belt
Old Jun 3, 2010 | 10:36 PM
DEZZIE41's Avatar
belt
is there a how to to change belt on lsj?
Old Jun 4, 2010 | 10:31 AM
gwatson650's Avatar
i don't think that there is..i had a helluva time getting mine back on.
Old Jun 4, 2010 | 10:36 AM
Staged07SS's Avatar
Administrator
Administrator
http://www.crateenginedepot.com/stor...P1750C194.aspx
^ Nice info in there on how to get the belt started to make the install easier.
Old Jun 4, 2010 | 10:40 AM
coopercharge's Avatar
Its Farely straight forward what you need to do is have a decent 15mm open end wrench preferably with a long handle. Push down on the tensioner with the 15mm wrench towards the firewall to loosen the belt and pull it of make sure you remember how the belt is routed. The new belt should be wrapped around the 2 bottom pullies and the pulled and you will need to make a u shape with the belt around the alternator and then onece you have that done use the 15mm wrench and push back towards the fire wall again to pop the new belt into place. It should only take about 15 minutes.
Old Jun 4, 2010 | 10:42 AM
gwatson650's Avatar
we had to use a prybar to push back down the tensioner to get the belt back on. it doesn't help that the final pulley to get over is plastic.
Old Jun 4, 2010 | 10:51 AM
selfinfliction's Avatar
Easiest way is to loosen the supercharger bolts and let it lean in
Old Jun 4, 2010 | 11:23 AM
SO NOT Necessary, lot more work than need I have 2.8 inch supercharger pulley and the larger 2.5 inch idler pulley and didnt have any troubles. Its all about working smarter not harder.
The final pulley should be the supercharger pulley which I know mine is metal but have never seen them plastic and it really shouldn't make a difference.
Last edited by coopercharge; Jun 4, 2010 at 11:23 AM. Reason: Automerged Doublepost
Old Jun 4, 2010 | 11:34 AM
I wouldn't call loosening up 4 bolts harder lol
Old Jun 4, 2010 | 11:56 AM
Its more work than you need to do the belt is pud. There is no reason that you should have to loosen the bolts of the supercharger not to mention if you try to properly torque the bolt on the supercharger under the stress of the belt you could damage something.
Old Jun 4, 2010 | 11:58 AM
Thanks for letting me know that if you improperly torque a bolt, something could get messed up... I never knew that until now
Old Jun 4, 2010 | 12:32 PM
No reason to get all defensive. I only state these things because I learned from my mistakes forums are supposed to be a place to recieve help and if you give someone the wrong information you could potentially lead them to breaking something. Before posting something technical make sure that the quality of information you are lending is worth the time it took you to write it. If the OP would have used that information it could have ended up badly.
Old Jun 4, 2010 | 12:48 PM
Not defensive, I just appreciate your almighty and vast knowledge. How long have you owned a cobalt exactly?
Old Jun 4, 2010 | 12:57 PM
I had Red 07 LS that I bought brand new, and now I have the 06 SS so about 3 years now. But I have been working on cars since I was 15.
Old Jun 4, 2010 | 06:52 PM
and basically the only thing you've done is swap a pulley
congrats.
Old Jun 4, 2010 | 06:58 PM
2006superchargedss's Avatar
lolz
Old Jun 5, 2010 | 03:36 PM
congrats.
You know what it's waste of my time to sit here and have a pissing contest. Fact of the matter is what you said to do was wrong. OP I hope you dont try his suggestion as its not a good idea. However the choice is yours.
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
