Whats your oil?
I put whatever the hell the dealership puts in there... I actually need to make an appointment & take it up there for them to change the oil out! I hope they use Mobil 1 Fully Synthetic 5W-30 (or whatever our cars recommend).
Mobile super syn 0W-30 the high gas mileage type that meets or exceeds GM spec (4718M IIRC) for our cars. I am going to give the Castrol Edge oil a try next itme. In lab tests. It had 8X the wear resistance of Mobile one!!!
Yep. Walmart sells it 5 quarts for $24 or so. It meets or exceeds the GM spec for our 5W-30 not just any 0W-30 will work though. Thinner oil has less friction on cold startups and it will get slightly better gas mileage because of the reduced oil viscosity. Nothing major, but I like the cold start protection factor in the winter.
definitely. that ams oil is the SH*T. you should use the 0 weight. you can go 20,000 before changing, and they even send you a kit to take an oil sample.
everyone should check out Amsoil.com. Royal purple is good, Amsoil is BETTER.
it may cost around $70 for an oil change, but you don't have to do it as often
I use the 5w30 mobile 1 syn extended from walmart, its the cheapest around here in the 5 qt jug. But yeah ^^that castrol edge has grabed my attention and im a lil interested in how it compares.
okay so what kind oif filters are you using? im just usings the acdelco's rt now since they are kinda oem and real easy to get. thought about going with K&N. I've heard of some of the other filters/glue coming apart. So whats everyone like?
same thing for me!!
