belt installation tool?
guys that tool is the ****!
Supposedly the guys at PB said GM is adopting that tool for dealers, it not only relives tension, it holds it loose so you can work!
the only thing I have found that is slightly difficult is if you have an adjustable tensioner pulley, it might be harder to get the tool on initially if the pulley is on max tension, but you just push it down as you get it on.
Originally Posted by fljohnboy
I had a pair of pliars and some Mother F-ing everything.
damn i really need one of these... i think that when i put my pully on i slightly damaged the side of the idler pulley and that **** just tore my belt into pieces...
i know its my fault but if that damn pulley wasnt so damn hard to push down i think this could have been avoided...
Originally Posted by bdwarr6
get a wrench and do it like a man, its not that bad just put a towl over your hand
A wrench will do you absolutly no good if you have the adjustable tensioner.
Im ordering one of those right now. Im tired of my wrench slipping off that pos idler pulley and smashing my fingers against the block. I don't understand why its not like other GM vehicles and you can use a ratchet.
Anyone know where to hit up to get a new plastic pulley besides the dealer?? I broke mine using a pry bar.
Originally Posted by Joewit
Will the pulleyboys tool make it easier to put a stage 2 belt on?
in all honesty tho, u get 2 ppl. one with a wrench, 1 with a large screw driver. easy swap on the belt/pulley
