ZZP LNF Cam Testing
Old Mar 30, 2012 | 01:24 PM
  #451
Turbo Hearse's Avatar
Originally Posted by Terminator2
He has the larger fuel lobe.
Great. Thanks for the info!
Old Apr 8, 2012 | 09:08 PM
  #452
Okay, I've finally read this entire thread and I've got a few questions.
The dyno graphs that were in the very first post, are they a result of what zzp sells now or were they from prototype
grinds??
Second, the original dyno shows the torque curve basically following the boost curve. If the car had a flatline tune would the torque curve match it or is it a result of the cam grinds?
If the dunno graph is a reflection of what is being sold currently it looks like the cams could go even bigger but that's just me. Still a lnf noob
Old Apr 8, 2012 | 09:29 PM
  #453
Matt M's Avatar
The dyno testing was done on the s1 cams that we currently sell, but without the larger pump lobe that we offer.
Old Apr 8, 2012 | 09:36 PM
  #454
Matt M's Avatar
We should be doing a better dyno comparison soon. The tests need to be updated, because I didn't have much direction at the time these tests were done. It was more like brainstorming on a dyno.
Old Apr 8, 2012 | 10:49 PM
  #455
40rty's Avatar
Im already going to be compiling and posting some info with Term sometime this coming week. Realworld, real street drivingand dyno.
Old Apr 9, 2012 | 01:34 AM
  #456
I'd love to see a current dyno graph with the larger fuel lobe. Hopefully on a dyno sheet much like the first post because it shows engine speed, boost, torque and rpm
Old Apr 9, 2012 | 08:50 AM
  #457
Terminator2's Avatar
Hurry Up LOL.
Old Jan 22, 2014 | 10:50 AM
  #458
cw383's Avatar
Bump from the past, 40RTY, did you ever get to do your real world testing ( or anyone else ?) Planning on doing cams this spring.
Old Jan 22, 2014 | 02:44 PM
  #459
40rty's Avatar
I'd have to go through my logs again. Ill see if I can get some up.
Old Feb 11, 2015 | 10:13 AM
  #460
DaculaWeather's Avatar
Hey guys! New here but not to the motor! We're using the LNF in the autocross Jeep we drive, and the owner is now looking to go with the stage 2 cams. Vince did our first tune and I'm assuming the you (ZZP) and Vince probably already have a good tuning table for this setup (we use E85). I haven't seen any dyno runs of the Stage 2. We still have the stock turbo. We're going with the Stage 2 cams as well as valvesprings and retainers.
The car weighs 1760 lbs with me in it, has an 80" wheelbase, and 14" wide Formula Atlantic tires on the rear. :-)
More about it
here:
North Georgia Weather - Autocrossing The Jeep
and here: The Jeep - North Georgia Weather
Ballpark output with the Trifecta tune?
Old Feb 11, 2015 | 10:14 AM
  #461
JapEatr's Avatar
South Central *********
that thing looks crazy
Old Feb 11, 2015 | 10:39 AM
  #462
It IS crazy! Part of the difficulty in driving it fast is that it has such a short wheelbase, it will snap on you very quickly if you're not ready for it.
It uses a Doug Nash 2 speed quick change transmission with a Ford 8" read end with 4:63 gears. We launch in high gear and never shift. We needed some additional RPM which is one reason for the camshaft and valve spring change. We've good for about 75 mph top speed. We get there REAL quick though. :-)
Old Feb 11, 2015 | 11:17 AM
  #463
More about it
here:
Stage 2 cams would be pointless on the stock turbo. Better to first upgrade to a turbo that will hold power past 6200 before considering stage 2 cams. You will want Opel injectors and cams with big fuel lobe though with e-85 and a larger turbo.
Old Feb 11, 2015 | 11:24 AM
  #464
You beat me to it.
Old Feb 11, 2015 | 12:41 PM
  #465
96S1's Avatar
Dude that "jeep" flies around the track so fast it looks like the video is in fast forward!! Looks like an absolute blast to run.
1760 lbs and LNF powered - that's ****** awesome
0-75 in 3.2 seconds?!
Old Feb 11, 2015 | 01:01 PM
  #466
Never actually timed it but that's probably pretty close. :-)
Here are some in car videos from the 2014 Solo Nationals.
Sep 27, 2015 08:53 PM
jas09ss
Sep 26, 2015 01:06 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
