After all that!
Old Oct 3, 2011 | 07:07 AM
  #51
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by ecot3c inside
I would never increase the compression with pistons without first putting in sleeves. you'll crack that bitch in half, 7250rpm is about 50-75rpm to high, especially on an 05 with 106k miles. And yes the GMS3 kits are rich because it's safer to be rich than lean, different elevations and climates differ it. get a custom tune next time it's obviously better. I have f*cked with my ss soooo much and not 1 problem from it in 2 years. you can check your tensioner to see if it broke so it doesn't have to be a "might have been your tensioner" situation.
His rev limit was not too high. He was only reving to 7K +/- (rev limit 7250 rpm) which is still perfectly safe. What happened to his car could have happened even if he was still running the stock rev limit. He has over 100k miles on the car.... Stuff is going to break.
Old Oct 3, 2011 | 11:22 AM
  #52
Joemaster70's Avatar
that's staged u seem like the only reasonable voice here. I still like that GM stage kit. I might just have vince custom GMS3 me. so i can run mild cam's all head work and maybe leave the bottom end stock idk yet. still gotta see what the hell i broke
what would u guys replace at this point? how do i tell if my stock sleeves are still strong?
I really don't wanna put 5+K in this motor. plain and simple.
Old Oct 3, 2011 | 11:28 AM
  #53
Staged07SS's Avatar
Administrator
Administrator
Keep me posted.
I'm upgrading my valve springs this winter. I don't want to run the risk of floating a vlave or worse dropping a valve. I like reving out past 7K just for the better feel of the car when it falls into the next gear (keeps the car in sweet spot of the powerband). You have the perfect opportunity now to upgrade your valvetrain and do things right. Good luck man!
Old Oct 3, 2011 | 11:38 AM
  #54
Originally Posted by BlueBolt66
Dude I told you multiple times how to go about making the power you want on the m62 and stock motor. We just told you if you wanted bigger power to go turbo instead of strapping on nitrous but you don't listen and had your mine set which is fine live and learn I guess. But to say you tried for help and all we said was go turbo is just ignorance. Ask your girlfriend or everybody that's been at the meets, your girlfriend was even laughing because we kept having to repeat how to achieve your goal. I also like how when you showed up with your car weds making noise and running like crap we asked if you were racing your heating on it you said you were just cruising on the highway and now you were stomping a 2010 m3. Good luck with your car though you apparently only want advice that supports what you already have your mind set too.
dont bring my g/f into it u honestly don't know why she was laughing. She was pretty much laughing due to you guys not getting why i wanted to go the route i did. U think E-85 is easy to find. I drive more than 60+ miles a day to and from work, it be so pointless to put that in when if i can't find the station i run outta gas. Nitrous is refillable and doesnt require to be on all the time only when want to be used. Maybe the meth idea you guys gave me is good i still might do that. But honestly don't say **** when you don't know the deep facts ok
Old Oct 3, 2011 | 11:48 AM
  #55
mrbelvedere's Avatar
joe u can make plenty of power on stock parts the majority of the reliabilty is in the tune
Old Oct 3, 2011 | 11:50 AM
  #56
i know it's the tune but no way the GMS3 tune could of hurt my motor it's "supposed" to be safe so
Old Oct 3, 2011 | 12:07 PM
  #57
no because pistons would obviously be in addition to any pulley drops, you can run on the hub on an m62 and it would still fall on it's face at 20psi. tvs is a different story, look at most turbo builds, some people's sleeves/pistons took a ****. your theory of detonation is false because that would imply that with the proper afr, and the best spark plugs you can run infinite boost. no one can predict when **** goes wrong man.
cylinder pressure is cylinder pressure no matter how u look at it. it dosent matter if its from dropping a pully size or raising the compression. reguardless of which way you raise cylinder pressure you increase the risk of detonation it takes more then propper afr to keep detonation away and there is no miracle spark plug out there that will fix all that detonation is the grim reapor of engines
Old Oct 3, 2011 | 12:09 PM
  #58
well if the engine wasent up to mechanicaly then yes it could have been the down fall
Old Oct 3, 2011 | 02:20 PM
  #59
user 72239's Avatar
Listen to Mrbelvedere. That guy knows his **** when it comes to cobalts. Some dickwads in Chicago are gonna be crying that their engine grenades and Mrbelvedere will be strolling on by laughing.
Old Oct 3, 2011 | 03:10 PM
  #60
mrbelveder what do u recommend i should do??
Old Oct 3, 2011 | 04:41 PM
  #61
ebristol's Avatar
The tune its self is not rich (11.4 cmnd AFR through most of the midrange & 11.3 cmnd AFR up top).
Old Oct 3, 2011 | 05:06 PM
  #62
Perfect.disguise's Avatar
lmao
Old Oct 3, 2011 | 10:24 PM
  #63
heres the process so far
tomorrow is clean up and spliting the tranny from the motor than tear it apart piece by piece
Old Oct 5, 2011 | 02:42 AM
  #64
LittleRedRocketSS's Avatar
so what you gonna do put a junk yard motor in there or what?
Old Oct 5, 2011 | 06:10 AM
  #65
BlkWdoSS's Avatar
Prove it! mileage has nothing to do with it unless you beat the crap out of it. As I have stated already mine has 165k+ miles and my motor is still kicking. Please say it is my power level, cuz I can guarantee that I make near double what you do.
if you want a built and badass motor that you think you need, you will need to put near 5k and probably far more.
Thank you for saying this, it really is the tune and abuse that the owner puts it through.
Supposed to be and actually are 2 very different things, and if you have just a GMS3 and have other mods it could very well be too lean or the injector sticks or fuel pressure drop from bad pump or... etc.
I recommend you should sell it and just get something new since your car is soooo old cuz it has more than 100k miles
Originally Posted by ebristol
most people wont know what that says ebristol but its definitely not 11.4 in the mid range, quite a bit leaner.
l8r,
PD
Old Oct 5, 2011 | 07:11 AM
  #66
Staged07SS's Avatar
Administrator
Administrator
l8r,
PD
Wow, how old are we???
Are you trying to intimidate me with your cars power?? Really??
Just because your car is fine at 100K+ does not mean everyone elses is running as well.
It's common sense that a motor with 100K+ is bound to have **** break eventually. Just because you havent doesnt mean it cant/wont happen.
I have been GMR Stage 3+ longer than a lot of people on this site. I have performed plenty of logs on my car. I consider my mid range in the 5500 rpm area considering what I rev to. I know it is in the low 12's high 11's below that.
My cars logs are as follows:
12.2-11.9 from 4500-5000 rpm, 11.9-11.6 from 5000-5500 rpm, 11.4 from 5500-6500 rpm, & 11.3 from 6500-7000 rpm.
It goes to almost 11 flat after 7000 rpm (I rev to 7500rpm).
Old Oct 5, 2011 | 07:23 AM
  #67
zfissette's Avatar
point of fact, if staged07 is running similar mods to my 07, hes making around 275 whp, so in order to be making double you would have to hit 550 whp. fairly sure the 500+ whp cars can be counted on one hand.
Old Oct 5, 2011 | 07:40 AM
  #68
Staged07SS's Avatar
Administrator
Administrator
You are close....
My car makes 273whp on 93 octane, and close to 285whp on race gas.
I don't run the M62 which most members know by now.
I'm not making crazy power obviously, but I don't understand why he thought he should attack me with "my car makes more power than your car"..... It had nothing to do with what I was gettting at in my post.
Nor was I bragging about my cars power level ::shrugs::
Old Oct 5, 2011 | 09:38 AM
  #69
some peoples kids man
Old Oct 5, 2011 | 09:51 AM
  #70
ebristol's Avatar
Yeah.
Originally Posted by EB
I was not planning on it but I can tell you that the commanded AFR looks much better then the GMS2 tune.
GMS3 PE Fuel Multiplier vs RPM Table
Starts at 12.9, 12.25, 11.76, and ends with 11.3.
That is on an 06/07 Redline. It could be difference for other years and other platforms.
Old Oct 5, 2011 | 09:57 AM
  #71
Staged07SS's Avatar
Administrator
Administrator
Yeah.
My logs are fairly close to the table....
I should have been more clear in my post when I said 11.4 in the midrange. My car carries 11.4 for most of the powerband, and richens up to 11.3 & finally 11.0ish up top (past 7K).
Old Oct 5, 2011 | 10:27 PM
  #72
start saving for performance parts! most likely build the motor. Matters what i can afford may take longer. I do wanna keep my car plus i don't want another car payment.
Old Oct 6, 2011 | 06:13 AM
  #73
BlkWdoSS's Avatar
I wasnt attacking you, I wasnt attempting to intimidate you with my HP, I was simply trying to say that his horsepower level isnt what caused his motor to blow because I have more miles and more power and it has not happened to me yet. I also have an amazing tuner and I know enough about tuning to save my car if I notice something going wrong.
You say that it is common sense that things will break eventually after 100k? if that were true then why is there a warranty for things under 100k? Its common sense that cars will break, more so if they have been modded and the more mods done the higher the chance of breaking.
also, there are tons of cars that have crossed over 500k or even a million miles, 100k is just the tip of the iceberg if you treat it right, do PM and care for them as necessary.
point of fact, there were more than 5 500+whp cobalts 5 years ago. and you dont know anything about my car or any thing that I have done to it. If you would like to see a list of cobalts that are near 500 and some that are well above 500 please visit the "Official Turbo LSJ thread" on the forum. Almost every car in that thread starts at mid to upper 300s on pump gas and clears 500 on anything above 110 octane.
Just because 99% of cobalts will never see horsepower past where the stage kits get them. Some of us have had these cars for a long time and saved and spent a lot of money on these things and it has paid off.
l8r,
PD
Old Oct 6, 2011 | 07:14 AM
  #74
Staged07SS's Avatar
Administrator
Administrator
l8r,
PD
I never said power level had anything to do with it.....
You said that you hoped I would say that. Please read what you said to me in your first post towards me.
I never said 100K+ is the magical number for things to break either, but it is a point where the risk becomes greater, and potentially happen. A lot of it depends on how well you maintain the car to (also build variences can be a lead factor). We don't know for sure how well the OP maintained his car, or his driving styles.
Hell, my first car (1992 Cavalier RS) when I turned 16 exceeded 250,000 miles once I got to college. I sold it, and it lived on to 300,000 miles before getting into an accident. If you maintain a car, and treat it well, it could potentially last forever.
There have been some good points made by you, me, and other knowledgeable members throughout this thread. Lets see how the OP's engine tear down and rebuild go. There is no need for anymore bickering over what caused his issue.
Old Oct 6, 2011 | 07:45 AM
  #75
so in one week you went from i hate my car its got alot of mileage and is a piece of junk i want a high horsepower newer car
to
i love my car its so fun i dont want to get rid of it im gonna build it to the moon?
do YOU know what you want?
