zzp s256et tuning session one
Old Jun 1, 2012 | 02:08 AM
raver0789's Avatar
Started tuning my s256et after the install was completed. Car is on 24psi now, 14 degrees timing and is a beast. Very happy. Plugs are gapped at .29 but car is misfiring up top 6300 to 7400. Plugs are brand new. Car is way faster than my e47 fully bolted stock turbo car which put down 360 434. Mods are zzp's turbo kit, 3 inch zzp exhaust, zzp intercooler, ecm boost control and tial 38mm wastegate. ZZP is NOT tuning this car....this is my friend tuning it and modifying a base tune they sent me.
Any thoughts if I should tighten the plugs up more to .25?
There is very little lag with this setup, i'm impressed.
Matt
Old Jun 1, 2012 | 04:04 AM
Frogstofall's Avatar
Perhaps are you running out of fuel up there or are you positive its something like spark blow out?
Old Jun 1, 2012 | 06:12 AM
brant's Avatar
gap plugs to .25 i had the same issue
Old Jun 1, 2012 | 07:23 AM
blrt's Avatar
Good point. Hmmm...
Old Jun 1, 2012 | 08:22 AM
ATLsilverSS's Avatar
I doubt he is running out of fuel on pump gas. Or wait......is this an ethanol tune???
Old Jun 1, 2012 | 09:13 AM
FasterIsBetter's Avatar
Yeah, could also be a boost leak, especially if you throw a maf code.
Old Jun 1, 2012 | 09:19 AM
Terminator2's Avatar
Matt
Sounds exactly like injection window misfire to me. You are likely past the injection window in the higher RPMs (the higher the RPM the shorter the injection window). At 24psi you should be able to run stock plug gap no issues. You need to advance the injection timing and raise the WOT fuel pressure a little as well.
Old Jun 1, 2012 | 09:36 AM
blrt's Avatar
Little thing like this us shadetree tuners will never thought of. I am just saying and I am not implying anyone. Thanks for sharing..
Old Jun 1, 2012 | 11:25 AM
raver0789's Avatar
I forgot to say, we had timing low because we weren't sure what boost we were running, misfiring was prevalent. When we added a bit of timing, misfiring went almost away but there still is a little.
Old Jun 1, 2012 | 11:32 AM
ebristol's Avatar
What range plugs are you running. There is a such thing as being too cool.
Old Jun 1, 2012 | 11:55 AM
raver0789's Avatar
They r not the stock plugs. i have a set of the stock lazer iridium at home. they were included by zzp free with the kit.
Old Jun 1, 2012 | 12:00 PM
raver0789's Avatar
Thanks term. we will look into that issue to see what is going on. for anyone who wants to know the lag on this kit positive pressure is at 3100 full boost by 3500 to 3600.
Old Jun 1, 2012 | 12:21 PM
I wish they sent lazer iridiums with mine. I got Autolites from em...lol. Oh well, they work and the car doesn't seem to mind them!
Old Jun 1, 2012 | 12:23 PM
ebristol's Avatar
Are you running E10, E47 or E85?
Old Jun 1, 2012 | 12:44 PM
MBC or using the factory wg solenoid?
Old Jun 1, 2012 | 01:17 PM
raver0789's Avatar
Factory boost control. i am running e10 94octane we get here in canada. ya i am running autolites right now. that is what zzp sent for free. i am stock iridiums in my basement.
We don't have numbers yet, but car loved being switched from 0.83 to 0.86 lambda. Not sure if that is the sweet spot, what has anyone else found?
Old Jun 1, 2012 | 01:27 PM
Matt M's Avatar
I would recommend stock plugs at .032". Remember, you can always send me a scan if you want some help with the tune.
Do you have stock valvesprings or upgraded?
Old Jun 1, 2012 | 01:29 PM
ei3dag3's Avatar
subd
Old Jun 1, 2012 | 01:31 PM
AARON-SS-TC's Avatar
damn, you did 360whp and 434wtq on the stock turbo? thats great numbers, and im curious to see what you have with the new setup
Old Jun 1, 2012 | 01:36 PM
raver0789's Avatar
Yup ZZP valvesprings and retainers
Car doesn't have the instant get up and go the stock turbo did on e47, but once she spools it's a night and day difference, and it's scary cuz i can't even rev her out to 7400 cuz i'm getting misfires and shutting her down. I'm cutting her off at 6300.
Thanks Matt M, I will send you an email if we need some help. You guys at ZZP have been a great assistance from day 1.
Very impressed with the trubo. Cool and stable IAT2s and by the wastegate duty cycle numbers she's not even trying at 24psi.
Old Jun 2, 2012 | 08:46 PM
blrt's Avatar
Good to hear you are pleased with how it spooled. EFR what? Wait till you get the 4.45.. have fun!
Old Jun 2, 2012 | 09:15 PM
You all are makin me jealous....cant wait til I get my trans back in. Already missin my girl!
Old Jun 3, 2012 | 10:04 AM
blrt's Avatar
Patient Grasshopper...
Old Jun 6, 2012 | 11:15 AM
raver0789's Avatar
It was the plugs. Autolites are gone and were replaced with stock plugs gapped at .25. The car instantly ran smoother overall. No misfires right through to fuel cutoff. Tuning session two is thursday. We hope to make more progress.
Old Jun 6, 2012 | 11:50 AM
Sully20's Avatar
How is this Turbo spool and WHP wise compared to the 252et?
