ZZP Cams and Valve springs installed!
Old Jul 16, 2013 | 09:01 PM
  #51
taintedred07's Avatar
Yea we're talking more from a general engine stand point, not specific to the turbo. I didn't even think about replacing the stock chain but that's a good point.
Old Jul 16, 2013 | 09:12 PM
  #52
Hockeyman's Avatar
Video is up!
Old Jul 16, 2013 | 09:34 PM
  #53
Dirty but sexy haha
Old Jul 16, 2013 | 10:17 PM
  #54
Wert842's Avatar
Damn that does sound good. Are you running a catless dp with what mpx catback set up?
Old Jul 16, 2013 | 10:40 PM
  #55
Yea, zzp catless dp and mpx catback exhaust with resonator and with muffler. It's deep and quiet which is what I was going for, opens up at wot though like any other.
Old Jul 16, 2013 | 10:45 PM
  #56
Fastgti69's Avatar
Hey Japeatr, what tool did you use for compressing the springs. I can't find it for the LNF engine, it's not the same as the LSJ correct?
Old Jul 16, 2013 | 10:58 PM
  #57
The kent moore ecotec valve spring compressor - this tool is universal for all the ecotecs I believe but I don't recall the part number. Can find on ebay for $100-200.
The lnf specific part is the timing bracket which holds the cam gear in place thus keeping timing. Japeatr had the lsj bracket, but not the lnf. That's why he had to re set the timing after installation.
Need Japeatr or Powell to clarify, but pretty sure for the lnf you need the ecotec vvt bracket, unless you want to go through the hassle of timing everything. Can find on ebay for around $30 I believe.
Old Jul 16, 2013 | 11:08 PM
  #58
JapEatr's Avatar
South Central *********
Kent Moore J-43649-1 for the valve spring compressor
Need to get the J number for VVT cam gears
Old Jul 16, 2013 | 11:19 PM
  #59
Fastgti69's Avatar
Thank you guys! Just getting everything ready. Mine will all be installed with a built motor in one month exactly!
Old Jul 16, 2013 | 11:42 PM
  #60
Nice! Whats the rest of your build consist of?
Old Jul 17, 2013 | 12:26 AM
  #61
Fastgti69's Avatar
I'm buying a motor that is already built, pistons, cyroed rods, sleeves and crank. I will be installing the cams and valvesprings along with fixing my issues with my 25g. The engine will come with LSJ tranny and the KY stage 4 clutch. I will have 3 different tunes, 91 and a e85 DD files(22-24 psi). And a special race file e85/110 mix 31 psi or so. I'm guessing fueling will be maxed out before this turbo is so yea. Sorry to thread jack.
Old Jul 17, 2013 | 12:39 AM
  #62
nhanson's Avatar
Ewww miller lite
Looks like everything is good!
  #63
It's all good man, I asked you lol could probably run a custom 5th inj with your race tune, but I'd wait and see how you'd do with the cams.
Old Jul 17, 2013 | 12:40 AM
  #64
Originally Posted by nhanson
Ewww miller lite
Not my first choice lol
Old Jul 17, 2013 | 01:06 AM
  #65
c130aviator's Avatar
Nice work OP and the other guys on the forum. Japeater and area have been around forever, its all about who you know.
Good stuff! You should have more than enough fuel for anything you can throw at it with the stock turbo. I mean Im not sure of the low end right when boost spikes on the stock turbo, but my friends LNF about maxed the fueling out with these cams on E85 on a 5557 and 26lbs at 476whp/432tq.
lsj is doing that with stock cams.
Old Jul 17, 2013 | 01:15 AM
  #66
Definitely
Old Jul 17, 2013 | 02:05 AM
  #67
Fastgti69's Avatar
That's the plan for now. 5th injector will be one like Gmtech on the throttle body. I have to look at his thread again but yea.
Lsj isn't direct injection, so it's not limited with fuel. We need cams for the lobe to supply more fuel. Or you can do the 5th injector which is meh... lol
Old Jul 17, 2013 | 02:25 AM
  #68
I know just rubbing it in. LOL, those LNF cams are a must.
Old Jul 17, 2013 | 09:52 AM
  #69
InfraRedline's Avatar
All his LNF was doing on stock cams and E47 on anything more than 22 lbs was getting injection window misfires Ran well up to that boost level, but aint nobody got time fo dat low boost! Brought it to ZZP when he was back home in Ohio and they put in the springs/retainers, cams, new charge piping, and fixed some boost leaks and put it on E85, so no more Bill Nye mixing at the pump with our non E10 91 octane and E85. Then they maxed out the fueling with the cams on his 5557 at 26 lbs. Runs great all the way up to 8k rpms, but he shifts at 7,400.
Old Jul 17, 2013 | 11:44 AM
  #70
Area47's Avatar
Rent me! per hour
you can run 24psi on e85 on a stock cammed lnf.
Old Jul 17, 2013 | 11:49 AM
  #71
On a 54 lb/min precision 5557 turbo?
Old Jul 17, 2013 | 01:04 PM
  #72
Area47's Avatar
Rent me! per hour
i didn't see that part. i was referring to the stock turbo. there is a slight hit in the fuel pressure in the midrange
Old Jul 17, 2013 | 02:10 PM
  #73
I figured you meant stock turbo lol. I wish I could get this local to get off his 26lb trifecta 91 tune and give E85 a try on HPT. But he is too stubborn. He says "I like map switching too much" No, you like the high boost setting, nobody likes the low boost setting lol
Old Jul 17, 2013 | 02:38 PM
  #74
Area47's Avatar
Rent me! per hour
tell him to stop being a **** waffle.
Old Jul 17, 2013 | 02:53 PM
  #75
I called him a curly headed f*ck. Not sure if it helped matters or worsened them, but it was said lol
