zfr boosting sound
Old Apr 27, 2014 | 11:32 AM
tomj77's Avatar
zfr boosting sound
ok got all my issues with my car sorted out after zfr install. one little thing. when i start boosting to 23psi i hear a turbo fins slapping the air sound for a second, then it goes away. is that normal? doesnt do it in second, does it in 3rd, dont know about 4th. i looked up on youtube and saw one video with a regal zfr that does the same.
here is a vid of what it sounds like except mine is shorter and does it earlier
Old Apr 27, 2014 | 11:50 AM
Wert842's Avatar
Mine does it in 4th only. I've only just realized in the last week or so though.
Old Apr 27, 2014 | 01:19 PM
tomj77's Avatar
I checked again and mine actually does it exactly like the video. what is that? im wondering if the bpv is being pushed open and letting come of the boost hit back into the compressor wheel fins making that noise. cause it doesn't do it on lower boost, just high. and only for a bit then it stops.
anyone else have any insight on this? im getting bpv in a week or so from zzp, ill see if that makes a difference with block off plate on bpv hole.
Old Apr 27, 2014 | 04:08 PM
Wert842's Avatar
Ya idk it's weird. Looking at the vid and what not mine seems to do it right along the same rpms.
Old Apr 27, 2014 | 04:42 PM
alerosaint's Avatar
Mine does it as well
Old Apr 27, 2014 | 07:56 PM
08VRSS's Avatar
Who's doing your tuning. Mine does not do this at all.
Old Apr 28, 2014 | 07:00 AM
tomj77's Avatar
I doubt this is a tuning issue. Not everything comes down to the tune like Matt from zzp once gave everyone one crap for on here.
Old Apr 28, 2014 | 07:42 AM
08VRSS's Avatar
Actually a tune can cause this if you don't know how to tune the PID tables for boost, the ecu can be fighting the throttle plate and cause this. So yes, it can be the tune.
Old Apr 28, 2014 | 10:34 AM
tomj77's Avatar
Well I'll talk to trifecta and see what's up
But was just saying it could also be something else. I had this happen really bad when I had a large boost leak as well a few weeks ago
Old Apr 28, 2014 | 11:54 AM
alerosaint's Avatar
OP how much boost you are running?
Old Apr 28, 2014 | 12:00 PM
OzzyruleZ's Avatar
Sounds like the thing is hitting its surge line on the compressor map
"To simplify, on-boost surge is too much boost too early. However, this doesn't really define it properly. Surge is due to high exit mach numbers at the impeller so that for that given compressor wheel profile, the slip losses at the boundary layer lead to flow reversion that cascades in a resonant frequency, eg cha cha cha"
How big is your intake piping and IC piping?
Old Apr 28, 2014 | 12:20 PM
Wert842's Avatar
3" intake 2.5" ic piping.
Old Apr 28, 2014 | 12:31 PM
OzzyruleZ's Avatar
You guys using boost controllers or is it ECU controlled stuff? Just seems like this turbo is on the threshold for the surge line on the LNF.
Old Apr 28, 2014 | 02:18 PM
Wert842's Avatar
Ecu controlled.
Old Apr 28, 2014 | 02:26 PM
ECU controlled, the throttle blade most likely isn't open enough for the amount of air the turbo is pushing like someone already said
Old Apr 28, 2014 | 02:32 PM
OzzyruleZ's Avatar
Ah the woes of drive by wire.
Old Apr 28, 2014 | 02:41 PM
tomj77's Avatar
23 psi
Old Apr 28, 2014 | 02:46 PM
tomj77's Avatar
is there any way to make throttle blades open more to see if that solves it?
Old Apr 28, 2014 | 02:47 PM
Gotta take the bad with the good
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
Sep 27, 2015 08:53 PM
