wisco pistons
Old Apr 24, 2011 | 10:01 PM
gtsr100's Avatar
wisco pistons
was just wondering how meny people had them. mine are in the car just have to do the timing on it also all i replace was the pistons rod bearings and arp head studes was wondering what kinda break in stuff i should do like oil miles that kinda stuff thank you all. oh i have pics of the build just need to get off my lazy ass and get them off my phone
Old Apr 24, 2011 | 10:31 PM
Zander916's Avatar
I'm getting ready to put in those pistons myself. I've done quite a bit of research on this very subject.
Everything that I've found says to follow the break-in given by the manufacturer of the car. I found one case where someone contacted Wiseco about it and posted the conversation. Wiseco said the same thing - "Just follow your vehicles given break in procedure".
The ONLY added cautions that I was able to find was that it's more important to adhere strictly to this break-in AND that for the life of the car to make absolutely sure it's fully warmed up before you drive it hard.
Reason being is that with a Forged process they still have internal tension within themselves and it takes quite a few heat cycles for them to relieve this internal stress. If you don't follow these rules they can go "out of round" and seize up. As for the second part they tend to shrink and expand more with heating and cooling (compared to the stock cast pistons) so if you thrash them when they are still a bit cool there's more slop and you can really bang them up until they get hot, expand and kind of tighten things up.
That's just what I've found in all my research.
Old Apr 24, 2011 | 10:50 PM
gtsr100's Avatar
why thank you sir mine are in just have to do the timing of the car witch is a bitch
Old Apr 24, 2011 | 10:54 PM
Zander916's Avatar
Yep no problem. My car is currently down. It's a slow process but the block is getting machined and I'm getting a pretty good deal so they can take their time. I won't hassle them.
Good luck with the rest of it! I can't wait to get back into mine.
Old Apr 25, 2011 | 07:31 AM
cmiller8006's Avatar
Timing really isn't that bad. Can be done in the car. Did you at least deglaze the cylinders? Run a contentional 5w30 penzoil or something for about 500 miles and take it kind of easy with boost but after around 150-200 miles go ahead and run it upto like 4000 rpm's and let it engine break back down to seat the rings better. Then start adding boost while doing it at like 4-500 miles, after 4-500 miles it is pretty much broke in. It really is broke in after the first few heat cycles, but I wouldn't just go hammering on it that soon.
Old Apr 25, 2011 | 08:40 AM
gtsr100's Avatar
just thought i would show them
Old Apr 25, 2011 | 08:47 AM
BLAZIN07SS's Avatar
I'm too JDM for you
nice work. but you replaced the cam cap bolts correct? they are torque to yield.
Old Apr 25, 2011 | 09:06 AM
RoadconeTuning's Avatar
use a good breakin oil, like brad penn, for the first few changes... first crank needs to let it get to operating temp, then change oil... then i'd change the oil after 10-50 miles and then at 500... after that you should be good... if you do break-in on the dyno then i'd say change oil after dyno tune and let it eat... even if its only got 5 miles on it.
Old Apr 25, 2011 | 09:17 AM
gtsr100's Avatar
we got rotela thats what we wher going to use
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
