20lbs of boost with a 2.8?
thats were the gauge is getting its input from, the map sensor
Having A Similar Problem And Im Trying To Figure It Out Myself I Have No Cat And Full Exhaust All Cooling Mods And Alcohol Injection Im Running About 22 Lbs Of Boost I Also Have A Scan Gauge So It Digital Not The Stock Gauge Im Going Crazy Trying To Figure It Out My Iats Jump From 130 To 160 I Dont Understand Is This Normal ?
Check the Inter cooler pump and make sure its working, There have been people on here that have experienced an over boost condition when the pump has died. That would also explain the IAT2 jump too.
its called backpressure.. u need to free up ur exhaust relive some pressure...i was hitting 20lbs on 2.8 then cut off the the cat and slapped a header on her with a hks muffler now i see 17 lbs and much more power.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
