ZZP LNF Cam Testing
Yes, the S1 cams are only about 8-10 degrees over stock. The gains are not going to be huge. Of course if you need the larger fuel pump lobe, the gains can be much higher.
Matt, a friend of mine who runs his kappa on scca events.
In his division, he's not allowed to have a more aggressive cams.
He is having fueling issues though since he's using ethanol.
Is it possible that you guys supply him w/ a stock cam BUT with a BIG fuel lobe?
thanks!
Forty's car needs the extra fuel that is for sure. If I get super aggressive with his wg DC even at 6000 RPMs it drops rail pressure badly.
I forgot he got the stage 1 cams not the stage 2. Stage one should have a better powerband for his BNR 2871 setup. Even if he gains only 12 whp he will be at 370 whp on the stock turbo and an otherwise stock engine.
thanks!
thanks!
Alright,
So we finished the cams last night, here are some pictures taken of the whole process.
Cleaning the ZZP Cams before installing w/solvant
Preparing Valve Cover to be removed
Valve Cover removed and began working on disassembling HPFP
Common leakage of Oil in HPFP
One thing I wanted to point out was that the silicon(when opening the top portion of the HPFP housing) did not have sufficient amount to create good seal. Most likely contributing to the oil seen about leaking in the HPFP.
Stock Fuel Lobe
HPFP piston
Removing Stock Cams
Removed
New Cams in Place with Larger Fuel Lobe on intake cam
Stock Fuel Lobe
HPFP piston
Removing Stock Cams
Removed
Applied Silicon to make good seal with gasket and top of HPFP housing to the engine.
Re-installing HPFP
Timing Done
JOKES ON ME!
ZZP Stage 1 cams Saturn Sky Redline First startup - YouTube
Re-installing HPFP
. Timing Done
JOKES ON ME!
Stock cams. 4th gear punch at 2000 RPMs dyno dynamics load type dyno.
357.5 whp 409 wtrq, 24 psi on E-47.
Saturn Sky Redline dyno - YouTube
Cool man. Last question, when you ordered these did you order the standard stage 1 cams or the larger fuel lobe for $150 more?
