ZZP Builds The Best LNF Mod Ever!
Old Nov 2, 2011 | 01:44 PM
  #1076
FasterIsBetter's Avatar
Originally Posted by Matt M
That's not required until 500+ whp on e85 or 550+ whp on gas if you have our fuel pump lobe. Either way, we sell the 5th injector as well. Send me an email or pm if you want one.
Glad I know all we need is a PM to get one. I wasn't sure if we'd have to visit you guys to get one or what. But I have thought about making a run up there come spring break. Prob have my efr in by then tho even if it isn't from you guys, no offense to you all. I'll need a trans anyways....lol...
Old Nov 2, 2011 | 02:05 PM
  #1077
Matt M's Avatar
It's not like we are trying to keep secrets or something. It's just that most people can have there fueling needs met through other, easier options. We try to steer people in the right direction rather than just agreeing to sell them all sorts of extra parts that they don't really need. The best plan for someone looking to make more than 500whp is to work with us on a build. It's really not all that difficult to do anymore.
Old Nov 2, 2011 | 02:21 PM
  #1078
No, sorry if I came off that way. I just thought you guys had to do custom work on our cars to install the 5th injector. My biggest problem around here is I can't get e85 only 100 octane and thats 50 miles away. Closest station is 138 miles away. And thats what I'm getting at with the visit during spring break. My goal is to meet over 500 whp on the 100 octane safely. I probably won't need that 5th injector but if it means the difference between some fuel cut and no fuel cut then I'll get one.
Edit: just forget everything I said. I just remembered Sunoco 110 is sold at the track. I'll just fill up a 55 gallon drum when I want to stock up for those spring and summer midnight runs.
Old Nov 2, 2011 | 02:39 PM
  #1079
Damn I look stupid. Thats what sleep deprivation due to certain animals making noise will do to you.
Old Nov 2, 2011 | 03:42 PM
  #1080
donkeyballs's Avatar
Matt if i have you guys do the 5th injector will that be enough or will i need a upgraded cam? I just want to run full E85 none of this mixing bullshit..
Old Nov 2, 2011 | 04:39 PM
  #1081
40rty's Avatar
Same here, I would like to run 100% E85 as well. Now this larger lope on the cams, since it basically strokes the HPFP how is the wear and tear on it? How long have you guys had the pumped stroked for? No issues over time/predict?
Old Nov 2, 2011 | 04:54 PM
  #1082
Matt M's Avatar
I would recommend the cam over the 5th injector. The main reason is because all tuning can be done in the ECM, then. With the 5th injector controller, you need to tune both.
Old Nov 2, 2011 | 04:58 PM
  #1083
Matt M's Avatar
I am running a .070" larger lobe and pushing up to 8000rpm, and I have not had any issues. Customers that run .050" larger pump lobes and shift at 7200 should be fine for a long time. The roller is huge.
Old Nov 2, 2011 | 09:45 PM
  #1084
40rty's Avatar
looks like I might be ordering some cams then, now you guys mentioned that with the cams its best to get the balanced shafts, I'm running 91/E85 and would like to run 100%. Do I need those? I mean I don't know if I'm going to be going to 8k or more.
Old Nov 3, 2011 | 04:51 PM
  #1085
cubaniche's Avatar
Wait...let me get something straight. The larger HPFP lobe on the cam you guys offer will allow us to run full e85 on a bigger turbo that revs to 7k? I was under the impression that it only helped level out fuel demand on full e85 on the stock k04.
Old Nov 3, 2011 | 04:58 PM
  #1086
Matt M's Avatar
You don't need to remove the balance shafts for a setup you are shifting at 7k or a little higher. I do recommend valvesprings if you are planning to rev past 7k and running much past 20psi.
Old Nov 3, 2011 | 05:10 PM
  #1087
Matt M's Avatar
It depends on what fuel system limitations you are running into. The main issue with running E85 on the K04 is the high torque which means a high fuel demand at a lower RPM. Since the hpfp cycles faster as the engine speed increases, it has the most trouble keeping up near your peak torque rpm. Since switching to a larger turbo usually does not increase torque numbers, and it often decreases, it doesn't necessarily need any more fuel system mods. Of course with the EFR, you can achieve more torque than the K04, but the best thing is that you don't have to. You can make power all the way to 7500rpm, so there is no need to spike the boost higher at the start of the pull in search of a wide power band. Either way, the larger fuel pump lobe allows you to run E85 on a larger turbo. Here is a dyno chart from our testing on a S259 turbo:
Old Nov 3, 2011 | 05:20 PM
  #1088
cubaniche's Avatar
Great! I knew that the dyno chart was on a bigger turbo so I figured I was safe to buy the cams with the larger lobe, but the old description on the old website threw me off. Is it possible to get the larger lobe on stock profile cams or do you offer just the intake cam, stock profile+bigger lobe?
Old Nov 4, 2011 | 04:45 AM
  #1089
40rty's Avatar
roger that, springs it is
Old Nov 4, 2011 | 03:34 PM
  #1090
SKY888's Avatar
This is interesting.
Matt, do you guys ONLY sell the .050" larger pump lobe?
or do you guys also sell the .070" larger lobe?
so the dyno that you showed is for the .070"?
will there be any fuel starvation concerns if only running .050"?
thanks!
Old Nov 4, 2011 | 03:50 PM
  #1091
Matt M's Avatar
thanks!
The dyno chart showed the same size lobe as we sell. I continued to test higher lift, but eventually ran into a problem where there is too much fuel pressure in some cases so it throws a regulator performance code. That was the reason for keeping the cams we sell limited to .050" larger than stock. The factory lift is only .186, so adding .050" is a lot.(27% increase) If you added that percentage of lift at your valves, it would be the equivalent of taking a .400" lift cam and bumping it up to .507" lift.
FWIW, we got up close to 500whp on Scythe Snake's car before we needed any additional fuel from the 5th injector. He is running the .050" larger lobe. I guess we could call it the 236 lobe for 236 thou added to the pump stroke.
Old Nov 4, 2011 | 04:10 PM
  #1092
SKY888's Avatar
thanks for the info Matt!
Old Nov 12, 2011 | 11:00 AM
  #1093
T CUPP's Avatar
when will this be avaliable for purchasing?
Old Nov 12, 2011 | 11:01 AM
  #1094
unijabnx2000's Avatar
1.99999 years
Old Nov 23, 2011 | 10:46 PM
  #1095
Miko's Avatar
Available now!
- EFR Bolt-in Turbo Upgrade #
Old Nov 24, 2011 | 01:35 AM
  #1096
matt638's Avatar
^ only for one person
Old Nov 24, 2011 | 01:31 PM
  #1097
Mike08ss/tc's Avatar
Originally Posted by Miko
for a good ol 4800 bucks. I can have my lsx block and heads for my fbody.
Old Nov 24, 2011 | 11:14 PM
  #1098
40rty's Avatar
Wow, looks good and all but $4800, yikes!
Old Nov 25, 2011 | 12:27 AM
  #1099
Matt M's Avatar
The price falls until it sells.
Old Nov 25, 2011 | 08:07 AM
  #1100
kennysabarese's Avatar
It's like backwards ebay!
