ZZP Builds The Best LNF Mod Ever!
It might have been an exaggeration on their part, but you have to admit that most of your posts in our threads are in violation of the forum rules.
More importantly, what fuel system was on the car that you dyno'd in your post on the last page? What fuel?
Matt,
I’m getting what seems to sound like quite a bit of compressor surge between shifts. It might even be wastegate chatter? Any reason why the ZFR is doing that and how to quiet it down?
I would recommend watching the cam phasing under those conditions to look at the possibility of excessive valve overlap causing the problem. You could also make adjustments to the bypass valve table to allow the turbo to bleed off pressure sooner. It could be due to other components in the system as well.
Yes, and only to hate on zzp, never to actually engage in a discussion about whatever he brings up. I clearly attempted to discuss injection timing with him as it pertains to the setup he was tuning. Instead of participating in a discussion, he simply disappears until next time he feels like putting in a bad word for zzp. It's unfortunate because he would have some useful knowledge to add to such a discussion, but he chooses to act like a troll instead.
Valve overlap stays between 40-50. The flutter noise happens consistently after about 4 PSI with higher pressures just making the flutter louder. I don't remember hearing this noise before you tuned it. Not sure how to adjust the bybass valve table. Is it the nut on the wastegate you're talking about?
Well InfraRedline (Taylor) tuned my car today....E47 on 26 psi.....pulls very strong and he kept it a little on the conservative side just to be safe. Overall i am very happy with the tune and the car.
Christian,
If you're trying to become an authorized/reputable tuner - you're doing it wrong.
Bashing on one of the only few companies that actually support our community is not the best way to do it. It's better to play well, maybe PM them, figure out who/what is wrong/different between you two and then post USEFUL, not HATEFUL information.
Dear serega12,
First- I agree, and I had no intention to be hateful. Good job sticking up for the forum!
Second- I have no intention to become an authorized/reputable tuner, I'm not an expert nor good enough to do it. And there is no way I would make enough money tuning. This is just a hobby.
Third- I don't see how I was being hateful? I read my post 4 times, and I just don't see it.
Forth- I've tuned on a few ECU platforms, single, and multi carburetor setups and worked with experts from 80 year old tuners to the engineers that develop future ECU systems. The one thing I've seen everybody do when they find a parameter that makes a little power, is tune for that parameter. That kinda worked in the past when ECU had one map that it always used. But these Bosch DI ECUs have multiple maps for different injection/power modes that all share some parameter tables. Tuning for these ECUs means going back to the basics and starting from scratch testing every combination of changes. But I'm not an expert and probably don't know what I'm talking about.
Fifth- I have purchased ZZP products and enjoy them, although I wish they communicated better, but I'm sure they are very busy and I probably just feel through the cracks.
Sixth- I enjoy and appreciate GMTechs posts they are often filled with great information, superb questions, and an amount of intellectual cynical bitterness that reminds me of Oscar Wild. Wish he replied to PMs also... maybe my PC is broken...
Seventh- GMTech might be a little bitter on this forum, but I can't blame him. I'd be bitter if my posts got pulled and I got sent the same message he did. On the other hand a little tact when posting on vendor threads is a good policy. But someone has to question vendor claims and results or we'll just have $50 single wire "black boxes" that "add 80hp and 20mpg" like eBay does.
Eighth- This forum does get a little immature at times, sometimes it's funny, sometimes it's irritating. This is probably a result of the age group differences between Cobalt SS, HHR SS, and Kappa Sol/Sky owners. I just learned to skim the BS for the bits of good info that's hidden in the mix. This is my example: https://www.cobaltss.net/forums/2-0l...harger-283313/
Ninth- I can't believe I wrote this long of a reply... I really don't care this much!
Tenth- 10 seems like a nice round number to finish on, so lets all put on our big boy and girl pants and stop taking things so F#cking personally!!! This is the internet remember!!
Thank you for your time,
--Christian
Dear serega12,
--Christian
--Christian
I think the answer should be, "Roll the dice and find out."
