ZZP cams worth it?
Old Apr 23, 2012 | 08:46 PM
AARON-SS-TC's Avatar
i wouldnt do cams with a stock turbo..power/cost ratio sucks...lol
Old Apr 23, 2012 | 09:03 PM
gone_in_10_sec's Avatar
Originally Posted by JacBlackSS/TC
did you read the link i posted to the write up???
the increased cam lobe is needed to run full e85
but for regular 93 octane you don't
there were gains like i stated 30 whp by zzp on there car, not sure what was done to the motor but the turbo was stock
my bad, i should have been more clearer - i was thinking of changing the current ZZP cam setup and ZZP ported head setup to compare notes..
Old Apr 23, 2012 | 11:03 PM
JacBlackSS/TC's Avatar
no i was wrong the cams were totally different
Old Apr 24, 2012 | 07:00 PM
brainchasm's Avatar
My plan is to roll out to ZZP whenever the EFR is available, and do cams, springs, and turbo all at once, with a retune. And then go home.
Hopefully at 450+ whp.
Note to self: get clutch before all that
Old Apr 24, 2012 | 08:20 PM
blrt's Avatar
Good plan..
For anyone that get the S1 cams, they should do the spring at the same time with the fuel lobe of course. I am not sure how this combo work with the stock turbo, they make the most hp at the upper rev limit with a big turbo at 7k rpm.
Old Apr 24, 2012 | 09:40 PM
Knightwolf's Avatar
I have a ZZP ported head with stage 1 cams and it pulls hard up until around 6700 or 6800 on stock turbo.. it's actually still going, but I do know that it loses breath up there in 4th gear which says to me, it's losing it's power probably around 6500 or 6600. 2nd and 3rd though, it's still beastly
Old Apr 27, 2012 | 10:55 PM
Nfamous60's Avatar
^^ how fast is your boost dropping?
with the mods i hav i want to do cams springs and maybe get valves from performanceautowerks.com
Old Apr 27, 2012 | 11:11 PM
FF_ace's Avatar
I need the cams and cam phasers... I would like to know if zzp provides a new timing table
Old Apr 29, 2012 | 01:50 AM
Knightwolf's Avatar
I'll have to look next time, but I'm generally not concerned with boost. I do believe I was seeing around 18 psi at high rpms.. the tune runs 22 or 23 normally up until low 6k range, but to be specific, I'd have to turn on my boost gauge and watch it closely lol
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
