Bank 1 too lean code??
Old Jul 31, 2012 | 10:39 AM
SS1's Avatar
SS1
2006 cobalt ss/sc (bank one too lean) code, the motor is stock. the cai is already ruled out. same code with stock airbox. maf is original and clean. the car has had this issue since in bought it. i had a warranty motor job and the tech flashed the car for a 2005. the code didnt come back afterwards but i had other issues. reflashed the car recently to the correct 2006 flash and within a few miles the car started codeing. and immediately went into engine reduce power. i reset the computer cleared the code and now it doesnt shut down but still codes. the injectors are stock. anyone else experience this on their ride? i have a few theories but id like some help ruling them out.
Old Jul 31, 2012 | 11:07 AM
any cracks or holes in the header or downpipe
is the o2 sensor not functioning correctly, what is the code?
some codes can have more than one answer
Old Jul 31, 2012 | 11:33 AM
Chevycobaltss3's Avatar
HOw did you manage on rulling the cai out? Did you log the car and verify trims are within reason and did you look at the narrow band readings to see what cruise Mvs are?
Old Jul 31, 2012 | 12:36 PM
take'em to school
Old Jul 31, 2012 | 12:42 PM
p0171 is caused by trims being out of wack, either exhaust leak, intake leak somewhere or just shitty trims from having a screwed airflow!
Old Jul 31, 2012 | 02:19 PM
SS1's Avatar
SS1
cfghsjsjytsytustjyshjhqalfikuhq **** oiqpaowuihhq;awhgtahwhqa not helping jhlkajhifuhahflahfkjehahlfikhal info is all good if i had the specs to compare the info too. jhlahfiuhuifhilahehalela thanks for the pep talk.
Old Jul 31, 2012 | 02:40 PM
Also if he flashed a 05 file on the car and its a 06, i cant beleive it ran (correctly with just a code)
Old Jul 31, 2012 | 03:12 PM
SS1's Avatar
SS1
the dealer flashed the ecu, and it didn't run correctly when it was an 05 it just didn't throw this code or any codes. it would misfire at high mph and rpm occasionally. since being flashed to an 06 the correct year the car now throws this lean code and thats what is throwing me off. what is the difference between 05 and 06 as far as mapping goes. this is where i think i have to start to determine what the actual problem is. i'm not looking to be showed up be someone who may know more than me so if ur not on here with the purpose to just lend a hand or some info. dont bother chimeing in thanks.
Old Jul 31, 2012 | 03:22 PM
Bro first off all I do is help, second off if you ask a question prepare to get some **** from some members for it. Am I giving you ****? No.
Different between te 05 and 06 mapping is basically all your fuelling other then a few tables and etc
Old Jul 31, 2012 | 03:30 PM
SS1's Avatar
SS1
hey pal did i call you out directly? dont think i did. im an easy going person and pretty easy to get along with. now i'm frustrated with this issue im dealing with and i was makeing it clear that im really not in the frame of mind to be ******* around anymore. bro so thank you for any help you have offered i very much appreciate it. and i'd like to drop the drama here and move on if its cool with ya? =-)
Old Feb 15, 2013 | 06:33 PM
Jonah Gogel's Avatar
Hey, I have the same problem..... but had no flash done on it. Mine threw the same code ever since putting a cai on it lol it seems that the car does not respond well to bolt ons to me, which sux cause i live n missouri and there is no where to take it to tune it..... any input would be great and it bucks like ****, bogs, and does not wanna rev past 5,500 rpms at WOT please help
Old Feb 15, 2013 | 06:34 PM
Almost seems like toooo much throttle response, you know?
Old Feb 15, 2013 | 06:41 PM
thedubsack85's Avatar
Have you had the stock airbox back on with the 06 flash long enough for the car to re-learn it's self which is a drive cycle or two? Did you make sure to re-set the computer (disconnect Neg battery terminal for 10-15 min?) when you put the stock airbox back on after the correct 06 flash? Normally a bank one lean code is the MAF Hz exceeding it's normal range cause of a CAI. My 07 did it back in the day! If it's missing also you may have other problems.. Subaru exhaust note?
Old Feb 15, 2013 | 07:54 PM
How did you fix your problem from back in the day?
Old Feb 16, 2013 | 12:40 AM
If you have a CAI and the lean code you have to tune it to either turn it off or accept the higher Hz range of 15K+. I saw your thread where your stock and having a lean code id get the car logged to see what the MAF is reading as it may have gone bad.
Old Feb 17, 2013 | 02:31 AM
M47TYB's Avatar
yeah man, seems like your flipping out.
i had your problem recently, cleaned all my ****, nothing. than ruled it to my maf, replaced it and bingo bango
or your intakes **** and you need a tune with it lol im running injen and longtubes without a tune now just fine
Old Feb 17, 2013 | 02:57 AM
turbosmart4's Avatar
I'm working on getting rid of the code on my stock balt......
Old Feb 17, 2013 | 08:23 AM
took off the injen intake, modified the stock air box, and now the car runs like a dream. I seriously think what dub sak said is right, but im not paying to get it tuned for that little amount of upgrades. Im gonna wait till i can get stage 2 and some other goodies first. Thank you guys for all your help!!!!
Old Feb 17, 2013 | 08:26 AM
Monday I get a new muffler put on the red dragon !!!
Old Feb 17, 2013 | 08:33 AM
Vander Nars's Avatar
U dont say.....
Old Feb 17, 2013 | 02:27 PM
b00sted06ss's Avatar
Well I just got the lean code yesterday, I don't think it'd be from my intake since I've had it on for a couple years and just now got it.. No exhaust leaks but I'm going to try and install the factory intake and go from there
Old Feb 18, 2013 | 02:37 AM
If it's unusually cold in your area when you were driving then it may be.. If you have the software to log id do that just to be safe! Funny to me how vander bolds everything but what i said and it being right...
Old Feb 18, 2013 | 11:28 AM
steveobed's Avatar
pull up data stream and see if your within the parameters, then pull a vacuum line and see if the 02 sensor compensates for the vacuum leak, if not then there's your problem
Old Feb 26, 2013 | 10:05 AM
BlackyK's Avatar
I have the Fujita F5 intake and when its 38-40 degrees (air is most dense) I'll get a lean code too. Can't tell if the stock air box would fix it since I bought the intake before the car, 6 years ago lol. Conveniently enough, I get the CEL right around when I need to inspect the car, in February. I haven't had the code for about 10 days, I think I can chance it now lol.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
