AIT2's
Old Dec 28, 2011 | 08:10 AM
duffman11's Avatar
AIT2's
Did a 2nd gear pull when it was 43 F. Then drove about 20 miles at ~75 MPH
When I stopped the car the Interceptor said it was at 134 is that good or bad?
Old Dec 28, 2011 | 08:13 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Normal.
Old Dec 28, 2011 | 08:18 AM
duffman11's Avatar
Even w/ ZZP S3 heat Exchanger. Seems kinda high I was expecting like 110's
Old Dec 28, 2011 | 09:34 AM
06cobalt racer's Avatar
your fine. it doesnt start to pull timing untill about 160-165
what was it reading during the pull?
Last edited by 06cobalt racer; Dec 28, 2011 at 09:34 AM. Reason: Automerged Doublepost
Old Dec 28, 2011 | 09:47 AM
ULWizSS's Avatar
Should be lower IMO, With just a HE and a 2.8 i would cruise at 70-87ish. At 134 you can barely do a long pull safely without touching the 160. Range.
I remember being at the track sitting at the line at 124ish and would pull major timing going down the track
Old Dec 29, 2011 | 03:54 AM
duffman11's Avatar
I'll take another "drive" drive this weekend write down the temps so you guys have a better idea. Still on stock pully. I have Intake,Header,DP,GMPP exhaust. I also notice I'm nocking quite a bit. One pull the knock went up to 21.
Old Dec 29, 2011 | 07:16 AM
ULWizSS's Avatar
Honestly if you showing that much knock i would not even be going WOT at all.
Old Dec 29, 2011 | 12:54 PM
ebristol's Avatar
What do you mean by "when I stopped the car"? Stopped and shut off the engine? Stopped and let the car idle for 5 minuets?
If your IAT2 were that high during normal driving there is something very wrong.
Old Dec 29, 2011 | 02:02 PM
Reaper06's Avatar
Converter?
Old Dec 30, 2011 | 05:02 PM
SneakyMilo's Avatar
If you are just cruising you should not see that large of a delta between the ambient and IAT2 reading. Something is wrong.
KR of 21? Something is wrong.
What did your IAT2 read during (or right after) the "pull"?
killtank
Dec 30, 2012 07:42 PM
Kingpin2010
Aug 7, 2012 11:48 AM
duffman11
May 7, 2012 10:52 PM
Vander Nars
Dec 9, 2011 01:54 AM
rivaladore
Sep 1, 2011 11:39 AM
