Belt tension
Old Dec 12, 2010 | 11:36 PM
Stone629's Avatar
I still don't understand why so many people are having trouble relieving the tension on their belts. Use at least a 12 inch handle, insert the torx bit into the tension pulley with the handle at the 10 o'clock position, and push down on it towards the rear of the car. It takes 2 seconds and about 15 lbs of force. Something tells me people are grabbing a 6 inch long WRENCH, and trying to get leverage with that. Removing the supercharger to remove the belt is absurd. Its not that bad.
Old Dec 13, 2010 | 06:15 AM
05Slowline's Avatar
Originally Posted by moranjames89
why don't you just tell me.... are YOU serious?
cylinder pressure........
asking a question like that and have yourself tuning in your sig, i'm waitin for the pop thread lol.
Old Dec 13, 2010 | 09:45 AM
denlou's Avatar
that didn't hurt as much as you thought it would just tell me mr. president about your top secret about winterizing your car.
Well it's simple Johnny, plug your ******* car in.
Old Dec 13, 2010 | 09:59 AM
xxxxsh4d0wxxxx's Avatar
Huh? If you use the T-50 torx bit and push to the back of the car, that will remove said bolt. It is not a tension/pivot point.
Maybe post up a picture.
Old Dec 13, 2010 | 10:16 AM
Staged07SS's Avatar
Administrator
Administrator
In the LSJ build book they tell you to use a 15mm flank drive wrench for the tensioner.
Some hammer on a 14mm open ended wrench.
There is also a tensioner tool for our car. I have it in my favorites on my home computer, and can post the link after work.
I have always used a small pry bar for my pulley swaps, and have never had an issue. I'm not a fan of loosening the bolts and tipping the supercharger out method.
Here's the link to the tensioner tool:
http://www.pulleyboys.com/store/prod...0&cat=2&page=1
Old Dec 13, 2010 | 08:02 PM
Stone629's Avatar
Just made a quick how to vid. Will be up in a minute.
Old Dec 13, 2010 | 08:15 PM
Stone629's Avatar
Here you go guys, I went out in the freezing cold just for ya'll. Sorry for not being able to speak more clearly, I was trying to hold a flashlight in my mouth, lol.
YouTube - Cobalt SS/SC Belt removal tension pulley release
Old Dec 13, 2010 | 08:18 PM
CanadianCobalt's Avatar
Damn, did you need to reef the **** out of the bolt on first? Mine just comes off.
Joel
Old Dec 13, 2010 | 08:23 PM
Stone629's Avatar
I just push down very slowly. If it does break loose while you are pushing down, go ahead and give it a good tightening. It should be tight enough that it doesn't do that, to be honest.
Old Dec 13, 2010 | 08:41 PM
bluesat's Avatar
hey stone629 is that an adjustable tensioner from zzp?
Old Dec 13, 2010 | 09:04 PM
  #36
Stone629's Avatar
It could be, it was on there when I bought the car. Everything else was stock when I picked it up.
Old Dec 13, 2010 | 09:57 PM
  #37
Staged07SS's Avatar
Administrator
Administrator
Yeah, I thought it looked like one. Nice video though
Old Dec 13, 2010 | 10:04 PM
  #38
Stone629's Avatar
For real!? Do they still offer it? I'd like to look at theirs to see how to adjust it. I can make my belt stop squeaking by pushing down on it while its running, so if I could lighten it a bit I bet that would get it to stop.
Edit... don't think it is adjustable judging by ZZP's pics of it. I'll have to go out there and put my eyes on it to tell for sure, but I don't think its a ZZP piece.
Old Dec 14, 2010 | 12:03 AM
  #39
Staged07SS's Avatar
Administrator
Administrator
Now that i look at it .... it looks like the stock tensioner w/o the plastic cover/lid covering the torx bit. It's tough to really tell due to the video being a little dark.
Old Dec 14, 2010 | 01:19 AM
  #40
I was just about to say, damn mine doesn't look like that..
Like Staged said, it looks like the ZZP piece, or the stock one without the cover.
Old Dec 14, 2010 | 08:13 AM
  #41
Stone629's Avatar
I popped that cover off awhile back, I believe. I'll get a good pic for you guys later.
Old Dec 14, 2010 | 10:13 AM
  #42
ecot3c inside's Avatar
haha you mean 'boost' amounting to cylinder pressure? you honestly think that will make a difference? In the cold you have more boost, but I for one am not doing pulls in the winter...
You guys can go ahead and go through the trouble to swap pulleys.
Old Dec 14, 2010 | 10:24 AM
  #43
rnjmur's Avatar
I had a 12 inch prybar that I used to push down the tensioner on my LSJ, that was the best way I found for doing it.
  #44
Staged07SS's Avatar
Administrator
Administrator
Same here.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
