ZZP ECU Tune Dyno'd
Old Jan 14, 2011 | 06:36 PM
vahdyx's Avatar
ZZP ECU Tune Dyno'd
I got dyno'd today to see exactly what the ZZP ECU tune did for me and it's not to shabby. Take a look...
I did a total of 3 pulls and this is my best, all results were the same pretty much. I'll post the other 2 here in a bit. I don't think you guys would be interested in all pull documents. ****Edit**** Here's the link to my other pulls Clicky
If it's hard to see, 262WHP 371WTQ
Old Jan 14, 2011 | 06:39 PM
SOHC24powa's Avatar
mods? and is your clutch slipping?
Old Jan 14, 2011 | 06:40 PM
383_Stroker's Avatar
Good torque number... but where's the horsepower?
ripped's Avatar
Any mods or just tune
Old Jan 14, 2011 | 06:44 PM
vahdyx's Avatar
Just stock with k&n drop in
Old Jan 14, 2011 | 06:46 PM
blewis13's Avatar
nice torque numbers. Is the ecu onlly thing done to it?
08ssedan's Avatar
Damn thats a huge jump on torque, i wonder what happened with the hp
Old Jan 14, 2011 | 06:50 PM
SOHC24powa's Avatar
i put down 285/365 with ZZp's tune with a 3" pownpipe. vahdyx isnt really spiking, i have a 28# spike then its levels out to 22#'s. probably why my clutch is slipping lulz.
Old Jan 14, 2011 | 07:02 PM
sponge14's Avatar
You only have a tune and you're putting down 371ft lbs of torque?
Why is the HP so low compared to the torque?
I will admit right off the bat, I'm not into knowing everyone's dyno numbers with what mods, etc., but that seems like an unbelievable jump in power from just a tune.
Old Jan 14, 2011 | 07:15 PM
vahdyx's Avatar
I can't tell you why my tq was so high, but we ran it three times and all results were the same. Even my friends couldn't believe it until they saw the sheet. My friends that were there with me couldn't believe it either and asked if something was wrong with the dyno.
08ssedan's Avatar
Does it pull like crazy? Thats pretty huge going from stock torque numbers to that
Old Jan 14, 2011 | 07:23 PM
Stamina's Avatar
The HP isn't high because the torque drops way off up top. The torque drops off up top because the boost drops way off. So the question then is: Why does the boost drop way off? 16-17psi??
Old Jan 14, 2011 | 07:24 PM
vahdyx's Avatar
Well, to me it feels amazing zzp pcm tune amazing
From what ZZP told me is it's to protect the engine at higher RPMs
Old Jan 14, 2011 | 07:54 PM
rukkee's Avatar
Hmmm...... wonder if the dyno was set up correctly . That seems like a pretty big difference between HP and TQ.
Just noticed how quick the boost drops off ... that doesn't seem right . Losing 6psi between 3 to 5K rpm seems extreme.
Old Jan 14, 2011 | 08:03 PM
vahdyx's Avatar
Are you guys suggesting not only was my tune set up incorrectly (or boost leak) that the dyno is as well?
Old Jan 14, 2011 | 08:06 PM
umrdyldo's Avatar
Can't see how your clutch would hold together at 370wtq and 3k rpm.
Old Jan 14, 2011 | 08:13 PM
HunterKiller89's Avatar
everything looks fine to me. the only peiople who have suggested somethig might be wrong i feel dont understand what they are reading or maybe some of the calculations behind it
Old Jan 14, 2011 | 08:18 PM
Dr.Balt407's Avatar
that and the car is pretty much stock all he stated "if im correct" was a drop in filter and the tune....cant be mad at that.
Old Jan 14, 2011 | 09:19 PM
rukkee's Avatar
Well just speaking from experience .... I don't lose 6psi from 3000 rpm to 5000rpm on a pull .... so unless im reading that boost graph wrong thats exactly what the op's car is doing . I spike 22-23 psi and hold 20 well past 5k rpm
Old Jan 14, 2011 | 10:40 PM
vahdyx's Avatar
My boost may drop but if you look my hp stays the same throughout the gear. That's has to account for something
Old Jan 14, 2011 | 11:49 PM
kidcrash603's Avatar
My 24lb spike hold 21lb trifecta tune put out 289whp 320wtq with only Dejon piping and SRI.
I've seen results where there is a much higher tq number than HP and usually the tune needs further dialing in to make the power useful where you need it.
Old Jan 14, 2011 | 11:55 PM
beast10007's Avatar
not bad is that a dyno jet?
Old Jan 15, 2011 | 12:31 AM
gotboost?17's Avatar
Nothin Stock
nice number...but pretty weird
Old Jan 15, 2011 | 12:59 AM
ecot3c inside's Avatar
it would be a perfect world if HP=TQ wouldn't it?
Old Jan 15, 2011 | 01:00 AM
Stamina's Avatar
It always does... at 5,252...
