ATT: people running the Rebel Kit
I'm having trouble figuring out how the injector harness gets installed. There are numbers labeling each connector, do I install it with the 1-3-4-2 combination (which is the firing order) or just a 1-2-3-4 one.?
And did anyone have a CEL when the kit was installed?
Thanks.
Thanks.
And that is why I have been told by you and one other person, I just want to be sure. I've already switched them once already. Do you that that would that cause a CEL?
See what the cel is and we can go from there. I don't know what all is included in the stage 1 kit but injectors should NOT cause a cel. What else is included in there kit? Also what made you choose rebel over ottp? Just the fact that there located in canada?
I personally have no idea what you have there, but its is my opinion that rebel sell junque other than their intake. which seems quite nice ...i have tried to help a customer who bought the RAW s/c upgrade for a 2.2 its a crime what they did. I dont care if they are a supporting vendor the work was just terrible and the car dont run right and its impossible to get it right without starting over...RAW + JBP = Fail. You asked for help: My advice? start over...
I also hate rebel but I hate a lot of companies who produce pure garbage and then sell it. Let me know what else is in the kit and I will let you know what might be tripping the cel, if the injectors are installed correctly and are properly working they shouldn't produce a cel.
-2.8 pulley
-60# flow matched injectors
-injector wiring harness
-PCM flash
This site did have a group buy on this kit back in 06/07 where 10 people bought in for a discounted price. I saw good reviews.
I can't read my PCM because I think Rebel put a "HP Tuners tunerlock" on it. I think this because a friend of mine with an OBD 2 reader plugged it into my car and its didn't power up. I still have not recieved a response from rebel to my many e-mail concering these issues
I do hear alot of good things about this kit, I decided to go with them mainly because I'am Canadian, and I wanted to keep my money in Canada. and secondly, I feel that OTT has some issues that I'm not going to get into here. Don't get me wrong, I like Josh and his business, but I think he has some supplier issues that make things unperdicatble. BTW, my OTT HE works and looks great.
I'm going to try that tomorrow for sure
Last edited by Red07Coupe; May 24, 2009 at 02:03 AM. Reason: Automerged Doublepost
The sc2.4 qwik refered to is my good friend and yea for the price it cost him he could have done alot more and better just becareful who you buy from
totally agree with qwik I have had horrible experieces with both a broken set of $3000 coil overs and head studs that were left loose on my car by raw resulting in a huge mess. get a refund go with ott. its nice keeping money in canada yes but when all they make is junk it becomes your expense.
It sounds like your cig ltr fuse is blown. It is a 15amp fuse in the black box under the hood. This will cause you to not be able to use your OBD-2 port. That tune is unlocked because I have it and have used it as a base for several vehicles I have personally tuned. It's actually a pretty good tune.
So Rebel finally e-mailed me, and he has no clue on how to install the harness either. Hopefully he gets back to me becasue I asked him to get in touch with his supplier about the install.
Last edited by Red07Coupe; May 24, 2009 at 01:23 PM. Reason: Automerged Doublepost
I just installed the harness with the 1-2-3-4 combination and reset the PCM like rebel said (disconnected the battery for 30 min, I left it for an hour)
Still have the CEL, must be something else.
Turns out that the fuse was blown, thanks again for the tip man. I'll try the reader again hopefully tomorrow.
Last edited by Red07Coupe; May 24, 2009 at 03:44 PM. Reason: Automerged Doublepost
So we got the reader to work and had a few codes pop up. Maybe you guys can help with them.
- P0300 Random misfire (probably when I was running the harness the wrong way, they are not coming up anymore)
- P0315 Crankshaft Position (CKP) System Variation Not Learned (I'm not sure about this one but alldata says the crank will re-learn it position after 5 warm up sequences) This happens on start up and keeps poping up
- P0172 DTC P0172 Fuel Trim System Rich, This just looks like Rebel tuned the mixture up to rich, its an easy fix and I'm not to worried.
And help would be good
So its been almost 3 days since I e-mailed Rebel about my problems with no reply. Looks like this guy is trying to run from his problems rather then fix them. Looks like I'm going to have to get another tuner to fix his **** ups.
BUYER BEWARE!!! REBEL AUTO WORXS IS A HACK!!!
https://www.cobaltss.net/forums/show...31#post3916231
Last edited by Red07Coupe; May 27, 2009 at 01:18 AM. Reason: Automerged Doublepost
I know all about Rebels problems, I had some myself.
You probably need a case learn done on your car, you ned a tech 2, or HP Tuners to do that.
Lots of cars pop the 0300, check your plug gap, and conditions of your plugs.
Get the case learn taken care of first, and then look at the other problems.
Kevin
Kevin
Sean Cummings
Mar 9, 2018 12:26 AM
roth
Sep 26, 2015 12:16 PM
