whp estimate
hate to bring it up again, but my mods have changed slightly. Just want to get a whp estimate please from the people who know what they are talking about.
Mods:
Trifecta/HP Combo Tune 24psi, no spikes above 25psi
AEM Cold Air intake (new version)
ZZP Upper Charge Pipe
AIS Meth Kit, Steel Lines, 100% Meth, tune adjusted for proper timing (plus 94 octane gas)
ZZP Magnaflow Catted Downpipe
Muffler Delete
350whp?
388wtq?
Thanks.
Mods:
Muffler Delete
350whp?
388wtq?
Thanks.
I'm gonna say 320whp and 365whp. A guy around here has full bolt on minus the intercooler with a trifecta 24psi tune and he only hit 275whp and 325wtq on a dynojet.
This is all speculation OP until you DYNO. Doooo iiit
The OP is running meth WITH a 24psi tune man. He should def be around 335-345whp at least. Something is def wrong with that guys numbers you mentioned. Im on a 24psi tune with full bolt-ons and I dyno 325whp. Shoot, I dynod 295whp on my 20psi tune last year.
Different dynos read differently. Maybe the one you used was out of calibration. Look at your graph, was it STD or SAE? STD is usually a little higher. To compare with other results from other dynos, you should use SAE. Temp, altitude, humidity all affect the dyno reading. Don't get hung up on dyno numbers, the dyno is just a tuning tool.
Thats my car that he's talking about, and yea back in October I did a pull, and it hit 325 WTQ which seems to be pretty accurate, but the WHP was only 275 as mentioned, which didn't make much sense to me. Don't know whats going on, because as mentioned i'm fully bolted minus intercooler and 24PSI Trifecta.... I thought i'd atleast be 300WHP. Have to see in the spring again.. Maybe I'm doing something wrong on the dyno? Haha..
Thanks for the input.
336hp without meth, I might get 350 then.
It's not just a trifecta tune, it's a combo tune.
Could of gone catless, but felt is was too loud with muffler delete.
Plus, have seen guys with cats not having much of a hp difference at all.
jcalvin1126
Sep 11, 2015 10:24 AM
