AIT2's
your fine. it doesnt start to pull timing untill about 160-165
what was it reading during the pull?
Last edited by 06cobalt racer; Dec 28, 2011 at 09:34 AM. Reason: Automerged Doublepost
Should be lower IMO, With just a HE and a 2.8 i would cruise at 70-87ish. At 134 you can barely do a long pull safely without touching the 160. Range.
I remember being at the track sitting at the line at 124ish and would pull major timing going down the track
I'll take another "drive" drive this weekend write down the temps so you guys have a better idea. Still on stock pully. I have Intake,Header,DP,GMPP exhaust. I also notice I'm nocking quite a bit. One pull the knock went up to 21.
Honestly if you showing that much knock i would not even be going WOT at all.
What do you mean by "when I stopped the car"? Stopped and shut off the engine? Stopped and let the car idle for 5 minuets?
If your IAT2 were that high during normal driving there is something very wrong.
If you are just cruising you should not see that large of a delta between the ambient and IAT2 reading. Something is wrong.
KR of 21? Something is wrong.
What did your IAT2 read during (or right after) the "pull"?
Vander Nars
Dec 9, 2011 01:54 AM
