3.5" Intake
Old Feb 19, 2014 | 01:01 PM
Josh@ottp's Avatar
3.5" Intake
Who would want one and would you just want the lower pipe to be 3.5" or the whole intake to be 3.5"? I will be mocking on up today and was just curious.
Old Feb 19, 2014 | 01:05 PM
Hockeyman's Avatar
I'd be interested if the whole intake was 3.5", plug and play with the LS4 TB and TVS.
Old Feb 19, 2014 | 01:10 PM
jrmotosports 88's Avatar
click
Old Feb 19, 2014 | 01:23 PM
blueLNFftw's Avatar
I would be.
Think it will fit through the hole in the frame without cutting it up?
My RD Fabs one fits pretty shifty.
Old Feb 19, 2014 | 01:37 PM
KMO43's Avatar
This for LNF or LSJ?
Old Feb 19, 2014 | 01:41 PM
...Seriously?
Old Feb 19, 2014 | 01:55 PM
Josh@ottp's Avatar
I would be.
It fits with about a 1/4" around the sides. For the best fitment I would most likely trim a little towards the front of the car to push the intake away from the tire. At the very least I would put some hose on the car to stop any vibrating of the intake.
Old Feb 19, 2014 | 01:59 PM
06cobaltncng's Avatar
im still rocking the stock airbox. been debating changing but I think itd only be for looks.
Old Feb 19, 2014 | 02:11 PM
KMO43's Avatar
Originally Posted by ECaulk
...Seriously?
sorry didn't read section I want a better cold air for my LNF
Old Feb 19, 2014 | 02:19 PM
yellowsupercharged06's Avatar
id buy one, pending it isnt overkill
some dyno sheet of 3 vs 3.5 would be nice too once its mocked up
Old Feb 19, 2014 | 02:28 PM
mrbelvedere's Avatar
get real its not going to happen
I would do a lower or a whole if It fit without cutting up a bunch of ****
Old Feb 19, 2014 | 02:30 PM
whats not going to happen ? and what am i getting real about ?
Old Feb 19, 2014 | 02:32 PM
Staged07SS's Avatar
Administrator
Administrator
A dyno of a 3" vs 3.5" intake.... that's what mrb was getting at.
This intake is only going to benefit TVS cars with extensive mods to the engine.... ie. a ported head, cams, additional power adders such as nitrous, etc.
A stock engine M62 or TVS car will see minimal if any gains from this.
someone doing a before and after test on the intakes is not going to happen so I recommend you do it
Old Feb 19, 2014 | 02:36 PM
i mean if Josh is going to produce one, why not put the time and effort into it ?
sooo we should all just buy one cuz its bigger ?
where is the logic ?
he asked about interest, i gave my interest and reasoning .....
would you buy a tvs if you had no idea if it was going to be better than an m62 ? or would you want harrop to show you it was better before your said ohh yea ill take one ???
Old Feb 19, 2014 | 02:39 PM
Josh@ottp's Avatar
I would like a test dummy for one.
Old Feb 19, 2014 | 02:41 PM
Bluelightning's Avatar
Got Bewst?
How many products do you see for our cars with before and after results that a manufacturer does? Veeeeery few.
Old Feb 19, 2014 | 02:43 PM
looks like Josh is trying to though...
Hockeyman's Avatar
I'd be happy to
But the TVS isn't going on until springtime.
Old Feb 19, 2014 | 02:44 PM
WVU_SS's Avatar
Same here. I'd test one, however I don't really have the mods to make it worth it right now.
Josh@ottp's Avatar
I think a few guys are missing the point of this. Not only will it make more power on a high end build, it is basically going to be required with where we are going. 375whp on e85 is more than enough power to overrun the maf table. Only way to get back on it is to go to a bigger tube for the MAF sensor.
Old Feb 19, 2014 | 02:46 PM
blueLNFftw's Avatar
Hi, I am corey and have done one of these for you before.
What do you need from me?
PM or email.
Old Feb 19, 2014 | 02:51 PM
Advise is a good friend of mine, he is in this area and he may be interested in testing this out for ya.
Old Feb 20, 2014 | 07:13 AM
Tjolley's Avatar
More then happy I can do u one better i have zzp 3" cia, inner cia, k&n typhoon cia, aem, stock. All sitting on the shelf at home.
Wouldn't take much to swap them all out at the dyno. Just show up with no fender liner. I can do it on my 2.4 and 100%meth(steve) can do it on his 2.0
Proly dial in ur 3.5 on the street first since it takes so much manipulation of the maf table.
Old Feb 20, 2014 | 10:43 PM
MrSlickSter06SS's Avatar
Wish I was local to you I'd let you have the car for a bit to play around with. Where would you locate the MAF sensor on the Tube? I am skittish since my Injen caused idle bounce do to poor location of the MAF mount, at least that's what I believe seeing's how going back to my stock air box, and doing an air box mod corrected the idle. I believe, correct me if I am wrong, ZZP said the MAF was seeing to much turbulence within the tube rather then a nice flow threw the tube..? Just curious is all, o and I don't have a TVS so I clearly wouldn't be a good test subject unfortunately.. Anyone close by should jump on this.
