Oshawa #1(9), Pontiac (GM Truck)(0)
* 12th to 17th characters - Identifies the sequence of the vehicle for production
as it rolled off the manufacturers assembly line. Starting with 100001.
^VIN doesn't state LSD option. You will have to look in the trunk.
axle codes are still not in the VIN. Older cars they on the right axle as you look at the car, newer cars will have it also marked in the door or located in the same place we are sending you! Never has been in the VIN
yes i get the point moron, thanks. this is for a car about 300 miles away, i can't much teleport over there, grab any numbers i need and teleport back.
and older cars also have it in the engine bay as well, usually on a manufacturer's label, along with the vin and engine codes.
The lable in the trunk is called a spid (Standard Production Identification) label. It has all the RPO (regular production options) your car was built with. So yes call the guy and verify that RPO G85 is listed. All those cryptic 3 number codes refer to somthing the car was built with including the paint code.
By the way if i remember right we made G85 standard in 09 I believe. It was only an option in 08 on TC's
Unfortunately its still an option. It should be standard IMHO.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
agentirons
Oct 16, 2015 02:11 AM
importkiller
Sep 30, 2015 07:18 PM
