ZZP LNF Cam Testing
Old Dec 19, 2010 | 03:10 PM
  #201
ralliartist's Avatar
some of you need some rather large turbos. lol
Glad I can be part of the club! With a different brand to go about it!
Old Dec 19, 2010 | 03:11 PM
  #202
cmiller8006's Avatar
Originally Posted by RoadconeTuning
a 362 would work tho
Unless bullseye makes them they no longer are made by borgwarner. They are now the s262 or 261, I don't remember.
Old Dec 19, 2010 | 03:13 PM
  #203
I have a pte that will make over 6 if I wanted and not take all day to spool lol.
Old Dec 19, 2010 | 04:21 PM
  #204
SKY888's Avatar
Matt_M, I need cams for a bigger turbo application!
Tell the ZZP staff to have one soon!
thanks!
Old Dec 20, 2010 | 12:52 AM
  #205
blackvette101's Avatar
Originally Posted by beast10007
u need more then a s252
in for your build
yeah im just running the 252 for daily driver duty once some more parts come out for the car im getting a camaro to drive and ill retire the cobalt to race duty. im probably going to use the S259 with a billet wheel thats the biggest turbo in the S200 line on bullseye's website. im only going for about 700 bhp.
I just want 10.50's and 5-550 is plenty for that. 700 is alot lol.
figure if im going to drop 20+k (im already in for 14k) on something your going to want more than 550 trust me ive been there but im building mine for highways. racing from a stop in a fwd car is extremely frustrating especially if your use to rwd
Old Dec 20, 2010 | 06:17 AM
  #206
Invest time and money into suspension and tires and you would be surprised how much better you would be able to launch.
Old Dec 20, 2010 | 09:46 AM
  #207
RoadconeTuning's Avatar
its been a year or two since i've looked... I was looking at that and an S372 for my last car.
Old Dec 21, 2010 | 12:39 PM
  #208
sheldon729's Avatar
Im excited to se these released i want want want but i would want a more aggressive cam then the one they are testing of course. Im planning to port and polish my head and get valve springs..etc
Old Dec 21, 2010 | 12:49 PM
  #209
elecblue06's Avatar
not necessarily a good idea.. remember DI is VERY flow/atomization Dependant.. zzp themselves did some testing and said it was too hit or miss with a ported head if i remember correctly
Old Dec 21, 2010 | 01:48 PM
  #210
D1sclaimer's Avatar
Cool
Old Dec 21, 2010 | 03:45 PM
  #211
Matt M's Avatar
Yes, I was just talking about that on page 8. The flow gains are there, but tune-ability, drive-ability, and fuel economy are sacrificed. Then it just come back to the fuel system limitations that can come into play on the stock head anyway. Then the ported head gains are reduced, but the down-sides are still there. That's why I went back to the stock head.
Old Dec 21, 2010 | 04:09 PM
  #212
elecblue06's Avatar
plus if you're making like 550 whp on the stock head.. it cant be THAT much of a hinderance lol
Old Dec 21, 2010 | 04:34 PM
  #213
soundjunky's Avatar
I was going to be content, only occasionally coming to see what's said, but then I read this;
all you had to do was say you're not releasing the info right now.
don't worry I'm unsubscribing from this thread, and will know better in the future than to ask (you) questions.
Douche bag!
wow.
why the name calling?
Matt said that the advertised duration @ .050 would be the same as the duration at @ .006 - which is not only improbable, but impossible.
Please let me build upon this incase any of you are as of yet unaware;
Duration advertised "@ .050" is the duration of the lobe between the two points where the lift is measured at .050" off the base circle.
The difference between .006 & .050 will indicate the lobes ramp...
You can have two cams with the exact same advertised specifications (often @.050 is not used for the advertised), and unless you look at the lobe ramp, as well as things such as and the lobe centerline (in relation to the installed position) you have a drastic variation of camshafts which are being portrayed here as exactly the same.
Yes I realize that ideally you want to degree any cam being installed, but while at it, many opt to change the installed position to suit their own preferences;
Also, if anyone was to install a cam, and not verify that they have installed it correctly, that's their problem.
I only posted in this thread in the hopes of seeing what was had to offer, and ralliartist seemed to understand what I was asking - as well as my frustration at Matt saying he had these cams while not giving any real information on them which I believe to be usable to much of the CSS.net membership.
Why did I post again?
- because CSS in similar fashion came through when I was called a douche bag for asking what seemed to be an otherwise obvious question.
You even told him that the cams are not finalized yet. ...
yea that guy needs to kool down...
Originally Posted by 09BlueBaltSS
wow. Someone pm him an e-tissue
wow guys.
You're all acting like I've been personally offended or something...
From my understanding, when something progresses to the point of being tested then posted/printed about, that means odds are specs are pretty much nailed down.
I mean, I thought that I was clear enough with this reply;
Please don't take offense by this, but if you don't want to disclose w/o buying, that's one thing - but I for one don't buy anything unless I am informed beforehand.
again, no offense intended - I originally subscribed to this thread in hopes of reading the specs on these cams.
then there's juvenile replies in my direction??
wow.
I didn't mean to upset him, but he's over-emphasizing the need for an exact number. It's cam duration, not main bearing clearance.
For the record, you never upset me.
I read what was essentially a teaser thread, and didn't come to the conclusion that you were still going to possibly change the cams - because that would make a teaser thread kind of pointless...
Once I read you say that the grind wasn't nailed down, I let it drop... perhaps some of you missed this in your rush to ridicule?
on a completely unrelated note;
Merry Christmas everyone!
--> hopefully none of you are in my position ~ of having yet to start shopping
Old Dec 21, 2010 | 05:26 PM
  #214
HunterKiller89's Avatar
wow.
wow guys.
wow.
all the beef was about what looked to me to be an over reaction to a lack of specs.
that was a normal response and a normal reaction.
this part seemed a little extreme. Why exactly do you know better than to ask him questions in the future? He stated plainly that the specs arent 100% yet, so he wont be releasing them as they aren't final.
buuuut, w/e
merry christmas indeed, and yes, i need to get to the mall today too
Old Dec 21, 2010 | 06:49 PM
  #215
soundjunky's Avatar
Originally Posted by HunterKiller89
buuuut, w/e
it's really easy to misinterpret stuff posted online, I am guilty of posting in too strong a manner, as well as misinterpreting people... but name calling is hard to misinterpret.
the mall... hmm... probably should do that some time soon
Old Dec 21, 2010 | 09:13 PM
  #216
Matt M's Avatar
wow.
Seriously? Do you want to go back and read what I actually posted? Or I guess I can just quote it here:
Advertised and .006 would be the same thing.
I gave you the .050 numbers.
Lobe separation is computer controlled.
I gave you the lift.
Centerline is computer controlled.
I clearly stated that "Advertised and .006 would be the same thing." Where in that statement is .050 mentioned? In cam measurements, "advertised duration" is typically measured at .006" for hydraulic cams and .020" for solid cams. I simply pointed out that your questions were redundant because you asked for advertised duration, and then you asked for duration at .006. Then you went on to ask for lobe separation and centerline which are both controlled by the ECM. Furthermore, I already listed the .050" duration and the lift. So basically, out of your list of 6 questions, 5 were either already answered or irrellevant.
Of course had you responded to my question about which part of my post didn't make sense to you, I could have pointed out your misunderstanding days ago.
The thing I really don't get is how you keep acting like I am hiding the specs. I stated that they were on the first page and you keep ignoring this fact.
Old Jan 5, 2011 | 12:49 AM
  #217
sheldon729's Avatar
Any updates??? im getting excited for cams lol i want more aggressive cams then what your testing
Old Jan 5, 2011 | 01:19 AM
  #218
AyrtonSenna's Avatar
Me too!! Please Matt let us know
Old Jan 12, 2011 | 01:38 PM
  #219
sheldon729's Avatar
Im cam craving any news haha
Old Jan 18, 2011 | 05:31 PM
  #220
gone_in_10_sec's Avatar
Matt - any updates on the cams..?
Old Jan 18, 2011 | 09:37 PM
  #221
Matt M's Avatar
We are having some tests done on these and then I plan to install bigger cams to test as well. I'll let you guys know when we have more info available.
Old Jan 19, 2011 | 11:58 PM
  #222
Matt - great news!!! we are all waiting to see whats next..
Old Jan 20, 2011 | 12:05 AM
  #223
ssblackstealth's Avatar
corn gas ftw....
would love a set of these!! in for results and pricing
Old Jan 20, 2011 | 12:08 AM
  #224
slowbalt84's Avatar
yeah my turbo upgrade could really use these cams.
Old Jan 20, 2011 | 01:38 PM
  #225
Wickedlsj's Avatar
Your turbo upgrade needs an upgrade.
