ATI super damper..
Old Jun 1, 2012 | 05:25 PM
delige's Avatar
ATI super damper..
so im told to use an OD damper from ati.. now my blower has a 3.0 pulley..
i was just gonna put the stock 6 rib cobalt crank pulley on my car...
ATI - ATI GM Ecotec Super Damper #
so anywyas what way would be better to go in terms on blower pulley size and crank pulley.. what combo ..
Old Jun 1, 2012 | 05:39 PM
quote from the link
Top Ecotec racers like Nelson Hoyos and Marty Ladwig rely on ATI Super Dampers for superior performance and reliability race after race. In May of 2005, Marty Ladwig's ATI equipped Chevy Cobalt became the first 4-cylinder FWD drag car to break 200 MPH in the 1/4 mile with a blistering 202.02 MPH run."
holy crap! i don't get it though what does a damper do? its not our tensioner is it
Old Jun 1, 2012 | 07:04 PM
delige's Avatar
so anyways , what pulley combo or what not would work best ? should i use the ati od pulley, but then what size should i put for the blower pulley ...
should i use stock cobalt 6 rib ? opinions ?
Old Jun 1, 2012 | 07:29 PM
bluebalt07's Avatar
Just use the stock one. The ATI is a great piece but isn't really necessary for your build.
Old Jun 1, 2012 | 07:42 PM
carstedt's Avatar
i run a 2.6 on mine no problems but be when it comes time to install it make sure ur on the ribs furthest in otherwise ull have tension pulling the belt and ull rip it..also i suggest getting an oversized tensioner pulley from zzp and using a stock length belt
Old Jun 2, 2012 | 12:15 PM
TStone's Avatar
It will make the blower pulley 1 size smaller.. So If you have the ati & a 3.0 pulley.. It'll spin the blower just as if you had the 2.9 pulley on it. So it's much safer on the blower also
Old Jun 2, 2012 | 04:24 PM
mrbelvedere's Avatar
quote from the link
no its not a tensioner a crank dampner absorbs the harmonics from the rotating assembly the stock dampner dosent do much past 6500 rpm
any eco spinning past 6500 rpm could utilize an ati
if you are running a phenolic intake spacer you dont need an oversized tensioner
Old Jun 2, 2012 | 05:24 PM
carstedt's Avatar
negative i hav a 2.6 and the spacer on mine and my stock tensioner was not holding at all..it gave me sum nasty belt slip...ran the zzp oversized tensioner and the belt is tight and holds just fine
Old Jun 2, 2012 | 05:31 PM
carstedt's Avatar
if he runs a larger pulley lik a 3.0 he may be ok but if u drop to a 2.8 or below ull want the oversized tensioner to be safe and nething below a 2.8 ull need it or ull hav belt slip...personal experience
Old Jun 2, 2012 | 05:37 PM
i can barley get the belt on with a 2.9
Old Jun 2, 2012 | 05:42 PM
carstedt's Avatar
i shredded my belt when i had the 2.6 on with the stock tensioner cuz it was loose enough that at wot when i shifted the belt shifted over a rib and caused it to rip and i was hittin mayb 15psi at most and then losing it down to bout 5psi...oversized tensioner solved that right away..but mayb he wont even drop down that far so who knows
Old Jun 3, 2012 | 04:14 PM
delige's Avatar
so the ati is lightweight, and when you put that on as the balancer , it makes whatever size blower pulley you have on, the next size smaller.
so it would make my 3.0 a 2.9 ?
Old Jun 3, 2012 | 04:29 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Ati is not lightweight.
Old Jun 3, 2012 | 04:37 PM
delige's Avatar
k so my engine is going to be fully built... my cams are 2800 - 7000 range
i have 3.0 pulley on blower right now .
not goin into details but bottom end l61 and top end lsj 2.0 .
what should i do for balancer and blower pulley..
Old Jun 4, 2012 | 12:53 PM
delige's Avatar
suggestions ?
Old Jun 4, 2012 | 04:10 PM
after all the information that has been givven you still need to ask. the ball is in your court young padiwan
Old Jun 4, 2012 | 10:27 PM
SSean's Avatar
I have the Fluidampr crank pulley and I am not disappointed. The engine feels like a cadillac 4-banger vs. a rattle trap. I have been to the drag strip with the stock pulley and the fluidampr and it was night and day difference. Engine doesn't feel like it will blow apart now. Granted it is not as smooth as a v6 or v8.
Old Jun 4, 2012 | 10:30 PM
kxrida2000's Avatar
u dont need it. put your money elsewhere
Old Jun 4, 2012 | 10:34 PM
SSean's Avatar
He's right. Invest the money and ride your bicycle.
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
