ZZP LNF Cam Testing
Old Dec 16, 2010 | 09:39 PM
  #151
Matt M's Avatar
Originally Posted by blackvette101
any chance your going to devolop cams with lope for us big turbo guys looking to make power to over 8k rpm eventually.
Yes, we will test bigger cams once the fuel adder is done.
Old Dec 16, 2010 | 11:36 PM
  #152
ralliartist's Avatar
Originally Posted by Matt M
If you purchased stage 2 (not stage 2 turbo) then you have supercharger cams.
We custom spec our Cams from Comp.
thanks for clearing that up matt!
Old Dec 16, 2010 | 11:39 PM
  #153
Berto09ss's Avatar
man o man!
That's really good numbers,any videos?
I want to hear the car at idle,if you have any that is,maybe some dyno vids?
Old Dec 16, 2010 | 11:50 PM
  #154
hawlyns711's Avatar
gotcha, thanks like ralli said
Old Dec 17, 2010 | 10:17 AM
  #155
sheldon729's Avatar
Fuel adder?? due tell
Old Dec 17, 2010 | 11:37 AM
  #156
cmiller8006's Avatar
The extra fuel rail they added. Its been around for a couple months.
Old Dec 17, 2010 | 01:51 PM
  #157
soundjunky's Avatar
We will release more info on the cams and fuel system soon.
Remember, we have over 120 degrees of lobe separation at idle. There isn't going to be any noticeable lope at idle with these cams.
Unless I've missed something, this is the closest we've come to getting specs on these cams.
Old Dec 17, 2010 | 03:08 PM
  #158
Matt M's Avatar
Specs are on the first page of this thread.
These cams are not huge by any means. They are about 8-10 degrees longer duration than stock IIRC. Lift is increased by ~.018". The tops of the lobes are a bit wider, keeping the valves near max lift longer, which is where the majority of the gains come from.
The exhaust is actually increased closer to 12 degrees.
Old Dec 17, 2010 | 03:16 PM
  #159
soundjunky's Avatar
umm, really?
I just looked again, you have dyno results listed, and then this;
These cams are not huge by any means. They are about 8-10 degrees longer duration than stock IIRC. Lift is increased by ~.018". The tops of the lobes are a bit wider, keeping the valves vear max lift longer, which is where the majority of the gains come from.
Please don't take offense by this, but if you don't want to disclose w/o buying, that's one thing - but I for one don't buy anything unless I am informed beforehand.
again, no offense intended - I originally subscribed to this thread in hopes of reading the specs on these cams.
Old Dec 17, 2010 | 03:20 PM
  #160
D1sclaimer's Avatar
Will these cams work in my 60 degree TDC V6 engine?
Old Dec 17, 2010 | 03:25 PM
  #161
He pretty much gave you the specs right there. All you have to do is know, or look up the stock LNF cam specs and add about 10 degrees of duration to the intake side and 12 to the exhaust side. Then to get lift, add .018" lift.
lmfao! tj you are always good for a laugh.
Last edited by ralliartist; Dec 17, 2010 at 03:25 PM. Reason: Automerged Doublepost
Old Dec 17, 2010 | 04:01 PM
  #162
soundjunky's Avatar
Originally Posted by ralliartist
.. All you have to do is know, or look up the stock LNF cam specs and add about 10 degrees of duration to the intake side and 12 to the exhaust side. Then to get lift, add .018" lift. ...
fair enough then.
in my world, "about" doesn't cut it - especially on camshafts...
Maybe I'm an old fashioned stick in the mud on wanting to know specs - but I know for a fact that no one in their wildest dreams can order cams by asking for "about" - and having personally experimented with different cams on GM FWD cars in the past, I just figured that getting the actual specs wouldn't be a big deal.
Things I normally read are:
  • advertised duration
  • duration @.050
  • duration @ .006
  • lobe separation
  • lobe lift
  • lobe centerline (when installed straight up)
pictorial example:
and with that I'm done.
Old Dec 17, 2010 | 04:06 PM
  #163
I know how to read cams and I understand your frustration. But I'd be willing to bet you if PM'ed a member from ZZP about it then you'd get a clearer answer. I know if you order the cams, you get a nifty little cam card that tells you everything you need to know about your cams.
Old Dec 17, 2010 | 04:20 PM
  #164
soundjunky's Avatar
I know how to read cams and I understand your frustration. ...
ok, good to know, sometimes it seems that the general membership here doesn't understand stuff like this - instead they think everything can be done with a tune, and as a result, mechanical upgrades are often (at least perceived by me to be) scoffed at.
I would not order without knowing the specs, and I had thought that this exact thread would have had the specs posted by now ~ last time I checked they didn't actually have these listed, and they were not released yet, and I am most certainly not going to waste the time of anyone associated with a business, with questions when I don't plan on buying beforehand...
I mean, I don't even think any cam manufacturer has LNF cam blanks, and GM never offered LNF cam blanks - so even if someone wanted to pull the douche card, it wouldn't to be easy.
Old Dec 17, 2010 | 06:34 PM
  #165
blackvette101's Avatar
hell yeah
Old Dec 17, 2010 | 10:31 PM
  #166
Matt M's Avatar
fair enough then.
  • duration @.050
  • duration @ .006
  • lobe separation
  • lobe lift
Advertised and .006 would be the same thing.
I gave you the .050 numbers.
Lobe separation is computer controlled.
I gave you the lift.
Centerline is computer controlled.
Actually, "about" is what everyone gets when they read cam specs. We have hydraulic lash adjusters and variable cam phasers. The numbers on paper are not exactly what you get in the real world. I said "about 10 degrees" and "about 12 degrees" because we use .050" specs while GM published 1mm specs. By my measurements, our cams are about 10 and 12 degrees larger than stock. I could say they are 10.1 degrees and 11.7 degrees bigger, but that would make no practical difference. Furthermore, these cams are not for sale yet. If we release exact specs and then change the design slightly, the numbers are stuck out there to be repeated on the forums time and time again.
Old Dec 18, 2010 | 02:02 AM
  #167
soundjunky's Avatar
wow.
I am completely dumbfounded that I just read that.
Old Dec 18, 2010 | 02:21 PM
  #168
Matt M's Avatar
wow.
Which part?
Do you believe that there is an important difference between 210 degrees vs. 209.7 degrees despite the fact that you wouldn't know the duration at anything higher than .050" lift? Two cams could have the exact same .006 and .050 duration, yet one could have 10 degrees more duration above .200 lift, but you would never know that from a cam card. People seem to get stuck on typically published specs even though they don't tell the whole story. It's similar to choosing a turbo based on the exhaust AR and the compressor trim even though a 200hp capable turbo and a 3000hp capable turbo can have the exact same AR and trim. It just doesn't seem to matter because people get it stuck in their head that they need these numbers and that is all they look for.
When we release specs for our cams, they will have more detail than what you asked for above.
Old Dec 18, 2010 | 02:27 PM
  #169
Which part?
I hate it when people talk about their turbos and reference only trim and AR. That literally tells me NOTHING about their turbo.
Old Dec 18, 2010 | 03:24 PM
  #170
soundjunky's Avatar
...When we release specs for our cams, they will have more detail than what you asked for above.
all you had to do was say you're not releasing the info right now.
don't worry I'm unsubscribing from this thread, and will know better in the future than to ask (you) questions.
Old Dec 18, 2010 | 04:18 PM
  #171
beast10007's Avatar
Douche bag!
thanks Matt for all the info that you have released but the Number's most people want is the HP/TQ gain lol
Old Dec 18, 2010 | 04:24 PM
  #172
gone_in_10_sec's Avatar
Cant wait to get the cams for my car..
Old Dec 18, 2010 | 04:58 PM
  #173
Matt M's Avatar
I did say that.
Feel free to ask me all the questions you want. Just don't act like a half a degree of duration makes a huge difference or that cam manufacturers give you exact numbers. Measure a few cams and you will see what I mean. Specs are off a couple degrees in most cases. On the LSJ, you can rotate the cam gear more than 2 degrees before the bolt is tight. Think of what that does to the LSA if you moved each cam in the opposite direction!
Old Dec 18, 2010 | 05:12 PM
  #174
Old Dec 18, 2010 | 05:16 PM
  #175
Matt M's Avatar
I didn't mean to upset him, but he's over-emphasizing the need for an exact number. It's cam duration, not main bearing clearance.
